Old 06-30-2020, 13:30   #196 (permalink)
Member: 455270
Thanks Meter: 3
Oppo
Need pinout Oppo CPH1951 and Realme RMX1993
Old 06-30-2020, 19:36   #197 (permalink)
Member: 2765671
Paano po gagawin kapag yung oppo A5s ayaw mag stay sa com, di rin po dumi diretso sa fastboot screen, tumutukoy po siya sa boot. Di ko naman po ma open and ADB kasi na boot loop. Thank u.
Old 07-02-2020, 16:58   #198 (permalink)
Member: 664247
Thanks Meter: 371
Isp Pinout Oppo A12 CPH2083
Oppo A12 CPH2083 Isp Pinout
The Following 2 Users Say Thank You to himcom For This Useful Post:
Old 07-21-2020, 15:31   #199 (permalink)
Member: 580077
Sonork: 100.1591941
Thanks Meter: 207
realme 5i with code + frp connect error with easy jtag plus software
and with emmc file manager connect ok , frp + code unlock ok
Old 07-21-2020, 16:21   #200 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
I can't see connection errors
I'ts only mount error - it's not a problem
The Following User Says Thank You to layder For This Useful Post:
Old 07-22-2020, 20:14   #201 (permalink)
Member: 311520
Thanks Meter: 6
Oppo (A9 2020) CPH1941 isp pinout Cannot find, please Help Me!
Old 07-28-2020, 05:46   #202 (permalink)
nagesss's Avatar
Member: 2306223
Sonork: 1660968:1234
Thanks Meter: 117
Im not sure but i guess it has ufs chip.not emmc..
Sent from my SM-A305F using Tapatalk
Old 07-28-2020, 05:48   #203 (permalink)
nagesss's Avatar
Member: 2306223
Thanks Meter: 117
Oppo a1k...old easy jtag....pattern.and frp...sucess
The Following 4 Users Say Thank You to nagesss For This Useful Post:
Old 08-13-2020, 08:27   #204 (permalink)
Member: 2496760
i need help with, my oppo PBET00, IS LOCKED WITH PATERN LOCK, I NEED TO REMOVE PLEASE....
Old 08-15-2020, 10:40   #205 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Oppo a3s pattern unlock easy jtag
INFO OR RESET LOG
Z3X EasyJtag Software ver. 3.7.0.17
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63
CMD Pullup Level:2072 mV
CMD Active Level:2392 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 90014A68423861503E03C0893AAFC5E4
eMMC CSD : D02700328F5903FFFFFFFFEF8E400042
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 12/2018  Rev.0x3
eMMC NAME: hB8aP> , S/N: 3230218927
eMMC NAME (HEX): 68423861503E
EMMC ROM1 (Main User Data)   Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
RPMB Info  mmc_switch_part Error, Reason: CARD Ready Timeout Error
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
  Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: hB8aP>_3230218927_20200815_1505.extcsd
The protective MBR's 0xEE partition is oversized! Auto-repairing.
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200  bytes ,First/Last usable sector: 34,61071326
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 219888
Short Android info:
Build ID:  OPM1.171019.026
Release Base ID:  8.1.0
Security Path:  2020-07-05
Architecture ABI:  arm64-v8a
Device manufacturer:  OPPO
Build Description:  msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20200710.012336 release-keys
Backup saved: BuildProp_20200815_1505.txt
Detected USERDATA USERDATA : 0x0158000000 (23.745GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
 BEC4D75B A8E8AAF1 AEFEBDC5 67A8B0CB 401ABF1B FED1097E 7ECB64C9 9B6914AA     ¾Ä×[¨èªñ®þ½Åg¨°Ë@.¿.þÑ    ~~ËdÉ›i.ª;
 2E39263C C6F8027A D711A328 F9319282 4BF23797 7C21829F 55D441D9 799ADBE8     .9&<Æø.z×.£(ù1’‚Kò7—|!‚ŸUÔAÙyšÛè;
 7159ECD1 458C6449 6CEAEFDD CABEA537 7C29ED3B 1EFB881F B21098EB 099CAA7B     qYìÑEŒdIlêïÝʾ¥7|)í;.û..²..ë    œª{;
 794A5481 03CDAC02 C8D9E86F 3022A3B5 0DAC12C3 F31F5378 FFD7B2BA 74AAD4D2     yJT..ͬ.ÈÙèo0"£µ.¬.Ãó.SxÿײºtªÔÒ;
 9067C8FB 7CA230A9 AE357AB0 2E914D77 C31C12FD 3AD89F52 C92D0E5A 600CFF8C     .gÈû|¢0©®5z°.‘MwÃ..ý:ØŸRÉ-.Z`.ÿŒ;
 A98597A3 46C2FBE6 5E6DEDDC BCA7DD1A 9450E5D0 490C806E 9A25FBE2 9861C955     ©…—£FÂûæ^míܼ§Ý.”PåÐI..nš%ûâ.aÉU;
 9B89CDFD DE57E99E 8526BF42 DF257360 0AE3F165 35CC7010 6ED9C6CB 3A7BBF86     ›‰ÍýÞWéž…&¿Bß%s`.ãñe5Ìp.nÙÆË:{¿†;
 E4EAC068 4785725F F2D399C5 03C9BA6E 256E918C 6C3D626F 1A0F5DF9 16469187     äêÀhG…r_òÓ.Å.ɺn%n‘Œl=bo..]ù.F‘‡;
Done.
Running:Format FRP Partition...
CMD Pullup Level:2062 mV
CMD Active Level:2660 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
EMMC ROM1 (Main User Data)   Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0158000000 (23.745GB) , formatting...
Done.
Done.
Done.
The Following User Says Thank You to .::THE ROCK::. For This Useful Post:
Old 08-15-2020, 10:47   #206 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Realme c1 rmx1811 pattern unlock z3x easy jtag emmc tool file manager
Z3X EasyJtag EMMC File Manager v 1.18 TEST at 04/04/2020 Started..
Box API Version: 3308
FS Driver Version: 11062019
SQLite Version: 3.30.1
FSCK Engine Version: 11062019
ESE DB Version: 11062019
System Util Version: 11062019
System: Windows NT 6.2 (Build 9200) / 64 BIT
CPU: Intel(R) Core(TM) i3-6006U CPU @ 2.00GHz
!!FOR BETA-TESTERS ONLY!!
Z3X Card Serial: AA098EDB
EasyJtag Box v1 Found at: COM94
EasyJtag Box Firmware: 1.63
Source: EasyJtag Port [EMMC/SD/MMC]
Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
Box Voltage set to: 3300 mV
Scanner Thread Created..
Config: 100111111110111
Setup HiPower CLK: OFF
Disable HS Timing: TRUE
Connecting To EasyJtag Box: 3300mV/21MHz/1BIT
EasyJtag Box Found! Result: 0/OK
CMD Pullup Level: 2041 mV
CMD Active Level: 2516 mV
EasyJtag S/N: 0707031F7AA05FBD
EasyJtag Box FirmWare: 1.63
Box Bus Width = 1 BIT
Box Hardware = EasyJtag 1st Generation
Search EMMC Chip...
EMMC Chip Found! 0/OK
EMMC CID: 150100514536334D42034E9CD07A55B0
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC VENDOR: SAMSUNG
EMMC NAME: QE63MB
EMMC SERIAL: 4E9CD07A
EMMC REVISION: 03
EMMC ROM1 Size: 30535680 Block(s)/14910 MB
EMMC ROM2/3 Size: 8192 Block(s)/4096 KB
EMMC RPMB Size: 8192 Block(s)/4096 KB
EMMC RPMB Counter: 104076
EMMC RPMB Answer: 0/OK
Switch To ROM1 Part: 0/OK
EMMC REV: 1.8 (for MMC v5.1)
EMMC VER: MMC 5.1
EMMC DEV Life Time: 0x01 -> Normal
EMMC MLC Life Time: 0x03 -> 20% - 30% Life Time Used
EMMC SLC Life Time: 0x03 -> 20% - 30% Life Time Used
EMMC Boot Config: 0x38/0x00/0x01
ExtCSD Automatically Saved..
Scanning Data From EMMC. Please wait..
Scanning GUID Partition Table from ROM1
GUID Partition Table is Found. Max Parts: 64
GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB
GPT: OPPODYCNVBK [000000005000 - 000000A00000] Size: 10.00 MB
GPT: OPPOSTANVBK [000000A05000 - 000000A00000] Size: 10.00 MB
GPT: MODEMST1 [000001405000 - 000000180000] Size: 1.50 MB
GPT: MODEMST2 [000001585000 - 000000180000] Size: 1.50 MB
GPT: PERSIST [000001705000 - 000002000000] Size: 32.00 MB
GPT: OPPORESERVE1 [000003705000 - 000000800000] Size: 8.00 MB
GPT: OPPORESERVE2 [000003F05000 - 000004000000] Size: 64.00 MB
GPT: FSC [000007F05000 - 000000000400] Size: 1.00 KB
GPT: SSD [000007F06000 - 000000002000] Size: 8.00 KB
GPT: SBL1 [000007F08000 - 000000080000] Size: 512.00 KB
GPT: RPM [000007F88000 - 000000080000] Size: 512.00 KB
GPT: TZ [000008008000 - 000000200000] Size: 2.00 MB
GPT: DEVCFG [000008208000 - 000000040000] Size: 256.00 KB
GPT: SBL1BAK [000008248000 - 000000080000] Size: 512.00 KB
GPT: RPMBAK [0000082C8000 - 000000080000] Size: 512.00 KB
GPT: TZBAK [000008348000 - 000000200000] Size: 2.00 MB
GPT: DEVCFGBAK [000008548000 - 000000040000] Size: 256.00 KB
GPT: DSP [000008588000 - 000001000000] Size: 16.00 MB
GPT: DDR [000009800000 - 000000008000] Size: 32.00 KB
GPT: FSG [000009808000 - 000000400000] Size: 4.00 MB
GPT: SEC [000009C08000 - 000000004000] Size: 16.00 KB
GPT: ABOOT [000009C0C000 - 000000100000] Size: 1.00 MB
GPT: ABOOTBAK [000009D0C000 - 000000100000] Size: 1.00 MB
GPT: MODEM [000009E0C000 - 000008000000] Size: 128.00 MB
GPT: DTBO [000011E0C000 - 000000800000] Size: 8.00 MB
GPT: VBMETA [00001260C000 - 000000010000] Size: 64.00 KB
GPT: BOOT [00001261C000 - 000004000000] Size: 64.00 MB
GPT: RECOVERY [00001661C000 - 000004000000] Size: 64.00 MB
GPT: DEVINFO [00001A61C000 - 000000100000] Size: 1.00 MB
GPT: SPLASH [00001A800000 - 000000B00000] Size: 11.00 MB
GPT: LOGO [00001B300000 - 000002000000] Size: 32.00 MB
GPT: DRIVER [00001D300000 - 000002000000] Size: 32.00 MB
GPT: CACHE [00001F300000 - 000010000000] Size: 256.00 MB
GPT: MISC [00002F300000 - 000000100000] Size: 1.00 MB
GPT: KEYSTORE [00002F400000 - 000000080000] Size: 512.00 KB
GPT: CONFIG [00002F480000 - 000000008000] Size: 32.00 KB
GPT: LOG [00002F488000 - 000004000000] Size: 64.00 MB
GPT: OEM [000033488000 - 000000100000] Size: 1.00 MB
GPT: LIMITS [000033800000 - 000000008000] Size: 32.00 KB
GPT: MOTA [000034000000 - 000000080000] Size: 512.00 KB
GPT: DIP [000034080000 - 000000100000] Size: 1.00 MB
GPT: MDTP [000034180000 - 000002000000] Size: 32.00 MB
GPT: SYSCFG [000036180000 - 000000080000] Size: 512.00 KB
GPT: MCFG [000036200000 - 000000400000] Size: 4.00 MB
GPT: LKSECAPP [000036800000 - 000000020000] Size: 128.00 KB
GPT: CMNLIB [000036820000 - 000000100000] Size: 1.00 MB
GPT: CMNLIB64 [000036920000 - 000000100000] Size: 1.00 MB
GPT: KEYMASTER [000036A20000 - 000000100000] Size: 1.00 MB
GPT: LKSECAPPBAK [000036B20000 - 000000020000] Size: 128.00 KB
GPT: CMNLIBBAK [000036B40000 - 000000100000] Size: 1.00 MB
GPT: CMNLIB64BAK [000036C40000 - 000000100000] Size: 1.00 MB
GPT: KEYMASTERBAK [000036D40000 - 000000100000] Size: 1.00 MB
GPT: APDP [000037000000 - 000000040000] Size: 256.00 KB
GPT: MSADP [000037040000 - 000000040000] Size: 256.00 KB
GPT: DPO [000037080000 - 000000002000] Size: 8.00 KB
GPT: LOGDUMP [000037082000 - 000004000000] Size: 64.00 MB
GPT: VM-KYSTORE [00003B082000 - 000000100000] Size: 1.00 MB
GPT: VM-DATA [00003B182000 - 000000A00000] Size: 10.00 MB
GPT: HYP [00003C000000 - 000000800000] Size: 8.00 MB
GPT: VM-SYSTEM [00003C800000 - 000004000000] Size: 64.00 MB
GPT: VM-LINUX [000040800000 - 000002000000] Size: 32.00 MB
GPT: SYSTEM [000042800000 - 0000D6900000] Size: 3.35 GB
GPT: VENDOR [000119100000 - 000041F60000] Size: 1.03 GB
GPT: USERDATA [00015B800000 - 0002485FBE00] Size: 9.13 GB
GPT: BACKUP_GPT [0003A3DFBE00 - 000000004200] Size: 16.50 KB
Reading Table Completed
Scanning GUID Partition Table from ROM2
GPT Signature Not Found. Break..
Scanning GUID Partition Table from ROM3
GUID Partition Table is Found. Max Parts: 4
GPT: CDT [000000004400 - 000000000800] Size: 2.00 KB
GPT: LAST_GROW [000000004C00 - 0000003F7200] Size: 3.97 MB
GPT Backup Header Not Found
Partition #9 mount as [/mnt/vendor/persist] -> 32.00 MB
Partition #11 mount as [/mnt/vendor/opporeserve] -> 64.00 MB
Partition #22 mount as [/dev_22] -> 16.00 MB
Partition #28 mount as [/MODEM] -> 128.00 MB
Partition #37 mount as [/cache] -> 256.00 MB
Partition #41 mount as [/LOG] -> 64.00 MB
Partition #66 mount as [/dev_66] -> 3.35 GB
Partition #67 mount as [/dev_67] -> 1.03 GB
Warning! Partition #68 -> 'USERDATA' is ENCRYPTED!
EmptyCheck:
EMPTY -> #23 - [FSG]
EMPTY -> #33 - [SPLASH]
EMPTY -> #37 - [MISC]
EMPTY -> #38 - [KEYSTORE]
EMPTY -> #41 - [OEM]
EMPTY -> #42 - [LIMITS]
EMPTY -> #43 - [MOTA]
EMPTY -> #44 - [DIP]
EMPTY -> #46 - [SYSCFG]
EMPTY -> #47 - [MCFG]
EMPTY -> #57 - [MSADP]
EMPTY -> #58 - [DPO]
EMPTY -> #59 - [LOGDUMP]
EMPTY -> #60 - [VM-KYSTORE]
EMPTY -> #61 - [VM-DATA]
EMPTY -> #62 - [HYP]
EMPTY -> #63 - [VM-SYSTEM]
EMPTY -> #64 - [VM-LINUX]
EmptyCheck: Done
Warning! Device Blocked by FRP
For Reset FRP Try to Tools Tab
Press Reset FRP Button
Partition #40 -> CONFIG
Android Info:
Vendor = OPPO
CPU ABI = arm64-v8a
Android Version = 9
Android Info:
Brand = OPPO
Device = RMX1805
Model = RMX1805
Product = RMX1805
Firm Version = RMX1805EX_11_A.61
Inc. Version = 1569323573
Firm Date = Tue Sep 24 19:12:53 CST 2019
Security Patch = 2019-10-05
OPPO Name = realme 2
Android Info:
Platform = msm8953
Scanner Thread Terminated
Elapsed: 00:00:14:172
Found 72 Partition(s)..
Scan Done. Init Main Engine...
Resetting EasyJtag Box. Wait..
CMD Active Level: 3042 mV
Reader Engine Initialized.. 0/OK
Operation Done: [Init Engine], Elapsed: 00:00:02:150
Universal Wipe User Data v1.0
Wiping MISC Partition..
Partition #38 is '/MISC'. Erasing..
Wipe Mode: Oppo/Vivo Factory Reset
Wipe 'MISC' Partition Done..
Wiping PARA Partition..
Partition PARA Not Found. Skip..
Done Wiping Data..
Elapsed Time: [00:00:00:056]
Operation Done: [Universal Wipe Data], Elapsed: 00:00:00:065
Done Wiping Data..
Elapsed Time: [00:00:00:051]
Operation Done: [Universal Wipe Data], Elapsed: 00:00:00:054
Old 08-15-2020, 16:46   #207 (permalink)
joseck's Avatar
Member: 648607
Sonork: 100.1638674
Thanks Meter: 23
OPPO A1K only show mtak port after wipe user data...cmd/clk/data0 all clean ..please help me recover
Old 08-15-2020, 23:45   #208 (permalink)
Member: 151887
Thanks Meter: 28
Put a jump on clk
Old 08-17-2020, 06:51   #209 (permalink)
joseck's Avatar
Member: 648607
Sonork: 100.1638674
Thanks Meter: 23
oppo a1k after WIPE USE DATA only MediaTek USB port in device manager...please help me to recover set
Old 08-17-2020, 07:32   #210 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
check hardware - CMD/CLK resistors
Page generated in 0.47288 seconds with 9 queries
