Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2008 Location: GSM DÜNYASI TEAM.
Member: 923948 Status: Offline Sonork: 100.1655611 Thanks Meter: 28 | ![]() before Welcome to Medusa Pro Software version 2.1.8. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Loading firmware. Please wait... Done. Selected eMMC interface. Your current activation is not fully compatible with present hardware and requires an upgrade. Some features may be disabled or slower than expected. Use Card Update Tool to activate your upgrade string. Socket detected! Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 4 bits Bus speed : 25 MHz Connecting to server. Please wait... Connection to server successful Full speed mode! Connecting... Device : Samsung eMMC AJNB3R Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100414A4E4233520309254192147B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : AJNB3R Product revision : 0.3 Product serial number : (hex) 9254192 Manufacturing date : 01/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/AJNB3R_13_01_2021_18_48_38.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: CPEFS (00010000, 00004000) 8 MB P05: m9kefs1 (00014000, 00002000) 4 MB P06: m9kefs2 (00016000, 00002000) 4 MB P07: m9kefs3 (00018000, 00002000) 4 MB P08: CARRIER (0001A000, 00000800) 1024 KB P09: PARAM (0001A800, 00004000) 8 MB P10: BOOT (0001E800, 00010000) 32 MB P11: RECOVERY (0002E800, 00013000) 38 MB P12: OTA (00041800, 00004000) 8 MB P13: CDMA-RADIO (00045800, 00002000) 4 MB P14: RADIO (00047800, 0002C000) 88 MB P15: TOMBSTONES (00073800, 00000800) 1024 KB P16: DNT (00074000, 00000800) 1024 KB P17: PERSISTENT (00074800, 00000400) 512 KB P18: PERSDATA (00074C00, 00006000) 12 MB P19: STEADY (0007AC00, 00000800) 1024 KB P20: RESERVED2 (0007B400, 00000C00) 1536 KB P21: SYSTEM (0007C000, 005DC000) 3000 MB P22: CACHE (00658000, 00064000) 200 MB P23: HIDDEN (006BC000, 0001E000) 60 MB P24: CP_DEBUG (006DA000, 00002800) 5 MB P25: USERDATA (006DC800, 0167A000) 11.24 GB Backuping EFS partition... Opening C:/Program Files/Medusa Pro Software/Backups/AJNB3R_EFS_0x6000_0xa000_13_01_2021_18_48_38.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.8; FW: 2.00. Backuping CPEFS partition... Opening C:/Program Files/Medusa Pro Software/Backups/AJNB3R_CPEFS_0x10000_0x4000_13_01_2021_18_48_38.bi n file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.8; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 507904 Number of sectors : 6144000 Device Manufacturer : samsung Device Platform : exynos5 Build ID : NRD90M Display Build ID : NRD90M.G610FDDU1BRG2 Release ID : 7.0 Device Model : SM-G610F Device Name : on7xeltedd Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : on7xeltedd-user 7.0 NRD90M G610FDDU1BRG2 release-keys after Welcome to Medusa Pro Software version 2.1.8. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Loading firmware. Please wait... Done. Selected eMMC interface. Your current activation is not fully compatible with present hardware and requires an upgrade. Some features may be disabled or slower than expected. Use Card Update Tool to activate your upgrade string. Socket detected! Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 4 bits Bus speed : 25 MHz Connecting to server. Please wait... Connection to server successful Full speed mode! Connecting... Device : Samsung eMMC 000000 Page size : 512 B Block size : 512 B Block count : 1048576 Size : 512.00 MB --------------------------------------------------------------- CID Info CID : 150100303030303030562014031443C7 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 000000 Product revision : 5.6 Product serial number : (hex) 20140314 Manufacturing date : 04/2016 --------------------------------------------------------------- CSD Info CSD : 902701320F5903FFF6DB7FE08A40403B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 512 Kbytes Boot2 size : 512 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/000000_13_01_2021_19_10_15.bin. Connect successful. |
![]() | #2 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,118 | Hello. Please, check your PM. What is the exact state of your memory? How did You manage to damage it? Last edited by Medusa Box; 01-14-2021 at 09:55. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
![]() | #3 (permalink) | |
Member: 923948 Status: Offline Sonork: 100.1655611 Thanks Meter: 28 | Quote:
Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: FT SCR2000 0 Loading firmware. Please wait... Done. Selected eMMC interface. Your current activation is not fully compatible with present hardware and requires an upgrade. Some features may be disabled or slower than expected. Use Card Update Tool to activate your upgrade string. Socket detected! Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 4 bits Bus speed : 25 MHz Connecting to server. Please wait... Connection to server successful Full speed mode! Connecting... Device : Samsung eMMC 000000 Page size : 512 B Block size : 512 B Block count : 1048576 Size : 512.00 MB --------------------------------------------------------------- CID Info CID : 150100303030303030562014031443C7 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 000000 Product revision : 5.6 Product serial number : (hex) 20140314 Manufacturing date : 04/2016 --------------------------------------------------------------- CSD Info CSD : 902701320F5903FFF6DB7FE08A40403B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 512 Kbytes Boot2 size : 512 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/000000_14_01_2021_12_11_43.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 2.00. Writing eMMC firmware from file: C:/Users/mesut/Desktop/klmag1jenb-b031 f ok/klmag1jenb-b031 f ok/ajnb3r_vnc0_00000000000000000000000000000000_7_0_r 1_15_27_22.bin...Done. Finalizing... Failed reconnect operation. Sorry, my phone didn't work, can you help me please | |
![]() | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,118 | Please, try to set Voltage to 2.8V and Bus speed to 1bit |
The Following 2 Users Say Thank You to Medusa Box For This Useful Post: |
![]() | #5 (permalink) |
Member: 923948 Status: Offline Sonork: 100.1655611 Thanks Meter: 28 | Welcome to Medusa Pro Software version 2.1.8. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: FT SCR2000 0 Loading firmware. Please wait... Done. Selected eMMC interface. Your current activation is not fully compatible with present hardware and requires an upgrade. Some features may be disabled or slower than expected. Use Card Update Tool to activate your upgrade string. Socket detected! Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Full speed mode! Connecting... Device : Samsung eMMC AJNB3R Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100414A4E4233520398A1E8DE437F Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : AJNB3R Product revision : 0.3 Product serial number : (hex) 98A1E8DE Manufacturing date : 04/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/AJNB3R_14_01_2021_12_37_10.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 2.00. RPMB: Authentication Key not yet programmed. Thank you very much, EMMC has improved |
The Following User Says Thank You to mesut07 For This Useful Post: |
