Old 04-17-2022, 11:42   #1 (permalink)
Member: 2287102
Thanks Meter: 119
easy jtag error can not be boot device
good day team
ihave problem
ufs chip is good it is good detection on emmc file manager all is ok
but when i try to detect using easy jtag plus emmc 2
to patch the mi account
but showing this error
( UFS Init Failed. Error: -112. Reason: Can't boot device )
Changelog:
05/05/2021 (ver 1.6.6.0)
Add: New keys for Oppo unpack
Fix: Bugs that have been found through your crash report
05.05.2021 (ver 2.0.1.0)
Add: Vendor LG
Add: Mediatek Preloader Parser
Add: OnePlus Unpacker
Add: Xiaomi Custom EDL Authorization
Add: Xiaomi Remove Mi Account (only Qualcomm)
Operation: Connect to Z3X EasyJtagPlus
Setting Interface to EasyJtag2/UFS-Socket
Setting IO Levels to Low
Setting Frequence to 66 Mhz
how to fix this issue
i have 2 pcs easy jtag plus v2
I HAVE UFS 254 ADAPTOR
I HAVE UFS 153 ADAPTOR
I HAVE ALSO ICFRIEND 3IN1
BUT ALL IS SAME PROBLEM
HOW TO SOLVE THIS ISSUE
THANKS TO ALL
Old 04-18-2022, 18:22   #2 (permalink)
Member: 2287102
Thanks Meter: 119
Any one can help me please ��
Old 04-20-2022, 18:43   #3 (permalink)
Member: 2287102
Thanks Meter: 119
Hello any one help me ��
Old 04-21-2022, 15:02   #4 (permalink)
Member: 2287102
Thanks Meter: 119
Any sudgestion ?
How to solve this?
Thanks
Old 04-22-2022, 06:45   #5 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
112 error - it a bad connection or dead chip
The Following User Says Thank You to layder For This Useful Post:
Old 04-22-2022, 10:31   #6 (permalink)
Member: 2287102
Thanks Meter: 119
THE CHIP IS good not dead brother
because after chip off then i read the chip on easy emmc manager then can read all file
but when i detect using emmc v2 to patch the mi account can not read error 112
then i try to resolder the chip on mother board then it is good the phone is alive
and again i chip off the ufs chip again then try to detect again on emmc v2
same error 112
Old 04-22-2022, 17:30   #7 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
please, post logs from detected chip
Old 04-23-2022, 08:40   #8 (permalink)
Member: 2287102
Thanks Meter: 119
here brother the logs of detection on east jtag emmc file manager
Source: EasyJtag Port [UFS]
Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
UFS Power Mode: HIGH
Scanner Thread Created..
Running EasyJtag UFS Mode...
UFS ISP Mode: OFF
UFS Safe Mode: ON
Init UFS Engine: 0/OK
EasyJtag Plus S/N: FE50FEDFA316A32A
EasyJtag Plus Box FirmWare: 2.53
Box Hardware = EasyJtag 2nd Generation
UFS: Socket Info:
S/N: 0x0123098F6F2262AAEE
Desc: EasyJTAG UFS Socket BGA-153 by EasyJTAG 13.01.21
Type: EasyJtag UFS Socket BGA-153
UFS: Voltage Info:
Mode: HIGH
VCC : 3251 mV, VCCQ2: 2797 mV
3v3 : 3321 mV, 1v2: 1224 mV
UFS: Memory Info:
Connection: UNKNOWN SOCKET TYPE
Vendor: MICRON
S/N: 0x03B5174B14D67E032100
OEM ID: MICRON
Firm Version: 1.02
Max LUNs: 32
LUNs Cnt: 6
W-LUNs Cnt: 1
LUNs ReConfig: Enabled
UFS Health Info:
UFS Life Time A: 0x01 -> 0% - 10% Life Time Used
UFS Life Time B: 0x01 -> 0% - 10% Life Time Used
UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks
UFS: LUNs Info:
LUN 0 -> Size: 61880320 Block(s)/236.05 GB
LUN 1 (Boot A) -> Size: 4096 Block(s)/16.00 MB
LUN 2 (Boot B) -> Size: 4096 Block(s)/16.00 MB
LUN 3 -> Size: 8192 Block(s)/32.00 MB
LUN 4 -> Size: 557056 Block(s)/2.13 GB
LUN 5 -> Size: 16384 Block(s)/64.00 MB
W-LUN 0xC4 (REPORT LUNS) -> Size: 65536 Block(s)/16.00 MB
UFS Init OK
Scanning Data From UFS Chip. Please wait..
Scanning GUID Partition Table from LUN 0
GUID Partition Table is Found. Max Parts: 64
GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB
GPT: SWITCH [000000006000 - 000000002000] Size: 8.00 KB
GPT: SSD [000000008000 - 000000008000] Size: 32.00 KB
GPT: DBG [000000010000 - 000000008000] Size: 32.00 KB
GPT: BK01 [000000018000 - 000000008000] Size: 32.00 KB
GPT: BK02 [000000020000 - 000000020000] Size: 128.00 KB
GPT: BK03 [000000040000 - 000000040000] Size: 256.00 KB
GPT: BK04 [000000080000 - 000000080000] Size: 512.00 KB
GPT: KEYSTORE [000000100000 - 000000080000] Size: 512.00 KB
GPT: FRP [000000180000 - 000000080000] Size: 512.00 KB
GPT: COUNTRYCODE [000000200000 - 000000200000] Size: 2.00 MB
GPT: MISC [000000400000 - 000000400000] Size: 4.00 MB
GPT: BK06 [000000800000 - 000000800000] Size: 8.00 MB
GPT: LOGFS [000001000000 - 000000800000] Size: 8.00 MB
GPT: FFU [000001800000 - 000000800000] Size: 8.00 MB
GPT: OOPS [000002000000 - 000001000000] Size: 16.00 MB
GPT: DEVINFO [000003000000 - 000001000000] Size: 16.00 MB
GPT: OEM_MISC1 [000004000000 - 000000100000] Size: 1.00 MB
GPT: METADATA [000004100000 - 000001000000] Size: 16.00 MB
GPT: BK08 [000005100000 - 000000F00000] Size: 15.00 MB
GPT: SPLASH [000006000000 - 000002000000] Size: 32.00 MB
GPT: BK09 [000008000000 - 000002000000] Size: 32.00 MB
GPT: PERSIST [00000A000000 - 000004000000] Size: 64.00 MB
GPT: PERSISTBAK [00000E000000 - 000004000000] Size: 64.00 MB
GPT: MTDBLK [000012000000 - 000002000000] Size: 32.00 MB
GPT: LOGDUMP [000014000000 - 000004000000] Size: 64.00 MB
GPT: MINIDUMP [000018000000 - 000006000000] Size: 96.00 MB
GPT: RAWDUMP [00001E000000 - 000008000000] Size: 128.00 MB
GPT: EXAID [000026000000 - 000018000000] Size: 384.00 MB
GPT: CUST [00003E000000 - 000040000000] Size: 1.00 GB
GPT: SUPER [00007E000000 - 000220000000] Size: 8.50 GB
GPT: VBMETA_SYSTEM_A [00029E000000 - 000000020000] Size: 128.00 KB
GPT: VBMETA_SYSTEM_B [00029E020000 - 000000020000] Size: 128.00 KB
GPT: BK010 [00029E040000 - 000001FC0000] Size: 31.75 MB
GPT: RESCUE [0002A0000000 - 000008000000] Size: 128.00 MB
GPT: USERDATA [0002A8000000 - 00385B7FB000] Size: 225.43 GB
GPT: BACKUP_GPT [003B037FB000 - 000000005000] Size: 20.00 KB
Reading Table Completed
Scanning GUID Partition Table from LUN 1
GUID Partition Table is Found. Max Parts: 32
GPT: XBL_A [000000006000 - 000000800000] Size: 8.00 MB
GPT: XBL_CONFIG_A [000000806000 - 0000007F5000] Size: 7.96 MB
GPT: LAST_PARTI [000000886000 - 000000775000] Size: 7.46 MB
GPT: BACKUP_GPT [000000FFB000 - 000000005000] Size: 20.00 KB
Scanning GUID Partition Table from LUN 2
GPT: XBL_B [000000006000 - 000000800000] Size: 8.00 MB
GPT: XBL_CONFIG_B [000000806000 - 0000007F5000] Size: 7.96 MB
Scanning GUID Partition Table from LUN 3
GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB
GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB
GPT: DDR [000000040000 - 000000200000] Size: 2.00 MB
GPT: MDMDDR [000000240000 - 000000100000] Size: 1.00 MB
GPT: LAST_PARTI [000000340000 - 000001CBB000] Size: 28.73 MB
GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20.00 KB
Scanning GUID Partition Table from LUN 4
GUID Partition Table is Found. Max Parts: 96
GPT: AOP_A [000000006000 - 000000080000] Size: 512.00 KB
GPT: BK41_A [000000086000 - 000000200000] Size: 2.00 MB
GPT: TZ_A [000000286000 - 000000400000] Size: 4.00 MB
GPT: HYP_A [000000686000 - 000000800000] Size: 8.00 MB
GPT: MODEM_A [000000E86000 - 00001C000000] Size: 448.00 MB
GPT: BLUETOOTH_A [00001CE86000 - 000000100000] Size: 1.00 MB
GPT: MDTPSECAPP_A [00001CF86000 - 000000400000] Size: 4.00 MB
GPT: MDTP_A [00001D386000 - 000002000000] Size: 32.00 MB
GPT: ABL_A [00001F386000 - 000000200000] Size: 2.00 MB
GPT: DSP_A [00001F586000 - 000004000000] Size: 64.00 MB
GPT: KEYMASTER_A [000023586000 - 000000100000] Size: 1.00 MB
GPT: BOOT_A [000023686000 - 00000C000000] Size: 192.00 MB
GPT: CMNLIB_A [00002F686000 - 000000100000] Size: 1.00 MB
GPT: CMNLIB64_A [00002F786000 - 000000100000] Size: 1.00 MB
GPT: DEVCFG_A [00002F886000 - 000000040000] Size: 256.00 KB
GPT: QUPFW_A [00002F8C6000 - 000000020000] Size: 128.00 KB
GPT: VBMETA_A [00002F8E6000 - 000000020000] Size: 128.00 KB
GPT: DTBO_A [00002F906000 - 000002000000] Size: 32.00 MB
GPT: UEFISECAPP_A [000031906000 - 000000200000] Size: 2.00 MB
GPT: MULTIIMGOEM_A [000031B06000 - 000000008000] Size: 32.00 KB
GPT: MULTIIMGQTI_A [000031B0E000 - 000000008000] Size: 32.00 KB
GPT: VM-LINUX_A [000031B16000 - 000002000000] Size: 32.00 MB
GPT: FEATENABLER_A [000033B16000 - 000000020000] Size: 128.00 KB
GPT: IMAGEFV_A [000033B36000 - 000000200000] Size: 2.00 MB
GPT: VENDOR_BOOT_A [000033D36000 - 000006000000] Size: 96.00 MB
GPT: AOP_B [000039D36000 - 000000080000] Size: 512.00 KB
GPT: BK41_B [000039DB6000 - 000000200000] Size: 2.00 MB
GPT: TZ_B [000039FB6000 - 000000400000] Size: 4.00 MB
GPT: HYP_B [00003A3B6000 - 000000800000] Size: 8.00 MB
GPT: MODEM_B [00003ABB6000 - 00001C000000] Size: 448.00 MB
GPT: BLUETOOTH_B [000056BB6000 - 000000100000] Size: 1.00 MB
GPT: MDTPSECAPP_B [000056CB6000 - 000000400000] Size: 4.00 MB
GPT: MDTP_B [0000570B6000 - 000002000000] Size: 32.00 MB
GPT: ABL_B [0000590B6000 - 000000200000] Size: 2.00 MB
GPT: DSP_B [0000592B6000 - 000004000000] Size: 64.00 MB
GPT: KEYMASTER_B [00005D2B6000 - 000000100000] Size: 1.00 MB
GPT: BOOT_B [00005D3B6000 - 00000C000000] Size: 192.00 MB
GPT: CMNLIB_B [0000693B6000 - 000000100000] Size: 1.00 MB
GPT: CMNLIB64_B [0000694B6000 - 000000100000] Size: 1.00 MB
GPT: DEVCFG_B [0000695B6000 - 000000040000] Size: 256.00 KB
GPT: QUPFW_B [0000695F6000 - 000000020000] Size: 128.00 KB
GPT: VBMETA_B [000069616000 - 000000020000] Size: 128.00 KB
GPT: DTBO_B [000069636000 - 000002000000] Size: 32.00 MB
GPT: UEFISECAPP_B [00006B636000 - 000000200000] Size: 2.00 MB
GPT: MULTIIMGOEM_B [00006B836000 - 000000008000] Size: 32.00 KB
GPT: MULTIIMGQTI_B [00006B83E000 - 000000008000] Size: 32.00 KB
GPT: VM-LINUX_B [00006B846000 - 000002000000] Size: 32.00 MB
GPT: FEATENABLER_B [00006D846000 - 000000020000] Size: 128.00 KB
GPT: VENDOR_BOOT_B [00006D866000 - 000006000000] Size: 96.00 MB
GPT: IMAGEFV_B [000073866000 - 000000200000] Size: 2.00 MB
GPT: BK42 [000073A66000 - 000000040000] Size: 256.00 KB
GPT: BK43 [000073AA6000 - 0000003A0000] Size: 3.63 MB
GPT: BK44 [000073E46000 - 000003400000] Size: 52.00 MB
GPT: DIP [000077246000 - 000000100000] Size: 1.00 MB
GPT: APDP [000077346000 - 000000040000] Size: 256.00 KB
GPT: GSORT [000077386000 - 000001000000] Size: 16.00 MB
GPT: MSADP [000078386000 - 000000040000] Size: 256.00 KB
GPT: SPUNVM [0000783C6000 - 000002000000] Size: 32.00 MB
GPT: LIMITS [00007A3C6000 - 000000008000] Size: 32.00 KB
GPT: LIMITS-CDSP [00007A3CE000 - 000000008000] Size: 32.00 KB
GPT: STORSEC [00007A3D6000 - 000000020000] Size: 128.00 KB
GPT: UEFIVARSTORE [00007A3F6000 - 000000080000] Size: 512.00 KB
GPT: LOGO [00007A476000 - 000004000000] Size: 64.00 MB
GPT: SECDATA [00007E476000 - 000000008000] Size: 32.00 KB
GPT: VM-KEYSTORE [00007E47E000 - 000000020000] Size: 128.00 KB
GPT: VM-DATA [00007E49E000 - 000000400000] Size: 4.00 MB
GPT: LAST_PARTI [00007E89E000 - 00000975D000] Size: 151.36 MB
GPT: BACKUP_GPT [000087FFB000 - 000000005000] Size: 20.00 KB
Scanning GUID Partition Table from LUN 5
GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104.00 KB
GPT: MODEMST1 [000000020000 - 000000200000] Size: 2.00 MB
GPT: MODEMST2 [000000220000 - 000000200000] Size: 2.00 MB
GPT: FSG [000000420000 - 000000200000] Size: 2.00 MB
GPT: FSC [000000620000 - 000000020000] Size: 128.00 KB
GPT: BK51 [000000640000 - 0000000C0000] Size: 768.00 KB
GPT: MDM1M9KEFS3 [000000700000 - 000000800000] Size: 8.00 MB
GPT: MDM1M9KEFS1 [000000F00000 - 000000800000] Size: 8.00 MB
GPT: MDM1M9KEFS2 [000001700000 - 000000800000] Size: 8.00 MB
GPT: MDM1M9KEFSC [000001F00000 - 000000100000] Size: 1.00 MB
GPT: LAST_PARTI [000002000000 - 000001FFB000] Size: 31.98 MB
GPT: BACKUP_GPT [000003FFB000 - 000000005000] Size: 20.00 KB
Partition #15 mount as [/LOGFS] -> 8.00 MB
Partition #20 mount as [/metadata] -> 16.00 MB
Partition #24 mount as [/persist] -> 64.00 MB
Partition #25 mount as [/persist] -> 64.00 MB
Partition #31 mount as [/cust] -> 1.00 GB
Partition #36 mount as [/mnt/rescue] -> 128.00 MB
Partition #65 mount as [/MODEM_A] -> 448.00 MB
Partition #66 mount as [/BLUETOOTH_A] -> 1.00 MB
Partition #70 mount as [/dev_70] -> 64.00 MB
Partition #90 mount as [/MODEM_B] -> 448.00 MB
Partition #91 mount as [/BLUETOOTH_B] -> 1.00 MB
Partition #95 mount as [/dev_95] -> 64.00 MB
Partition #118 mount as [/SPUNVM] -> 32.00 MB
Warning! Partition #37 -> 'USERDATA' is ENCRYPTED!
EmptyCheck:
EMPTY -> #2 - [SWITCH]
EMPTY -> #3 - [SSD]
EMPTY -> #4 - [DBG]
EMPTY -> #5 - [BK01]
EMPTY -> #7 - [BK03]
EMPTY -> #8 - [BK04]
EMPTY -> #9 - [KEYSTORE]
EMPTY -> #10 - [FRP]
EMPTY -> #11 - [COUNTRYCODE]
EMPTY -> #13 - [BK06]
EMPTY -> #15 - [FFU]
EMPTY -> #18 - [OEM_MISC1]
EMPTY -> #20 - [BK08]
EMPTY -> #21 - [SPLASH]
EMPTY -> #22 - [BK09]
EMPTY -> #25 - [MTDBLK]
EMPTY -> #26 - [LOGDUMP]
EMPTY -> #28 - [RAWDUMP]
EMPTY -> #29 - [EXAID]
EMPTY -> #34 - [BK010]
EMPTY -> #42 - [LAST_PARTI]
EMPTY -> #48 - [LAST_PARTI]
EMPTY -> #52 - [ALIGN_TO_128K_1]
EMPTY -> #53 - [CDT]
EMPTY -> #56 - [LAST_PARTI]
EMPTY -> #61 - [BK41_A]
EMPTY -> #66 - [MDTPSECAPP_A]
EMPTY -> #67 - [MDTP_A]
EMPTY -> #79 - [MULTIIMGOEM_A]
EMPTY -> #80 - [MULTIIMGQTI_A]
EMPTY -> #81 - [VM-LINUX_A]
EMPTY -> #86 - [BK41_B]
EMPTY -> #91 - [MDTPSECAPP_B]
EMPTY -> #92 - [MDTP_B]
EMPTY -> #104 - [MULTIIMGOEM_B]
EMPTY -> #105 - [MULTIIMGQTI_B]
EMPTY -> #106 - [VM-LINUX_B]
EMPTY -> #110 - [BK42]
EMPTY -> #111 - [BK43]
EMPTY -> #112 - [BK44]
EMPTY -> #113 - [DIP]
EMPTY -> #114 - [APDP]
EMPTY -> #124 - [VM-KEYSTORE]
EMPTY -> #125 - [VM-DATA]
EMPTY -> #126 - [LAST_PARTI]
EMPTY -> #130 - [ALIGN_TO_128K_2]
EMPTY -> #131 - [MODEMST1]
EMPTY -> #132 - [MODEMST2]
EMPTY -> #133 - [FSG]
EMPTY -> #134 - [FSC]
EMPTY -> #135 - [BK51]
EMPTY -> #139 - [MDM1M9KEFSC]
EMPTY -> #140 - [LAST_PARTI]
EmptyCheck: Done
Scanner Thread Terminated
Elapsed: 00:00:57:199
Found 142 Partition(s)..
Scan Done. Init Main Engine...
Use EasyJtag UFS Device: MT256GARAT4U31
Reader Engine Initialized.. 0/OK
Power Mode: HIGH
Config: 1001111111101111
Operation Done: [Init Engine], Elapsed: 00:00:00:101
and this is the logs of emmc tool v2 brother
eMMC_tool ver. 2.0.1.0 (release date: 05.05.2021)
Microsoft Windows 10 (64 bit) build 19044 (10.0.19041.1566)
Looking for EasyJTAG box...
EasyJTAG API ver. 3403
EasyJTAG Box Serial = FE50FEDFA316A32A
Card Serial = xxxxxxxx
EasyJTAG Box Firmware = 2.5302
Changelog:
Add: Vendor LG
when i resolder the ufs chip on motherboard the ufs chip ic good and the phone is power on and good condition
Old 04-23-2022, 08:49   #9 (permalink)
Member: 2287102
Thanks Meter: 119
whats the problem brother??
i have easy jtag ufs 153 adaptor and this is brandnew buy from official resseler
any solution brother??
and also according to my research in other forum this issue is maybe not supported by easy jtag i dont know if it is true
but please brother help me
thank you verry much
Old 04-23-2022, 11:54   #10 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
try to change settings in software
UFS: Voltage Info:
Mode: HIGH
Old 04-23-2022, 13:15   #11 (permalink)
Member: 2287102
Thanks Meter: 119
UFS: Voltage Info:
Mode: HIGH
all of this brother i already trying brother but all is same problem
Old 04-24-2022, 20:41   #12 (permalink)
Member: 2287102
Thanks Meter: 119
Any other incounter this error
Please help
Old 04-27-2022, 12:45   #13 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
post please screeshots of Normal connect and with errors
Old 05-04-2022, 11:43   #14 (permalink)
Member: 2287102
Thanks Meter: 119
this is the screen brother from detection and from error with setting high and low
Old 05-04-2022, 13:56   #15 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
try to copy EasyAPI.dll from efm folder to plus soft folder
Page generated in 0.20321 seconds with 9 queries
