05-06-2014, 06:01 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: india,kerala..in NAJMU
Member: 955971 Status: Offline Sonork: 100.1638835 Thanks Meter: 115 | Write Block Failed, Reason: DATA SND CRC Error-I9300 Z3X EasyJtag Software ver. 1.2.0.0 Loading eMMC Addon Firmware... Box S/N: 16FFXXXXXXXXX, ,FW Ver.: 01.49 CMD Pullup Level:1670 mV CMD Active Level:2248 mV eMMC Device Information EMMC CID : 15010056545530304DF11C9627B75FD4 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 479602615 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_ 479602615_20140402_1006.extcsd Done. Running:SAMSUNG: Smart Factory Reset + Format... Z3X EasyJtag Software ver. 1.2.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1670 mV CMD Active Level:2248 mV Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! Running:SAMSUNG: MoviNAND Format... Z3X EasyJtag Software ver. 1.2.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1670 mV CMD Active Level:2248 mV EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_ 479602615_20140402_1006.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 1.2.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1670 mV CMD Active Level:2248 mV Writing... Done! Done. Please don't forget to repair extCSD from backup!!! Writing file...E:\Z3X download\i9300\EMMC_ROM2_2Mb_BOOT\EMMC_ROM2_000000 00_00200000.bin Z3X EasyJtag Software ver. 1.2.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1670 mV CMD Active Level:2248 mV Writing 000000200000 bytes to 00000000 ...ROM2 Retry writing adress 0x00000000 (Attempt #1)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #2)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #3)... Retry Fail !!! Write Block Failed, Reason: DATA SND CRC Error Writing file...E:\Z3X download\i9300\EMMC_ROM1_512Mb_USER\EMMC_ROM1_0000 0000_20000000.bin Z3X EasyJtag Software ver. 1.2.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1670 mV CMD Active Level:2248 mV Writing 000020000000 bytes to 00000000 ...ROM1 Retry writing adress 0x00000000 (Attempt #1)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #2)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #3)... Retry Fail !!! Write Block Failed, Reason: DATA SND CRC Error .... |
05-06-2014, 07:06 | #2 (permalink) |
Member: 955971 Status: Offline Sonork: 100.1638835 Thanks Meter: 115 | Tryed last version (EasyJtag_Release_v1.3.2.0) Try ed last version (EasyJtag_Release_v1.3.2.0).......BUT Same Rsult.. EasyJtag Suite ver.: 1.3.2.0 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Successefuly connected to box on COM83 Box S/N: 16Fxxxxxxxxxxx, ,FW Ver.: 01.50 Box Working Mode: JTAG Box. Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : Axxxxxxxx , ver: 22 Z3X EasyJtag Software ver. 1.3.2.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 16Fxxxxxxxxxxxxxx, ,FW Ver.: 01.50 Warning: CMD Pullup Level (1082 mV) too low , check cables etc.!!! CMD Active Level:1392 mV eMMC Device Information EMMC CID : 15010056545530304DF11C9627B75FD4 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 479602615 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_ 479602615_20140402_1108.extcsd Done. Writing file...E:\Z3X download\i9300\EMMC_ROM2_2Mb_BOOT\EMMC_ROM2_000000 00_00200000.bin Z3X EasyJtag Software ver. 1.3.2.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1082 mV CMD Active Level:1392 mV Writing 000000200000 bytes to 00000000 ...ROM2 Retry writing adress 0x00000000 (Attempt #1)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #2)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #3)... Retry Fail !!! Write Block Failed, Reason: DATA SND CRC Error ......... |
05-06-2014, 10:54 | #3 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | You may try read 512kb from main and rom2 and upload somewhere - i will look situation after wipe. Also may try 1.3.3 - we increased write timeout on 25% maybe your flash very slow. |
05-20-2014, 21:05 | #5 (permalink) | |||
Junior Member Join Date: Jan 2006 Location: Russia, Siberia
Member: 227137 Status: Offline Thanks Meter: 9 | Quote:
My log: Quote:
Write - bad. Tel - samsung N7100, chip soldered in EMMC adapter. Quote:
P.S. ATFJtag also does not write. | |||
05-20-2014, 23:04 | #6 (permalink) | |
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Quote:
https://mega.co.nz/#!TEsCHa7J!BWdOAs...CIAoRoZ9oPFPT0 | |
06-03-2014, 08:18 | #7 (permalink) |
Major Poster Join Date: Apr 2011 Location: Kerala,DRC
Member: 1549945 Status: Offline Thanks Meter: 2 | Write Block Failed, Reason: DATA SND CRC Error Please help, Z3X EasyJtag Software ver. 1.5.2.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 04040618A0D34483, ,FW Ver.: 01.50 CMD Pullup Level:1144 mV CMD Active Level:1526 mV eMMC Device Information EMMC CID : 15010056545530304DF15FDC55735FD2 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 1608275315 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_1608275315_20140502_0911.extcsd Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 1.5.2.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1144 mV CMD Active Level:1526 mV EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:1144 mV CMD Active Level:1526 mV Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_1608275315_20140 501_1733.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 1.5.2.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1144 mV CMD Active Level:1526 mV Writing... Done! Done. Please don't forget to repair extCSD from backup!!! Writing file...D:\Easy Jtag Files\GT-I9300\EMMC_ROM2_2Mb_BOOT\EMMC_ROM2_00000000_002000 00.bin Z3X EasyJtag Software ver. 1.5.2.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1144 mV CMD Active Level:1526 mV Writing 000000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Retry writing adress 0x00000000 (Attempt #1)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #2)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #3)... Retry Fail !!! Write Block Failed, Reason: DATA SND CRC Error |
06-03-2014, 08:20 | #8 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
The Following User Says Thank You to blang For This Useful Post: |
06-04-2014, 19:55 | #9 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | Quote:
06-05-2014, 09:25 | #10 (permalink) |
Member: 1549945 Status: Offline Thanks Meter: 2 | Now its possible to write files but bad luck phone does't booted on its done compleately no power on now any help Skip loading eMMC Addon Firmware CMD Pullup Level:825 mV CMD Active Level:1072 mV Reading S.M.A.R.T S.M.A.R.T Ver. 0 , Card Error mode : Normal Super Block size : 0x00800000 (8388608 bytes) Super Page size : 0x00004000 (16384 bytes) Optimal Write size : 0x00010000 (65536 bytes) Read Reclaim count : 0 Optimal TRIM size : 0x00002000 (8192 bytes) Total Number of banks : 4 Initial bad blocks per bank : 4,2,1,7 Runtime bad blocks per bank : 0,0,0,0 Reserved blocks left per bank : 47,49,50,44 All Erase counts (min,avg,max): 0,0,1 SLC Erase counts (min,avg,max): 0,0,1 MLC Erase counts (min,avg,max): 0,0,0 S.M.A.R.T Report Done !!! Z3X EasyJtag Software ver. 1.5.2.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 04040618A0D34483, ,FW Ver.: 01.50 CMD Pullup Level:1144 mV CMD Active Level:1526 mV eMMC Device Information EMMC CID : 15010056545530304DF15FDC55735FD2 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 1608275315 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: VTU00M_1608275315_20140504_0937.extcsd Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 1.5.2.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1144 mV CMD Active Level:1526 mV EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:1144 mV CMD Active Level:1526 mV Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_1608275315_20140 501_1733.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 1.5.2.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1144 mV CMD Active Level:1526 mV Writing... Done! Done. Please don't forget to repair extCSD from backup!!! Writing file...D:\Easy Jtag Files\GT-I9300\EMMC_ROM2_2Mb_BOOT\EMMC_ROM2_00000000_002000 00.bin Z3X EasyJtag Software ver. 1.5.2.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1144 mV CMD Active Level:1526 mV Writing 000000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Write Speed: 890 kB/s Done !!! Writing file...D:\Easy Jtag Files\GT-I9300\EMMC_ROM1_512Mb_USER\EMMC_ROM1_00000000_2000 0000.bin Z3X EasyJtag Software ver. 1.5.2.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1144 mV CMD Active Level:1526 mV Writing 000020000000 bytes to 00000000 ...ROM1 (USER ROM) Write Speed: 2615 kB/s Done !!! |
06-06-2014, 22:38 | #11 (permalink) | |
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | You forget to click magic button in bootom of eMMC tool. Your emmc boit config are zerous so phone will not start until they 0x00 0x00 ;-) Quote:
The Following User Says Thank You to NoName® For This Useful Post: |
06-11-2014, 08:18 | #12 (permalink) |
Member: 1549945 Status: Offline Thanks Meter: 2 | Z3X EasyJtag Software ver. 1.5.2.2 Skip loading eMMC Addon Firmware CMD Pullup Level:804 mV CMD Active Level:1072 mV Reading S.M.A.R.T S.M.A.R.T Ver. 0 , Card Error mode : Normal Super Block size : 0x00800000 (8388608 bytes) Super Page size : 0x00004000 (16384 bytes) Optimal Write size : 0x00010000 (65536 bytes) Read Reclaim count : 0 Optimal TRIM size : 0x00002000 (8192 bytes) Total Number of banks : 4 Initial bad blocks per bank : 4,2,1,7 Runtime bad blocks per bank : 0,0,0,0 Reserved blocks left per bank : 47,49,50,44 All Erase counts (min,avg,max): 0,2,10 SLC Erase counts (min,avg,max): 0,0,10 MLC Erase counts (min,avg,max): 2,2,5 S.M.A.R.T Report Done !!! Z3X EasyJtag Software ver. 1.5.2.2 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 04040618A0D34483, ,FW Ver.: 01.50 CMD Pullup Level:1134 mV CMD Active Level:1536 mV eMMC Device Information EMMC CID : 15010056545530304DF15FDC55735FD2 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 1608275315 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_1608275315_20140503_0914.extcsd Done. |
06-12-2014, 08:19 | #14 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Oued zenati Algeria Age: 44
Member: 266158 Status: Offline Sonork: 131654654654 Thanks Meter: 198 | brother if u have repair emmc name 0000 than u must do boot confing n7100 i9300 one clic bouton then write rom 2 and phone will be alive report after test plz |
