Old 11-19-2013, 05:05   #16 (permalink)
unlock in nepal's Avatar
Member: 1686564
Sonork: PM me
Thanks Meter: 157
I9070 Direct eMMC pinout
I9070 support or not by Direct eMMC
I want to pin out my mobile not connect in Medusa
& Riff may phone taking current in dcpower supply
0.09 when i prase on of boad is untouch & frase
Old 11-19-2013, 11:04   #17 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Yes it supported , even if JTAG wont connect.
The Following User Says Thank You to NoName® For This Useful Post:
Old 11-19-2013, 17:36   #18 (permalink)
Member: 1686564
Sonork: PM me
Thanks Meter: 157
Thanks To NoName Sir
Thanks To NoName Sir If posable to so emc pinout pliz so me
I oder my box reasive in 1 wink pliz so me emc pinout
Old 11-21-2013, 21:51   #19 (permalink)
Member: 702604
Thanks Meter: 12
emmc pinout for s3 i9300
Hi all!!
Can someone give me pinouts for galaxy s3 i9300?
Thanks.
Old 11-21-2013, 23:55   #20 (permalink)
Member: 1351772
Sonork: 100.1640819
Thanks Meter: 4
HTC One M7 - directEMMC Pinout
Successefuly connected to box on COM13
Box S/N: xxxxxxxxxxxxxxxx, ,FW Ver.: 01.47
Loading eMMC Addon Firmware...
CMD Pullup Level:1742 mV
CMD Active Level:1866 mV
EMMC CID 1501004D4247344741002507630E2133
EMMC CSD D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufactorer ID: 15
EMMC OEM ID: 0100
EMMC Date: 02/1998 FW rev.0x0 HW rev.0x0
EMMC Serial #: 621241102
EMMC NAME: MBG4GA
EMMC Capacity: 29820 MB (High Density Card)
Extended CSD rev 1.6 (MMC 4.5)
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x01]:
implementation based on CMD13
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x3f]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x04]
Tag Resources Size [TAG_RES_SIZE: 0x00]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a]
Power off notification [POWER_OFF_LONG_TIME: 0x3c]
Cache Size [CACHE_SIZE] is 65536 KiB
Background operations status [BKOPS_STATUS: 0x00]
TRIM Multiplier [TRIM_MULT: 0x02]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
Device supports alternative boot method
Device supports dual data rate during boot
Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x10]
Access size [ACC_SIZE: 0x07]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x11]
Sector Count [SEC_COUNT: 0x03a3e000]
Partition switching timing [PARTITION_SWITCH_TIME: 0x01]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02]
I/O Driver Strength [DRIVER_STRENGTH: 0x0f]
Card Type [CARD_TYPE: 0x17]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x00]
Not boot enable
No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x01
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x04
Enable background operations handshake [BKOPS_EN]: 0x01
H/W reset function [RST_N_FUNCTION]: 0x01
HPI management [HPI_MGMT]: 0x00
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x000747
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
General Purpose Partition Size
[GP_SIZE_MULT_4]: 0x000000
[GP_SIZE_MULT_3]: 0x000000
[GP_SIZE_MULT_2]: 0x000000
[GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
Native sector size [NATIVE_SECTOR_SIZE]: 0x00
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be Released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status[EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
The Following User Says Thank You to MasterDuke For This Useful Post:
Old 11-23-2013, 05:52   #21 (permalink)
CELLMANIAC's Avatar
Member: 410843
Thanks Meter: 28
how about Gt-i9180 pin out direct?
The Following User Says Thank You to CELLMANIAC For This Useful Post:
Old 11-24-2013, 11:44   #22 (permalink)
Crazy Poster
Member: 1561698
Thanks Meter: 3
Please gt i8150 pin out direct!
thank's
The Following User Says Thank You to mikele09 For This Useful Post:
Old 11-24-2013, 15:51   #23 (permalink)
Member: 1773784
Thanks Meter: 27
plz. need I977 emmc pinout
The Following User Says Thank You to satglitch For This Useful Post:
Old 11-24-2013, 17:54   #24 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 931
I9100,N7000 and htc evo 3D cdma PG86100 emmc pinout pleasee
The Following 2 Users Say Thank You to mr.omphonx For This Useful Post:
Old 12-09-2013, 13:29   #25 (permalink)
fr3nsis's Avatar
Member: 190882
Sonork: BB PIN: 7C83D9CE
Thanks Meter: 1,282
can i have i9100 pinout?
my easy jtag is on the way and in themaintime i would to solder wires
thanks
The Following User Says Thank You to fr3nsis For This Useful Post:
Old 12-11-2013, 01:19   #26 (permalink)
Member: 1773784
Thanks Meter: 27
help I977 emmc pinout jtag
jtag pin are broken thank you
Old 12-19-2013, 11:39   #27 (permalink)
Member: 1906979
Sonork: 100.1681049
Thanks Meter: 162
very good thread, must be sticky
The Following User Says Thank You to KE6SOLTI For This Useful Post:
Old 12-30-2013, 17:49   #28 (permalink)
Member: 628250
Sonork: 100.1646879
Thanks Meter: 3
need pinouts i9100 ..
The Following User Says Thank You to bajoe_85 For This Useful Post:
Old 01-01-2014, 16:47   #29 (permalink)
Member: 1754897
Sonork: 100.1622738
Thanks Meter: 5
Motorola A956 eMMC CLK Location
I am attempting to read the eMMC on the above listed phone. On my test phone I have identified 4 of the 5 connection locations. I have not been able to locate the CLK location on the phone PCB, other than on CPU pinout.
Any help would be appreciated!
Thanks
J2
The Following User Says Thank You to Jacques2 For This Useful Post:
Old 01-18-2014, 03:25   #30 (permalink)
Member: 1890630
Sonork: 1223
Thanks Meter: 2
EMMC S6310 pin out please help me
The Following 2 Users Say Thank You to ASTROCEL For This Useful Post:
Page generated in 0.32471 seconds with 9 queries
