08-06-2020, 01:00 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: In front of my pc
Member: 586318 Status: Offline Thanks Meter: 112 | How to know if a memory is in a good state? Code: eMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020) Microsoft Windows 10 (64 bit) build 18363 (10.0.18362.959) Looking for EasyJTAG box... EasyJTAG API ver. 3401 EasyJTAG Box Serial = XXXXXXXXX Card Serial = XXXXXXXXXX EasyJTAG Box Firmware = 2.5204 Changelog: Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 MHz CMD Pullup Level: 2093 mV CMD Active Level: 2263 mV EMMC Device Information : EMMC CID: 150100475836424D42004550066165FF EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: GX6BMB , HEX: 475836424D42 , S/N: 45500661 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 66 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: GX6BMB_45500661_20200805_173740.extcsd EMMC Init completed. Get firmware version Brand = samsung Manufacturer = samsung Device = a6plte Model = SM-A605GN CPU Abi = armeabi-v7a Android release = 8.0.0 Security Patch = 2018-04-01 Firmware version = R16NW.A605GNUBU1ARD7 Firmware date = Wed Apr 25 13:16:15 KST 2018 |
08-06-2020, 01:38 | #2 (permalink) |
Freak Poster Join Date: Jul 2013 Location: egypt alexandria
Member: 1972033 Status: Offline Thanks Meter: 32 | recording for that log nand memory is good but we cant say its good if this emmc have ram also and in first place wats wrong with this device Last edited by layder; 08-06-2020 at 11:47. Reason: merge posrs |
The Following User Says Thank You to nour2014 For This Useful Post: |
08-06-2020, 01:54 | #3 (permalink) |
Member: 586318 Status: Offline Thanks Meter: 112 | The customer take it to a store for flashing the phone due to some software errors, but the technician told me that he flashed it and the process was ok, but sometimes the screen became into rose color or something like that. The customer bring me the phone to activate the battery due to it was completely dead but after given some charge to the battery the phone does not turn on at all. So I read the info in with the easy jtag classic version and there is no user data (it is in blank, just zeros) |
