Old 08-24-2019, 00:12   #91 (permalink)
khalidahmed's Avatar
Member: 2298142
Thanks Meter: 240
How to possible
Oppo rmx1945 (Realme C2)
Pattern reset with easy jtag box
Plz give any success post
Old 08-24-2019, 00:23   #92 (permalink)
Member: 798811
Sonork: astrong
Thanks Meter: 16
is very good job brother...............
Br.
Old 08-24-2019, 02:30   #93 (permalink)
Member: 1708622
Thanks Meter: 7
R15x need isp pinout
Old 08-24-2019, 09:04   #94 (permalink)
AniAxn's Avatar
Member: 1045758
Sonork: 100.1613661(Offline)
Thanks Meter: 4,307
Arrow OPPO A3S CPH1803 Password & FRP Reset Done by EasyJtag
Wbr,
AniAXN
The Following 3 Users Say Thank You to AniAxn For This Useful Post:
Old 08-25-2019, 12:57   #95 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
any help friends ? should I extract firmware and flash userdata partition only ? or should i flash the hole firmware ?
how to avoid this problem next time ? thank you
Old 08-25-2019, 15:09   #96 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 2,363
Smile Realme C2 (RMX1945) pin / pattern or Frp remove done
Realme C2 (RMX1945) pin / pattern or Frp remove done with easy jtag...
pinout/isp
wipe user data
unlock done
Thanks easy jtag team
The Following 7 Users Say Thank You to pintu_das For This Useful Post:
Old 08-26-2019, 18:52   #97 (permalink)
Member: 2924824
Sonork: 100.650600
plz pin outs sends...
Old 08-27-2019, 06:06   #98 (permalink)
Member: 1915808
Sonork: 1656805:2042
Thanks Meter: 29
Oppo A7 cph1901 pattern lock done
oppo a7 cph 1901 pattern lock remove by easy jtag
select oppo a3s in tool
no any risk superb
Z3X EasyJtag Software ver. 3.6.1.15
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 0500A0045BF8E66E, ,FW Ver.: 01.63
CMD Pullup Level:1773 mV
CMD Active Level:2371 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 90014A484347386134A2267359A3B51A
eMMC CSD : D02701328F5903FFFFFFFFEF8A400026
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 11/2018 Rev.0xA2
eMMC NAME: HCG8a4 , S/N: 645093795
eMMC NAME (HEX): 484347386134
EMMC ROM1 (Main User Data) Capacity: 59640 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 3868 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: HCG8a4_ 645093795_20190827_1024.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x003E800000 (3.968GB)
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190516.002839 release-keys
Detected USERDATA USERDATA : 0x017E800000 (52.264GB)
Unable to mount USERDATA , code : 95
Done.
CMD Active Level:2681 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Can't init EMMC, Reason: DATA RCV CRC Error
Check Data Line!
Done.
CMD Pullup Level:1784 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
RPMB Info mmc_init Error, Reason: DATA RCV CRC Error
Real (Hardware) Disk/Image size: 100000000 sectors 2.0 TiB
Done.
CMD Pullup Level:1763 mV
CMD Active Level:2691 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes
Detected (Android Userdata) USERDATA : 0x017E800000 (52.264GB)
Erasing...
Done.
Detected (Android Cache)) CACHE : 0x001F300000 (256.0MB)
Erasing...
Done.
Done.
Running:Format FRP Partition...
CMD Active Level:2361 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002F480000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x017E800000 (52.264GB) , formatting...
Done.
Done.
Done.
Running:Reset PIN/PASS/GESTURE Locks
CMD Active Level:2670 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Mount EXT4 fs...
Unable to mount USER , code : 95
Done.
The Following User Says Thank You to deepak pandey For This Useful Post:
Old 08-27-2019, 09:08   #99 (permalink)
Member: 1265808
Sonork: 1660165
Thanks Meter: 21
just jtag update last version and formate oppo & fix hang on logo or restart
Old 08-28-2019, 13:01   #100 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Talking OPPO A37f PATTERN L0CK REMOVE W/O LOSS
Setting interface to EasyJtag2/ISP_HiPower
Setting bus width to 1 Bit
HiPower mode is ON
Setting frequence to 18 MHz
CMD Pullup Level: 1790 mV
CMD Active Level: 1851 mV
EMMC Device Information :
EMMC CID: 13014E51324A3936521005F3B9E754DD
EMMC CSD: D07F01320F5913FFFFFFFFEF924000A3
EMMC Manufacture : MICRON , EMMC NAME: Q2J96R , HEX: 51324A393652 , S/N: 05F3B9E7 , rev. 0x10
EMMC Manufacture ID: 0x13 , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 5/2017
   EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: Q2J96R_05F3B9E7_20190828_153442.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: modem, [000004000000 - 000008000000], size: 000004000000 (64.0 MB)
Partition: DDR, [000008000000 - 000008008000], size: 000000008000 (32.0 KB)
Partition: fsg, [000008008000 - 000008188000], size: 000000180000 (1.50 MB)
Partition: sec, [000008188000 - 00000818C000], size: 000000004000 (16.0 KB)
Partition: fsc, [00000C000000 - 00000C000400], size: 000000000400 (1.00 KB)
Partition: ssd, [00000C000400 - 00000C002400], size: 000000002000 (8.00 KB)
Partition: sbl1, [00000C002400 - 00000C082400], size: 000000080000 (512. KB)
Partition: sbl1bak, [00000C082400 - 00000C102400], size: 000000080000 (512. KB)
Partition: aboot, [000010000000 - 000010100000], size: 000000100000 (1.00 MB)
Partition: abootbak, [000010100000 - 000010200000], size: 000000100000 (1.00 MB)
Partition: rpm, [000014000000 - 000014080000], size: 000000080000 (512. KB)
Partition: rpmbak, [000014080000 - 000014100000], size: 000000080000 (512. KB)
Partition: tz, [000014100000 - 000014180000], size: 000000080000 (512. KB)
Partition: tzbak, [000014180000 - 000014200000], size: 000000080000 (512. KB)
Partition: hyp, [000014200000 - 000014280000], size: 000000080000 (512. KB)
Partition: hypbak, [000014280000 - 000014300000], size: 000000080000 (512. KB)
Partition: modemst1, [000014300000 - 000014480000], size: 000000180000 (1.50 MB)
Partition: modemst2, [000014480000 - 000014600000], size: 000000180000 (1.50 MB)
Partition: oppodycnvbk, [000014600000 - 000015000000], size: 000000A00000 (10.0 MB)
Partition: oppostanvbk, [000015000000 - 000015A00000], size: 000000A00000 (10.0 MB)
Partition: LOGO, [000015A00000 - 000016A00000], size: 000001000000 (16.0 MB)
Partition: boot, [000018000000 - 00001A000000], size: 000002000000 (32.0 MB)
Partition: recovery, [00001A000000 - 00001C000000], size: 000002000000 (32.0 MB)
Partition: system, [00001C000000 - 0000CC000000], size: 0000B0000000 (2.75 GB)
Partition: devinfo, [0000CC000000 - 0000CC100000], size: 000000100000 (1.00 MB)
Partition: cache, [0000D0000000 - 0000D8000000], size: 000008000000 (128. MB)
Partition: persist, [0000D8000000 - 0000DA000000], size: 000002000000 (32.0 MB)
Partition: misc, [0000DA000000 - 0000DA100000], size: 000000100000 (1.00 MB)
Partition: keystore, [0000DA100000 - 0000DA180000], size: 000000080000 (512. KB)
Partition: config, [0000DA180000 - 0000DA188000], size: 000000008000 (32.0 KB)
Partition: oem, [0000DA188000 - 0000DE188000], size: 000004000000 (64.0 MB)
Partition: DRIVER, [0000DE188000 - 0000E0188000], size: 000002000000 (32.0 MB)
Partition: reserve1, [0000E0188000 - 0000E0388000], size: 000000200000 (2.00 MB)
Partition: reserve2, [0000E0388000 - 0000E1388000], size: 000001000000 (16.0 MB)
Partition: reserve3, [0000E1388000 - 0000E1588000], size: 000000200000 (2.00 MB)
Partition: reserve4, [0000E1588000 - 0000E2588000], size: 000001000000 (16.0 MB)
Partition: reserve_exp1, [0000E2588000 - 0000E2788000], size: 000000200000 (2.00 MB)
Partition: userdata, [0000E2788000 - 0003AB3FBE00], size: 0002C8C73E00 (11.1 GB)
GPT header successfully parsed
Get firmware version
Brand = OPPO
Manufacturer = OPPO
Model = A37f
Phone platform = msm8916
CPU Abi = arm64-v8a
Android release = 5.1.1
Firmware version = A37fEX_11_171209
Firmware date = Sat Dec  9 16:58:03 CST 2017
HiPower mode is ON
CMD Pullup Level: 1796 mV
Backup saved: Q2J96R_05F3B9E7_20190828_153453.extcsd
Operation: Remove Android Locks
Mount [modem] successfully   PartType: FAT16
Mount [system] successfully   PartType: LINUX
Mount [cache] successfully   PartType: LINUX
Mount [persist] successfully   PartType: LINUX
Mount [config] SKIPPED   PartType: FRP  <<<  FRP !!!
Mount [data] successfully   PartType: LINUX
Delete object: data/system/gesture.key
Delete object: data/system/password.key
Delete object: data/system/locksettings.db
Delete object: data/system/locksettings.db-wal
Delete object: data/system/locksettings.db-shm
All done
Old 09-02-2019, 14:32   #101 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
cph1853 password unlock easily
Z3X EasyJtag Software ver. 3.6.1.9
Box S/N: 0500D01E3BC5A469, ,FW Ver.: 01.63
CMD Pullup Level:2010 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
eMMC CID : 150100514536334D420698DD908AB5E2
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 11/2018  Rev.0x6
eMMC NAME: QE63MB , S/N: 2564657290
eMMC NAME (HEX): 514536334D42
IC Name: Samsung , KMQE60013M-B318/16GB @BGA221
EMMC ROM1 (Main User Data)   Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes
EMMC RPMB is programmed and written 18393 times
Backup saved: QE63MB_2564657290_20190902_1914.extcsd
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x01]:
implementation based on CMD13
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x3f]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x02]
Tag Resources Size [TAG_RES_SIZE: 0x00]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a]
Power off notification [POWER_OFF_LONG_TIME: 0x3c]
Cache Size [CACHE_SIZE] is 65536 KiB
------------------------- eMMC v5+ -------------------------
Supported modes [SUPPORTED_MODES: 0x03]
FFU features [FFU_FEATURES: 0x00]
Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00]
FFU Argument [FFU_ARG: 0xc7810000]
Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0]
Vendor proprietary health report:
[VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00
_(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x01]
 i.e. 0% - 10% device life time used
_(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x01]
Pre EOL information [PRE_EOL_INFO: 0x01]
 i.e. Normal
Optimal read size [OPTIMAL_READ_SIZE: 0x00]
Optimal write size [OPTIMAL_WRITE_SIZE: 0x08]
Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x01]
Device version [DEVICE_VERSION: 0x00 - 0x00]
Firmware version:
[FIRMWARE_VERSION[261]]: 0x00
[FIRMWARE_VERSION[260]]: 0x00
[FIRMWARE_VERSION[259]]: 0x00
[FIRMWARE_VERSION[258]]: 0x00
[FIRMWARE_VERSION[257]]: 0x00
[FIRMWARE_VERSION[256]]: 0x00
[FIRMWARE_VERSION[255]]: 0x00
[FIRMWARE_VERSION[254]]: 0x06
Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00]
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00]
Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00]
Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
 [MIN_PERF_DDR_W_8_52: 0x00]
 [MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x02]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
 Device supports alternative boot method
 Device supports dual data rate during boot
 Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x20]
Access size [ACC_SIZE: 0x07]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x11]
Sector Count [SEC_COUNT: 0x01d1f000]
Minimum Write Performance for 8bit:
 [MIN_PERF_W_8_52: 0x00]
 [MIN_PERF_R_8_52: 0x00]
 [MIN_PERF_W_8_26_4_52: 0x00]
 [MIN_PERF_R_8_26_4_52: 0x00]
Minimum Write Performance for 4bit:
 [MIN_PERF_W_4_26: 0x00]
 [MIN_PERF_R_4_26: 0x00]
Power classes registers:
 [PWR_CL_26_360: 0x00]
 [PWR_CL_52_360: 0x00]
 [PWR_CL_26_195: 0x00]
 [PWR_CL_52_195: 0x00]
Partition switching timing [PARTITION_SWITCH_TIME: 0x02]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a]
I/O Driver Strength [DRIVER_STRENGTH: 0x1f]
Card Type [CARD_TYPE: 0x57]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x38]
 No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x20
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x14
Enable background operations handshake [BKOPS_EN]: 0x02
HPI management [HPI_MGMT]: 0x00
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0003a3
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000
 [GP_SIZE_MULT_3]: 0x000000
 [GP_SIZE_MULT_2]: 0x000000
 [GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
Native sector size [NATIVE_SECTOR_SIZE]: 0x00
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB
Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB
Logical sector size: 0x200  bytes ,First/Last usable sector: 34,30535646
Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB)
Build Description:  S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190624.211613 release-keys
Detected USERDATA USERDATA : 0x015B800000 (9.129GB)
Done.
CMD Pullup Level:2021 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Writing Recovery Command to MISC (33)
Done.
Old 09-08-2019, 09:15   #102 (permalink)
AnonDz's Avatar
Member: 2232889
Thanks Meter: 91
Originally Posted by MOORC View Post
Google have all you need
从我的 iPhone 发送,使用 Tapatalk
but google dont have the vcc and if you found a vcc is wrong
Old 09-10-2019, 00:34   #103 (permalink)
Member: 2185549
Thanks Meter: 535
as far as i knw vcc is voltage collector important but alternatively if uve soldered vccq<to supply these other pins and transistors with voltage > and gnd well u cud use voltage frm usb and selc wither 1.8 or 2.8 on vcc value it should be able towork out
Old 09-10-2019, 09:38   #104 (permalink)
AnonDz's Avatar
Member: 2232889
Thanks Meter: 91
Yes I used usb connection for the vcc thank you but after I connected the phone to medusa the phone stoped and only enter Qualcomm mode and dosent start I did erase the user data I tried to write a full dump and still same I don’t know why I tried different things now I am stuck
Old 09-10-2019, 10:58   #105 (permalink)
Member: 2185549
Thanks Meter: 535
kindly post in medusa section maybe i will find you there but for now we are in easyjtag section
Page generated in 0.35079 seconds with 9 queries
