05-07-2017, 14:11 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | OPPO R831K emmc done ( wipe data fail) Loading eMMC Addon Firmware... IO: 1800 mV Box S/N: 0B00100EE1608FB2, ,FW Ver.: 01.58 CMD Pullup Level:1701 mV CMD Active Level:1763 mV Box IO Level:1800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A4834473164040509A29DCCB1E8 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 11/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 161652172 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d _ 161652172_20170226_1720.extcsd Searching for partition tables... Partitioning not detected... Done. Running:JEDEC: Partitions config burn... Z3X EasyJtag Software ver. 2.5.0.7 Skip loading eMMC Addon Firmware CMD Pullup Level:1701 mV CMD Active Level:1763 mV Box IO Level:1800 mV CLK Rate:14000 khz Partition configuration: No enhanced user data area User partition write reliability: on No GP1 partition GP1 write reliability: on No GP2 partition GP2 write reliability: on No GP3 partition GP3 write reliability: on No GP4 partition GP4 write reliability: on Partitioning successful, power-cycle to make effective HW Parts Config Done. |
The Following User Says Thank You to ALI_MAFIA For This Useful Post: |
05-07-2017, 18:22 | #3 (permalink) | |
No Life Poster Join Date: May 2013 Location: In Core Of eMMC
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | Quote:
