Old 07-09-2017, 18:33   #106 (permalink)
rajendrakumar's Avatar
Member: 488940
Sonork: 100.1594730
Thanks Meter: 110
Originally Posted by oblio View Post
Warning again, JPIN-JIC by MOORC has the pin no 17 shorted to ground, so cut it before using this adaptor or else you will destroy the internal regulator U7 !
how to cut ground from pin no 17.please reveal.thanks in advance.
Old 08-04-2017, 06:38   #107 (permalink)
Member: 331917
Thanks Meter: 214
I have a big doubt.....
what happens with "sticky" bootloaders??
did you see moto?
if you flash with latest version, then, you can not flash again lower boot version...
it will allow to flash the other files, but boot is not possible...
ok, what happens if you write lower boot via emmc??
would it work?
thanks
Old 08-08-2017, 00:37   #108 (permalink)
Member: 331917
Thanks Meter: 214
Hello Support, no ideas about this?
thanks
Old 09-14-2017, 16:39   #109 (permalink)
Member: 2177146
Thanks Meter: 20
hi
pls help me :
what is boot config emmc?
when should be used?
how do you diagnose?
Old 09-26-2017, 23:14   #110 (permalink)
Member: 2638162
Question Can We Make eMMC Chip reader?
I want to know that can we make emmc test socket adapter to decode pictures and data from the chip from damaged motherboard. i'm asking this because that device is not cheap and that is made by china company name is (sireda emmc test socket adapters)
Any one can help I want my lost data back in free or cheap :P :P
Old 09-29-2017, 11:43   #111 (permalink)
Member: 2758697
Sonork: 100.1670532
j2 prime sucessfully write bootloader but phone is still dead....
power butten pressing time power supply reading amp 0-12 .
swtich releasing time reading down to 0..
what is the correct reson...am to worry
Old 09-29-2017, 11:51   #112 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
emmc dead most case...............
Old 10-03-2017, 17:00   #113 (permalink)
Member: 2177146
Thanks Meter: 20
Originally Posted by h.azaraa View Post
hi
pls help me :
up...?????.........pls.......
The Following User Says Thank You to h.azaraa For This Useful Post:
Old 11-16-2017, 12:02   #114 (permalink)
Member: 1741973
Thanks Meter: 115
what is the good jumperwire for JTAG? i always encounter hi power mode is off but the wire is connected in the exact postion of the the jtag points according to the guide image of phone. what ever i tried to repeat soldering to make sur the wire is properly and strongly connected the problem still the same. if u try pull off the wire the remaining cut is on the every points of. allready put a resistor, 50-200 ohms regarding on its watts value, is the watts of resistor affected the voltage on the adapter? yesterday i try jtag an OPPO R1001 problem logo only but not so lucky to solve it because i face CMD error timedout. the other one is LG D295 secure boot verification problem, jtag got an error; Hi power mode is off...
The Following User Says Thank You to chmsc_ELX For This Useful Post:
Old 09-07-2018, 13:18   #115 (permalink)
Member: 900168
Thanks Meter: 2
J100h Emmc repaired , now its come to " Samsung j1" , after that went to the download mode , then undated with latest firmware . After 100% phone comes to "Samsung J1 " & restart . It never goes to Samsung logo.
Old 01-22-2021, 09:05   #116 (permalink)
Member: 925389
Thanks Meter: 32
how can i use isp 4-bit to direct emmc? where should conect dat 1 2 3 ???
Old 01-22-2021, 11:58   #117 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
4bit isp mode now is not release af box firmware. may be later
The Following 3 Users Say Thank You to layder For This Useful Post:
Page generated in 0.22886 seconds with 9 queries
