Old 01-28-2014, 11:41   #211 (permalink)
Member: 762819
Thanks Meter: 232
I9070 Galaxy Advance Repaired successfully with Easy Jtag.
Connecting to Target...
U8500 USB BOOTROM : device 04CC:8500 opened
success: set configuration #1
success: claim_interface #0
Sending XLOADER...
success: bulk read 4 bytes
Done.
JTAG device: U8500
CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4
CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9
JTAG device: U8500
CPU IDCODE : 0x62286041 Mfg.: 0x020, Part: 0x2286, Ver.: 0x6
CPU Manufacturer: SGS/Thomson , CPU Name: NOVATHOR U8500 JRC
Halting CPU...
Initialize hardware...
Starting target communication...
Detecting emmc memory parameters of bank (0) ...
EMMC #0 : ID : 0x00000045 Name : SEM08G Size : 7.3 G , (15269888) Blocks
EMMC #1 : ID : 0x00000045 Name : SEM08G Size : 2.0 M , (4096) Blocks
eMMC flash device(s) found, Device ID : 0x00450000
EMMC Writing GPT...
eMMC Write OK! Elapsed time: 1.015625s (126.031 KiB/s)
EMMC Writing XLOADER...
eMMC Write OK! Elapsed time: 3.781250s (101.554 KiB/s)
EMMC Writing PIT...
eMMC Write OK! Elapsed time: 4.078125s (251.096 KiB/s)
EMMC Writing STE MEM INIT...
eMMC Write OK! Elapsed time: 2.921875s (175.230 KiB/s)
EMMC Writing PWR MGT...
eMMC Write OK! Elapsed time: 3.187500s (160.627 KiB/s)
EMMC Writing SBL...
eMMC Write OK! Elapsed time: 13.609375s (150.484 KiB/s)
EMMC Writing SBL2...
eMMC Write OK! Elapsed time: 14.562500s (140.635 KiB/s)
EMMC Writing PARAM...
eMMC Write OK! Elapsed time: 11.375000s (90.022 KiB/s)
EMMC Writing IPL MODEM...
eMMC Write OK! Elapsed time: 10.953125s (186.979 KiB/s)
All Done.
Old 01-28-2014, 18:50   #212 (permalink)
Saulcell's Avatar
Member: 278939
Sonork: 100.1593095
Thanks Meter: 382
Repair Dead Boot Note 2 N7100 Done
EasyJtag Suite ver.: 1.0.99.0 started.
Operating system ver.: Windows 7 (build 7600).
Successefuly connected to box on COM17
Box S/N: xxxxxxxxxxxxxxx, ,FW Ver.: 01.48
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : xxxx-xxxx , ver: 22
Successfully connected to box on COM17
Box S/N: 0E0E0F14F3059C50, ,FW Ver.: 01.48
Loading eMMC Addon Firmware...
CMD Pullup Level:1268 mV
CMD Active Level:1845 mV
EMMC CID 15010056545530304DF7CF25434C1141
EMMC CSD D02701320F5903FFF6DBFFFF8E40406D
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 01/1998 FW rev.0xf7
EMMC NAME: VTU00M , S/N: 3475325772
EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card)
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Backup saved: VTU00M_3475325772_20140006_1256.extcsd
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Done.
Running:SAMSUNG: Smart Factory Reset + Format...
Sending Smart Wipe Request...
Wiping Card... Please do not touch it!!!
Done.
Writing file...E:\JtagBox\Easy JTAG\Samsung\N7100\N7100_Rom2_Alive_Boot_BN.bin
CMD Pullup Level:1278 mV
CMD Active Level:1835 mV
Writing 000000100000 bytes to 00000000 ...ROM2
Write Speed: 161 kB/s
Done !!!
Writing file...E:\JtagBox\Easy JTAG\Samsung\N7100\N7100_Rom1_Alive_Dump_BN.bin
Writing 000020000000 bytes to 00000000 ...ROM1
Write Speed: 200 kB/s
Done !!!
The Following 2 Users Say Thank You to Saulcell For This Useful Post:
Old 02-04-2014, 15:25   #213 (permalink)
DUNIYA JAMAL's Avatar
Member: 192810
Sonork: Some people NEED change
Thanks Meter: 860
Samsung I9003 Dead boot Repair Done by Easy-Jtag
Old 02-05-2014, 07:00   #214 (permalink)
Member: 2100788
Thanks Meter: 5
Samsung b229 blinking solution done 100 percent box r very good
Old 02-05-2014, 12:40   #215 (permalink)
Member: 762819
Thanks Meter: 232
E160S (Same as Note N7000) was successfully repaired via Easy Jtag.
Sorry lost the logs.
thanks to Easy Jtag.
Old 02-06-2014, 08:29   #216 (permalink)
Member: 762819
Thanks Meter: 232
I9100G was successfully Repaired via Easy Jtag.
Operating system ver.: Windows XP (build 2600, Service Pack 3).
For support and updates visit EasyJtag , just better ? - New powerful JTAG unbrick device.
Initialising: SAMSUNG GT-I9100G Config ver.:1.00
I/O Level set to : 2600 mV
Box S/N: ***************** ,FW Ver.: 01.48
JTAG device: OMAP4430
CPU IDCODE : 0x3BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x3
CPU IDCODE : 0x6B95C02F Mfg.: 0x017, Part: 0xb95c, Ver.: 0x6
Halting CPU...
EMMC #0 : ID : 0x00150100 Name : M00LYV Size : 14.7 G , (30777344) Blocks
EMMC #1 : ID : 0x00150100 Name : M00LYV Size : 512.0 K , (1024) Blocks
eMMC flash device(s) found, Device ID : 0x00000015
EMMC Writing SBL1...
eMMC Write OK! Elapsed time: 121.750000s (16.821 KiB/s)
eMMC Write OK! Elapsed time: 126.328125s (16.212 KiB/s)
eMMC Write OK! Elapsed time: 467.781250s (17.512 KiB/s)
All Done.
Old 02-07-2014, 00:16   #217 (permalink)
Saulcell's Avatar
Member: 278939
Sonork: 100.1593095
Thanks Meter: 382
Repair Dead Boot Samsung GT-S5260 Done
Old 02-08-2014, 14:01   #218 (permalink)
Member: 1334781
Sonork: 0010
Thanks Meter: 80
HTC Sensation Z710e
Dead boot repair done
For support and updates visit <a href="http://easy-jtag.com">http://easy-jtag.com</a><br>Initialising: HTC Z710e Sensation (PG58130) Config ver.:1.00
I/O Level set to : 2200 mV
Box S/N: 18180B0EDFE53846 ,FW Ver.: 01.48
Warn: JTAG device: MSM8260.
CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4
Warn: CPU Manufacturer: Samsung , CPU Name: ARM7GEN
CPU IDCODE : 0x104210E1 Mfg.: 0x070, Part: 0x0421, Ver.: 0x1
Warn: CPU Manufacturer: QUALCOMM , CPU Name: MSM8260
Halting CPU...
Warn: Detecting emmc memory parameters of bank (0) ...
EMMC #0 : ID : 0x00000015 Name : MLL00M Size : 2.3 G , (4718592) Blocks
EMMC #1 : ID : 0x00000000 Name : MLL00M Size : 512.0 K , (1024) Blocks
Error: eMMC flash device(s) found, Device ID : 0x00150000
NAND Writing MBR...
Warn: eMMC Write OK! Elapsed time: 0.031250s (16.000 KiB/s)
NAND Writing SBL1...
Warn: eMMC Write OK! Elapsed time: 1.796875s (71.235 KiB/s)
NAND Writing SBL2...
Warn: eMMC Write OK! Elapsed time: 3.203125s (79.922 KiB/s)
NAND Writing ID...
Warn: eMMC Write OK! Elapsed time: 0.203125s (78.769 KiB/s)
NAND Writing WLAN...
Warn: eMMC Write OK! Elapsed time: 2.437500s (105.026 KiB/s)
NAND Writing SBL3...
Warn: eMMC Write OK! Elapsed time: 13.859375s (73.885 KiB/s)
NAND Writing RPM...
Warn: eMMC Write OK! Elapsed time: 3.109375s (82.332 KiB/s)
NAND Writing TZ...
Warn: eMMC Write OK! Elapsed time: 19.484375s (105.110 KiB/s)
NAND Writing HBOOT...
Warn: eMMC Write OK! Elapsed time: 16.140625s (63.442 KiB/s)
NAND Writing SPLASH1...
Warn: eMMC Write OK! Elapsed time: 64.078125s (95.883 KiB/s)
NAND Writing MISC...
Warn: eMMC Write OK! Elapsed time: 2.328125s (109.960 KiB/s)
NAND Writing HTC...
Warn: eMMC Write OK! Elapsed time: 74.500000s (109.940 KiB/s)
NAND Writing BOOT...
Warn: eMMC Write OK! Elapsed time: 180.718750s (90.660 KiB/s)
NAND Writing RECOVERY...
Error: Packet length too large: 0xFFFFFFFF
Error: Unknown DCC answer /PROTOCOL/
Warn: Failed writing file RECOVERY.BIN to eMMC flash 0 at offset 0x09660400
All Done.
Old 02-10-2014, 11:31   #219 (permalink)
Member: 762819
Thanks Meter: 232
I9000 EFS file done
Easy-Repair file load OK!
Using EasyRepair Mode...
Checking repair data...
EasyJtag Suite ver.: 1.0.101.0 started.
Initialising: SAMSUNG GT-I9000 Config ver.:1.00
I/O Level set to : 2800 mV
Box S/N: 16160A1FA8BA9BC5 ,FW Ver.: 01.48
JTAG device: S5PC110
CPU IDCODE : 0x1BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x1
CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A8
Halting CPU...
Detecting nand memory parameters ...
NAND flash device ID:00EC:0050 'NAND 512MB 1.8V 16-bit (Samsung)' found
NAND geometry: Blocks:00000800, Page size:1024 bytes , Block size:256 pages
NAND Writing EFS...
NAND Write OK! Elapsed time: 18.546875s (569.368 KiB/s)
All Done.
Old 02-11-2014, 08:50   #220 (permalink)
naushad09's Avatar
Member: 216094
Thanks Meter: 321
S7562 done
Initialising: Samsung GT-S7562 Config ver.:1.01
Box S/N: xxxxxxxxxxxx ,FW Ver.: 01.48
JTAG device: MSM7225A
CPU IDCODE : 0x106230E1 Mfg.: 0x070, Part: 0x0623, Ver.: 0x1
CPU Manufacturer: QUALCOMM , CPU Name: MSM7227A
Halting CPU...
EMMC #0 : ID : 0x01000015 Name : JJS00A Size : 3.6 G , (7634944) Blocks
EMMC #1 : ID : 0x01000015 Name : JJS00A Size : 1.0 M , (2048) Blocks
NAND Writing QCSBL...
eMMC Write OK! Elapsed time: 3.703125s (69.131 KiB/s)
NAND Writing MODEM...
eMMC Write OK! Elapsed time: 321.281250s (63.745 KiB/s)
NAND Writing PRT5...
eMMC Write OK! Elapsed time: 33.140625s (118.450 KiB/s)
NAND Writing OEMSBL...
eMMC Write OK! Elapsed time: 11.812500s (81.270 KiB/s)
NAND Writing APPSBL...
eMMC Write OK! Elapsed time: 11.500000s (83.478 KiB/s)
NAND Writing PIT...
eMMC Write OK! Elapsed time: 4.328125s (118.296 KiB/s)
NAND Writing MD5...
eMMC Write OK! Elapsed time: 17.078125s (119.919 KiB/s)
All Done.
Old 02-14-2014, 20:33   #221 (permalink)
sikandar.mehdi's Avatar
Member: 2080403
Sonork: 100.1645596
Thanks Meter: 52
I9070 Dead don by easy jtag
Successefuly connected to box on COM7
Box S/N: 131xxxxxxxxx, ,FW Ver.: 01.48
Z3X Card Serial : AAAD-30FF , ver: 22
Loading repair file: 'D:\Box Installer\Z3X\9. Easy Jtag files\Samsung\GT-I9070\Repair\Samsung GT-i9070_v1.01.rcp'
Repair File ver. : Easy Repair for Mfg: SAMSUNG Model: GT-I9070, Ver.: 1.01
Error loading information!
Initialising: SAMSUNG GT-I9070 Config ver.:1.01
Box S/N: 131xxxxxxxxxx ,FW Ver.: 01.48
Sending XLOADER...
Done.
JTAG device: U8500
JTAG device: U8500
Halting CPU...
EMMC Writing GPT...
eMMC Write OK! Elapsed time: 0.624001s (205.128 KiB/s)
eMMC Write OK! Elapsed time: 6.723612s (57.112 KiB/s)
EMMC Writing PIT...
eMMC Write OK! Elapsed time: 15.007226s (68.234 KiB/s)
eMMC Write OK! Elapsed time: 5.850010s (87.521 KiB/s)
eMMC Write OK! Elapsed time: 8.502015s (60.221 KiB/s)
EMMC Writing SBL...
eMMC Write OK! Elapsed time: 36.379265s (56.296 KiB/s)
eMMC Write OK! Elapsed time: 35.958065s (56.955 KiB/s)
eMMC Write OK! Elapsed time: 25.958445s (39.448 KiB/s)
eMMC Write OK! Elapsed time: 25.662045s (79.807 KiB/s)
All Done.
The Following User Says Thank You to sikandar.mehdi For This Useful Post:
Old 02-14-2014, 23:13   #222 (permalink)
Member: 1616463
Sonork: 100.1660594
Thanks Meter: 247
Wink S4 I9505 Successfully Boot Repair Done By Easy Jtag
Operating system ver.: Windows 7 (build 7601, Service Pack 1).
Successefuly connected to box on COM10
Box S/N: 0505040F9C1C2CBB, ,FW Ver.: 01.48
Z3X Card Serial : AAFD-8077 , ver: 22
Loading repair file: 'J:\Mobile\Box file\EASY JTAG\Repair\I9505\Repair boot\Samsung GT-i9505_XXUEMKF_BOOT_V1.03.rcp'
Repair File ver. : Easy Repair for Mfg: SAMSUNG Model: GT-I9505, Ver.: 1.00
Repair file options. : NONE
For support and updates visit http://easy-jtag.com
Initialising: SAMSUNG GT-I9505 Config ver.:1.00
Box S/N: 0505040F9C1C2CBB ,FW Ver.: 01.48
JTAG device: APQ8064T.
CPU IDCODE : 0x2071B0E1 Mfg.: 0x070, Part: 0x071b, Ver.: 0x2
CPU Manufacturer: QUALCOMM , CPU Name: APQ8064T
Halting CPU...
EMMC #0 : ID : 0x00000015 Name : AFEABB Size : 14.7 G , (30777344) Blocks
EMMC #1 : ID : 0x00000015 Name : AFEABB Size : 4.0 M , (8192) Blocks
NAND Writing PGPT, PIT, MD5, P4...
eMMC Write OK! Elapsed time: 31.144781s (131.515 KiB/s)
eMMC Write OK! Elapsed time: 1.225070s (104.484 KiB/s)
eMMC Write OK! Elapsed time: 2.891165s (88.546 KiB/s)
eMMC Write OK! Elapsed time: 5.981342s (85.600 KiB/s)
NAND Writing ABOOT...
eMMC Write OK! Elapsed time: 15.105864s (84.735 KiB/s)
NAND Writing RPM...
eMMC Write OK! Elapsed time: 1.753100s (109.520 KiB/s)
NAND Writing TZ...
eMMC Write OK! Elapsed time: 2.418139s (105.867 KiB/s)
NAND Writing SGPT...
eMMC Write OK! Elapsed time: 0.098006s (168.357 KiB/s)
All Done.
By Easy Jtag
The Following User Says Thank You to meshkat_azizi For This Useful Post:
Old 02-16-2014, 09:08   #223 (permalink)
Member: 921094
Sonork: 100.1603246
Thanks Meter: 326
My first success story with easy jtag
I 9070 DEAD BOOT REPAIR DONE
Box S/N: ,FW Ver.: 01.48
Sending XLOADER...
Done.
JTAG device: U8500
JTAG device: U8500
Halting CPU...
EMMC Writing GPT...
eMMC Write OK! Elapsed time: 0.347020s (368.855 KiB/s)
eMMC Write OK! Elapsed time: 2.567147s (149.582 KiB/s)
EMMC Writing PIT...
eMMC Write OK! Elapsed time: 4.506258s (227.240 KiB/s)
eMMC Write OK! Elapsed time: 1.905109s (268.751 KiB/s)
eMMC Write OK! Elapsed time: 2.715156s (188.571 KiB/s)
EMMC Writing SBL...
eMMC Write OK! Elapsed time: 12.996743s (157.578 KiB/s)
eMMC Write OK! Elapsed time: 13.108749s (156.232 KiB/s)
eMMC Write OK! Elapsed time: 10.457598s (97.919 KiB/s)
eMMC Write OK! Elapsed time: 8.585491s (238.542 KiB/s)
All Done.
The Following User Says Thank You to naseer_mansehra For This Useful Post:
Old 02-17-2014, 09:46   #224 (permalink)
Member: 1856544
Sonork: 100.1606364
Thanks Meter: 23
pls help easy jtag team
s7562 ace duos deadboot,after revive in easy jag phone turn samsung logo only..
ill try to hard reset by press volume down,volume up,home,power on but no response
when entering to download mode i see,CUSTOM BINARY DOWNLOAD:YES(1 COUNTS)
SYSTEM STATUS:CUSTOM
The Following User Says Thank You to chance^09 For This Useful Post:
Old 02-18-2014, 19:58   #225 (permalink)
Member: 2080403
Sonork: 100.1645596
Thanks Meter: 52
Samsung i9070 Dead Boot Rapair Done By Easy Jtag
Box S/N: 131xxxxxxxxxxx2, ,FW Ver.: 01.48
Box S/N: 131304xxxxxxxxxxxx ,FW Ver.: 01.48
Sending XLOADER...
Done.
JTAG device: U8500
JTAG device: U8500
Halting CPU...
EMMC Writing GPT...
eMMC Write OK! Elapsed time: 1.749100s (73.180 KiB/s)
eMMC Write OK! Elapsed time: 7.137409s (53.801 KiB/s)
EMMC Writing PIT...
eMMC Write OK! Elapsed time: 15.330876s (66.793 KiB/s)
eMMC Write OK! Elapsed time: 5.793331s (88.377 KiB/s)
eMMC Write OK! Elapsed time: 8.616493s (59.421 KiB/s)
EMMC Writing SBL...
eMMC Write OK! Elapsed time: 29.962713s (68.352 KiB/s)
eMMC Write OK! Elapsed time: 31.758816s (64.486 KiB/s)
eMMC Write OK! Elapsed time: 19.053089s (53.745 KiB/s)
eMMC Write OK! Elapsed time: 24.735415s (82.796 KiB/s)
All Done.
Page generated in 0.14838 seconds with 9 queries
