08-04-2017, 06:38 | #107 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Buenos Aires, Argentina
Member: 331917 Status: Offline Thanks Meter: 214 | I have a big doubt..... what happens with "sticky" bootloaders?? did you see moto? if you flash with latest version, then, you can not flash again lower boot version... it will allow to flash the other files, but boot is not possible... ok, what happens if you write lower boot via emmc?? would it work? thanks |
09-26-2017, 23:14 | #110 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2638162 Status: Offline Thanks Meter: 0 | Can We Make eMMC Chip reader? I want to know that can we make emmc test socket adapter to decode pictures and data from the chip from damaged motherboard. i'm asking this because that device is not cheap and that is made by china company name is (sireda emmc test socket adapters) Any one can help I want my lost data back in free or cheap :P :P |
09-29-2017, 11:43 | #111 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2758697 Status: Offline Sonork: 100.1670532 Thanks Meter: 1 | j2 prime sucessfully write bootloader but phone is still dead.... power butten pressing time power supply reading amp 0-12 . swtich releasing time reading down to 0.. what is the correct reson...am to worry |
11-16-2017, 12:02 | #114 (permalink) |
No Life Poster Join Date: Mar 2012 Location: gsm world
Member: 1741973 Status: Offline Thanks Meter: 115 | what is the good jumperwire for JTAG? i always encounter hi power mode is off but the wire is connected in the exact postion of the the jtag points according to the guide image of phone. what ever i tried to repeat soldering to make sur the wire is properly and strongly connected the problem still the same. if u try pull off the wire the remaining cut is on the every points of. allready put a resistor, 50-200 ohms regarding on its watts value, is the watts of resistor affected the voltage on the adapter? yesterday i try jtag an OPPO R1001 problem logo only but not so lucky to solve it because i face CMD error timedout. the other one is LG D295 secure boot verification problem, jtag got an error; Hi power mode is off... |
The Following User Says Thank You to chmsc_ELX For This Useful Post: |
09-07-2018, 13:18 | #115 (permalink) |
Junior Member Join Date: Nov 2008 Location: colombo, sri lanka
Member: 900168 Status: Offline Thanks Meter: 2 | J100h Emmc repaired , now its come to " Samsung j1" , after that went to the download mode , then undated with latest firmware . After 100% phone comes to "Samsung J1 " & restart . It never goes to Samsung logo. |
