04-17-2022, 11:42 | #1 (permalink) |
Freak Poster Join Date: Nov 2014
Member: 2287102 Status: Offline Thanks Meter: 119 | easy jtag error can not be boot device ihave problem ufs chip is good it is good detection on emmc file manager all is ok but when i try to detect using easy jtag plus emmc 2 to patch the mi account but showing this error ( UFS Init Failed. Error: -112. Reason: Can't boot device ) Changelog: 05/05/2021 (ver 1.6.6.0) Add: New keys for Oppo unpack Fix: Bugs that have been found through your crash report 05.05.2021 (ver 2.0.1.0) Add: Vendor LG Add: Mediatek Preloader Parser Add: OnePlus Unpacker Add: Xiaomi Custom EDL Authorization Add: Xiaomi Remove Mi Account (only Qualcomm) Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/UFS-Socket Setting IO Levels to Low Setting Frequence to 66 Mhz UFS Init Failed. Error: -112. Reason: Can't boot device how to fix this issue i have 2 pcs easy jtag plus v2 I HAVE UFS 254 ADAPTOR I HAVE UFS 153 ADAPTOR I HAVE ALSO ICFRIEND 3IN1 BUT ALL IS SAME PROBLEM HOW TO SOLVE THIS ISSUE THANKS TO ALL |
04-22-2022, 10:31 | #6 (permalink) |
Member: 2287102 Status: Offline Thanks Meter: 119 | THE CHIP IS good not dead brother because after chip off then i read the chip on easy emmc manager then can read all file but when i detect using emmc v2 to patch the mi account can not read error 112 then i try to resolder the chip on mother board then it is good the phone is alive and again i chip off the ufs chip again then try to detect again on emmc v2 same error 112 |
04-23-2022, 08:40 | #8 (permalink) |
Member: 2287102 Status: Offline Thanks Meter: 119 | here brother the logs of detection on east jtag emmc file manager Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: HIGH Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: ON Init UFS Engine: 0/OK EasyJtag Plus S/N: FE50FEDFA316A32A EasyJtag Plus Box FirmWare: 2.53 Box Hardware = EasyJtag 2nd Generation UFS: Socket Info: S/N: 0x0123098F6F2262AAEE Desc: EasyJTAG UFS Socket BGA-153 by EasyJTAG 13.01.21 Type: EasyJtag UFS Socket BGA-153 ID: 4673 UFS: Voltage Info: Mode: HIGH VCC : 3251 mV, VCCQ2: 2797 mV 3v3 : 3321 mV, 1v2: 1224 mV UFS: Memory Info: Connection: UNKNOWN SOCKET TYPE Vendor: MICRON Name: MT256GARAT4U31 S/N: 0x03B5174B14D67E032100 OEM ID: MICRON Firm Version: 1.02 Size: 0x003B97800000/238.37 GB Max LUNs: 32 LUNs Cnt: 6 W-LUNs Cnt: 1 LUNs ReConfig: Enabled UFS Health Info: UFS Life Time A: 0x01 -> 0% - 10% Life Time Used UFS Life Time B: 0x01 -> 0% - 10% Life Time Used UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks UFS: LUNs Info: LUN 0 -> Size: 61880320 Block(s)/236.05 GB LUN 1 (Boot A) -> Size: 4096 Block(s)/16.00 MB LUN 2 (Boot B) -> Size: 4096 Block(s)/16.00 MB LUN 3 -> Size: 8192 Block(s)/32.00 MB LUN 4 -> Size: 557056 Block(s)/2.13 GB LUN 5 -> Size: 16384 Block(s)/64.00 MB W-LUN 0xC4 (REPORT LUNS) -> Size: 65536 Block(s)/16.00 MB UFS Init OK Scanning Data From UFS Chip. Please wait.. Scanning GUID Partition Table from LUN 0 GUID Partition Table is Found. Max Parts: 64 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: SWITCH [000000006000 - 000000002000] Size: 8.00 KB GPT: SSD [000000008000 - 000000008000] Size: 32.00 KB GPT: DBG [000000010000 - 000000008000] Size: 32.00 KB GPT: BK01 [000000018000 - 000000008000] Size: 32.00 KB GPT: BK02 [000000020000 - 000000020000] Size: 128.00 KB GPT: BK03 [000000040000 - 000000040000] Size: 256.00 KB GPT: BK04 [000000080000 - 000000080000] Size: 512.00 KB GPT: KEYSTORE [000000100000 - 000000080000] Size: 512.00 KB GPT: FRP [000000180000 - 000000080000] Size: 512.00 KB GPT: COUNTRYCODE [000000200000 - 000000200000] Size: 2.00 MB GPT: MISC [000000400000 - 000000400000] Size: 4.00 MB GPT: BK06 [000000800000 - 000000800000] Size: 8.00 MB GPT: LOGFS [000001000000 - 000000800000] Size: 8.00 MB GPT: FFU [000001800000 - 000000800000] Size: 8.00 MB GPT: OOPS [000002000000 - 000001000000] Size: 16.00 MB GPT: DEVINFO [000003000000 - 000001000000] Size: 16.00 MB GPT: OEM_MISC1 [000004000000 - 000000100000] Size: 1.00 MB GPT: METADATA [000004100000 - 000001000000] Size: 16.00 MB GPT: BK08 [000005100000 - 000000F00000] Size: 15.00 MB GPT: SPLASH [000006000000 - 000002000000] Size: 32.00 MB GPT: BK09 [000008000000 - 000002000000] Size: 32.00 MB GPT: PERSIST [00000A000000 - 000004000000] Size: 64.00 MB GPT: PERSISTBAK [00000E000000 - 000004000000] Size: 64.00 MB GPT: MTDBLK [000012000000 - 000002000000] Size: 32.00 MB GPT: LOGDUMP [000014000000 - 000004000000] Size: 64.00 MB GPT: MINIDUMP [000018000000 - 000006000000] Size: 96.00 MB GPT: RAWDUMP [00001E000000 - 000008000000] Size: 128.00 MB GPT: EXAID [000026000000 - 000018000000] Size: 384.00 MB GPT: CUST [00003E000000 - 000040000000] Size: 1.00 GB GPT: SUPER [00007E000000 - 000220000000] Size: 8.50 GB GPT: VBMETA_SYSTEM_A [00029E000000 - 000000020000] Size: 128.00 KB GPT: VBMETA_SYSTEM_B [00029E020000 - 000000020000] Size: 128.00 KB GPT: BK010 [00029E040000 - 000001FC0000] Size: 31.75 MB GPT: RESCUE [0002A0000000 - 000008000000] Size: 128.00 MB GPT: USERDATA [0002A8000000 - 00385B7FB000] Size: 225.43 GB GPT: BACKUP_GPT [003B037FB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 1 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: XBL_A [000000006000 - 000000800000] Size: 8.00 MB GPT: XBL_CONFIG_A [000000806000 - 0000007F5000] Size: 7.96 MB GPT: LAST_PARTI [000000886000 - 000000775000] Size: 7.46 MB GPT: BACKUP_GPT [000000FFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 2 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: XBL_B [000000006000 - 000000800000] Size: 8.00 MB GPT: XBL_CONFIG_B [000000806000 - 0000007F5000] Size: 7.96 MB GPT: LAST_PARTI [000000886000 - 000000775000] Size: 7.46 MB GPT: BACKUP_GPT [000000FFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 3 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB GPT: DDR [000000040000 - 000000200000] Size: 2.00 MB GPT: MDMDDR [000000240000 - 000000100000] Size: 1.00 MB GPT: LAST_PARTI [000000340000 - 000001CBB000] Size: 28.73 MB GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 4 GUID Partition Table is Found. Max Parts: 96 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: AOP_A [000000006000 - 000000080000] Size: 512.00 KB GPT: BK41_A [000000086000 - 000000200000] Size: 2.00 MB GPT: TZ_A [000000286000 - 000000400000] Size: 4.00 MB GPT: HYP_A [000000686000 - 000000800000] Size: 8.00 MB GPT: MODEM_A [000000E86000 - 00001C000000] Size: 448.00 MB GPT: BLUETOOTH_A [00001CE86000 - 000000100000] Size: 1.00 MB GPT: MDTPSECAPP_A [00001CF86000 - 000000400000] Size: 4.00 MB GPT: MDTP_A [00001D386000 - 000002000000] Size: 32.00 MB GPT: ABL_A [00001F386000 - 000000200000] Size: 2.00 MB GPT: DSP_A [00001F586000 - 000004000000] Size: 64.00 MB GPT: KEYMASTER_A [000023586000 - 000000100000] Size: 1.00 MB GPT: BOOT_A [000023686000 - 00000C000000] Size: 192.00 MB GPT: CMNLIB_A [00002F686000 - 000000100000] Size: 1.00 MB GPT: CMNLIB64_A [00002F786000 - 000000100000] Size: 1.00 MB GPT: DEVCFG_A [00002F886000 - 000000040000] Size: 256.00 KB GPT: QUPFW_A [00002F8C6000 - 000000020000] Size: 128.00 KB GPT: VBMETA_A [00002F8E6000 - 000000020000] Size: 128.00 KB GPT: DTBO_A [00002F906000 - 000002000000] Size: 32.00 MB GPT: UEFISECAPP_A [000031906000 - 000000200000] Size: 2.00 MB GPT: MULTIIMGOEM_A [000031B06000 - 000000008000] Size: 32.00 KB GPT: MULTIIMGQTI_A [000031B0E000 - 000000008000] Size: 32.00 KB GPT: VM-LINUX_A [000031B16000 - 000002000000] Size: 32.00 MB GPT: FEATENABLER_A [000033B16000 - 000000020000] Size: 128.00 KB GPT: IMAGEFV_A [000033B36000 - 000000200000] Size: 2.00 MB GPT: VENDOR_BOOT_A [000033D36000 - 000006000000] Size: 96.00 MB GPT: AOP_B [000039D36000 - 000000080000] Size: 512.00 KB GPT: BK41_B [000039DB6000 - 000000200000] Size: 2.00 MB GPT: TZ_B [000039FB6000 - 000000400000] Size: 4.00 MB GPT: HYP_B [00003A3B6000 - 000000800000] Size: 8.00 MB GPT: MODEM_B [00003ABB6000 - 00001C000000] Size: 448.00 MB GPT: BLUETOOTH_B [000056BB6000 - 000000100000] Size: 1.00 MB GPT: MDTPSECAPP_B [000056CB6000 - 000000400000] Size: 4.00 MB GPT: MDTP_B [0000570B6000 - 000002000000] Size: 32.00 MB GPT: ABL_B [0000590B6000 - 000000200000] Size: 2.00 MB GPT: DSP_B [0000592B6000 - 000004000000] Size: 64.00 MB GPT: KEYMASTER_B [00005D2B6000 - 000000100000] Size: 1.00 MB GPT: BOOT_B [00005D3B6000 - 00000C000000] Size: 192.00 MB GPT: CMNLIB_B [0000693B6000 - 000000100000] Size: 1.00 MB GPT: CMNLIB64_B [0000694B6000 - 000000100000] Size: 1.00 MB GPT: DEVCFG_B [0000695B6000 - 000000040000] Size: 256.00 KB GPT: QUPFW_B [0000695F6000 - 000000020000] Size: 128.00 KB GPT: VBMETA_B [000069616000 - 000000020000] Size: 128.00 KB GPT: DTBO_B [000069636000 - 000002000000] Size: 32.00 MB GPT: UEFISECAPP_B [00006B636000 - 000000200000] Size: 2.00 MB GPT: MULTIIMGOEM_B [00006B836000 - 000000008000] Size: 32.00 KB GPT: MULTIIMGQTI_B [00006B83E000 - 000000008000] Size: 32.00 KB GPT: VM-LINUX_B [00006B846000 - 000002000000] Size: 32.00 MB GPT: FEATENABLER_B [00006D846000 - 000000020000] Size: 128.00 KB GPT: VENDOR_BOOT_B [00006D866000 - 000006000000] Size: 96.00 MB GPT: IMAGEFV_B [000073866000 - 000000200000] Size: 2.00 MB GPT: BK42 [000073A66000 - 000000040000] Size: 256.00 KB GPT: BK43 [000073AA6000 - 0000003A0000] Size: 3.63 MB GPT: BK44 [000073E46000 - 000003400000] Size: 52.00 MB GPT: DIP [000077246000 - 000000100000] Size: 1.00 MB GPT: APDP [000077346000 - 000000040000] Size: 256.00 KB GPT: GSORT [000077386000 - 000001000000] Size: 16.00 MB GPT: MSADP [000078386000 - 000000040000] Size: 256.00 KB GPT: SPUNVM [0000783C6000 - 000002000000] Size: 32.00 MB GPT: LIMITS [00007A3C6000 - 000000008000] Size: 32.00 KB GPT: LIMITS-CDSP [00007A3CE000 - 000000008000] Size: 32.00 KB GPT: STORSEC [00007A3D6000 - 000000020000] Size: 128.00 KB GPT: UEFIVARSTORE [00007A3F6000 - 000000080000] Size: 512.00 KB GPT: LOGO [00007A476000 - 000004000000] Size: 64.00 MB GPT: SECDATA [00007E476000 - 000000008000] Size: 32.00 KB GPT: VM-KEYSTORE [00007E47E000 - 000000020000] Size: 128.00 KB GPT: VM-DATA [00007E49E000 - 000000400000] Size: 4.00 MB GPT: LAST_PARTI [00007E89E000 - 00000975D000] Size: 151.36 MB GPT: BACKUP_GPT [000087FFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 5 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104.00 KB GPT: MODEMST1 [000000020000 - 000000200000] Size: 2.00 MB GPT: MODEMST2 [000000220000 - 000000200000] Size: 2.00 MB GPT: FSG [000000420000 - 000000200000] Size: 2.00 MB GPT: FSC [000000620000 - 000000020000] Size: 128.00 KB GPT: BK51 [000000640000 - 0000000C0000] Size: 768.00 KB GPT: MDM1M9KEFS3 [000000700000 - 000000800000] Size: 8.00 MB GPT: MDM1M9KEFS1 [000000F00000 - 000000800000] Size: 8.00 MB GPT: MDM1M9KEFS2 [000001700000 - 000000800000] Size: 8.00 MB GPT: MDM1M9KEFSC [000001F00000 - 000000100000] Size: 1.00 MB GPT: LAST_PARTI [000002000000 - 000001FFB000] Size: 31.98 MB GPT: BACKUP_GPT [000003FFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Partition #15 mount as [/LOGFS] -> 8.00 MB Partition #20 mount as [/metadata] -> 16.00 MB Partition #24 mount as [/persist] -> 64.00 MB Partition #25 mount as [/persist] -> 64.00 MB Partition #31 mount as [/cust] -> 1.00 GB Partition #36 mount as [/mnt/rescue] -> 128.00 MB Partition #65 mount as [/MODEM_A] -> 448.00 MB Partition #66 mount as [/BLUETOOTH_A] -> 1.00 MB Partition #70 mount as [/dev_70] -> 64.00 MB Partition #90 mount as [/MODEM_B] -> 448.00 MB Partition #91 mount as [/BLUETOOTH_B] -> 1.00 MB Partition #95 mount as [/dev_95] -> 64.00 MB Partition #118 mount as [/SPUNVM] -> 32.00 MB ================================= Warning! Partition #37 -> 'USERDATA' is ENCRYPTED! ================================= EmptyCheck: EMPTY -> #2 - [SWITCH] EMPTY -> #3 - [SSD] EMPTY -> #4 - [DBG] EMPTY -> #5 - [BK01] EMPTY -> #7 - [BK03] EMPTY -> #8 - [BK04] EMPTY -> #9 - [KEYSTORE] EMPTY -> #10 - [FRP] EMPTY -> #11 - [COUNTRYCODE] EMPTY -> #13 - [BK06] EMPTY -> #15 - [FFU] EMPTY -> #18 - [OEM_MISC1] EMPTY -> #20 - [BK08] EMPTY -> #21 - [SPLASH] EMPTY -> #22 - [BK09] EMPTY -> #25 - [MTDBLK] EMPTY -> #26 - [LOGDUMP] EMPTY -> #28 - [RAWDUMP] EMPTY -> #29 - [EXAID] EMPTY -> #34 - [BK010] EMPTY -> #42 - [LAST_PARTI] EMPTY -> #48 - [LAST_PARTI] EMPTY -> #52 - [ALIGN_TO_128K_1] EMPTY -> #53 - [CDT] EMPTY -> #56 - [LAST_PARTI] EMPTY -> #61 - [BK41_A] EMPTY -> #66 - [MDTPSECAPP_A] EMPTY -> #67 - [MDTP_A] EMPTY -> #79 - [MULTIIMGOEM_A] EMPTY -> #80 - [MULTIIMGQTI_A] EMPTY -> #81 - [VM-LINUX_A] EMPTY -> #86 - [BK41_B] EMPTY -> #91 - [MDTPSECAPP_B] EMPTY -> #92 - [MDTP_B] EMPTY -> #104 - [MULTIIMGOEM_B] EMPTY -> #105 - [MULTIIMGQTI_B] EMPTY -> #106 - [VM-LINUX_B] EMPTY -> #110 - [BK42] EMPTY -> #111 - [BK43] EMPTY -> #112 - [BK44] EMPTY -> #113 - [DIP] EMPTY -> #114 - [APDP] EMPTY -> #124 - [VM-KEYSTORE] EMPTY -> #125 - [VM-DATA] EMPTY -> #126 - [LAST_PARTI] EMPTY -> #130 - [ALIGN_TO_128K_2] EMPTY -> #131 - [MODEMST1] EMPTY -> #132 - [MODEMST2] EMPTY -> #133 - [FSG] EMPTY -> #134 - [FSC] EMPTY -> #135 - [BK51] EMPTY -> #139 - [MDM1M9KEFSC] EMPTY -> #140 - [LAST_PARTI] EmptyCheck: Done Scanner Thread Terminated Elapsed: 00:00:57:199 Found 142 Partition(s).. Scan Done. Init Main Engine... Use EasyJtag UFS Device: MT256GARAT4U31 Reader Engine Initialized.. 0/OK Source: EasyJtag Port [UFS] Power Mode: HIGH Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Config: 1001111111101111 Operation Done: [Init Engine], Elapsed: 00:00:00:101 and this is the logs of emmc tool v2 brother eMMC_tool ver. 2.0.1.0 (release date: 05.05.2021) Microsoft Windows 10 (64 bit) build 19044 (10.0.19041.1566) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = FE50FEDFA316A32A Card Serial = xxxxxxxx EasyJTAG Box Firmware = 2.5302 Changelog: 05/05/2021 (ver 1.6.6.0) Add: New keys for Oppo unpack Fix: Bugs that have been found through your crash report 05.05.2021 (ver 2.0.1.0) Add: Vendor LG Add: Mediatek Preloader Parser Add: OnePlus Unpacker Add: Xiaomi Custom EDL Authorization Add: Xiaomi Remove Mi Account (only Qualcomm) Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/UFS-Socket Setting IO Levels to Low Setting Frequence to 66 Mhz UFS Init Failed. Error: -112. Reason: Can't boot device when i resolder the ufs chip on motherboard the ufs chip ic good and the phone is power on and good condition |
04-23-2022, 08:49 | #9 (permalink) |
Member: 2287102 Status: Offline Thanks Meter: 119 | whats the problem brother?? i have easy jtag ufs 153 adaptor and this is brandnew buy from official resseler any solution brother?? and also according to my research in other forum this issue is maybe not supported by easy jtag i dont know if it is true but please brother help me thank you verry much |
04-23-2022, 11:54 | #10 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | try to change settings in software UFS: Voltage Info: Mode: HIGH Setting Interface to EasyJtag2/UFS-Socket Setting IO Levels to Low Setting Frequence to 66 Mhz UFS Init Failed. Error: -112. Reason: Can't boot device |
04-23-2022, 13:15 | #11 (permalink) | |
Member: 2287102 Status: Offline Thanks Meter: 119 | Quote:
all of this brother i already trying brother but all is same problem | |
