Old 02-03-2020, 07:14   #706 (permalink)
ssunil710@gmail's Avatar
Member: 2630154
Sonork: 1681209
Thanks Meter: 112
OPPO A37 Dead Shorting Over Tempure By Other Technician
Emmc Reprogram By Easy-Jtag
Handset Successfully Recover Done
The Following 2 Users Say Thank You to ssunil710@gmail For This Useful Post:
Old 02-07-2020, 16:06   #707 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Oppo a3s pattern & frp done easy jtag
OPPO A3S PATTERN & FRP DONE
EASY JTAG
The Following User Says Thank You to .::THE ROCK::. For This Useful Post:
Old 02-11-2020, 10:48   #708 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Z3X EasyJtag Software ver. 3.6.2.1
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63
CMD Pullup Level:2041 mV
CMD Active Level:3042 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 150100514536334D42039587F0F3455E
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 04/2018  Rev.0x3
eMMC NAME: QE63MB , S/N: 2508714227
eMMC NAME (HEX): 514536334D42
IC Name: Samsung , KMQE60013M-B318/16GB @BGA221
EMMC ROM1 (Main User Data)   Capacity: 14910 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 35158 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
  Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE63MB_2508714227_20200211_1449.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB
Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200  bytes ,First/Last usable sector: 34,30535646
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Backup saved: BuildProp_20200211_1449.txt
Build ID:  OPM1.171019.026
Release Base ID:  8.1.0
Security Path:  2019-12-05
Architecture ABI:  arm64-v8a
Device manufacturer:  OPPO
Build Description:  msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20191128.013212 release-keys
Detected USERDATA USERDATA : 0x0158000000 (9.184GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
 B79D3F21 94B8B5F7 190B0287 67AA59B6 95DA4721 2BFD44DC 2FEA78C6 702D306D     ·.?!”¸µ÷...‡gªY¶•ÚG!+ýDÜ/êxÆp-0m;
 9812DC2F BEC87D4A 3C8E4068 99B16521 62F598E7 36AFBE01 982DA835 3F8AEF9E     ..Ü/¾È}J<Ž@h.±e!bõ.ç6¯¾..-¨5?Šïž;
 8E5333A5 CFAE7A58 379C5B59 AD7BE204 B6C4BCE2 CDF45C29 4524E72D DCBB515F     ŽS3¥Ï®zX7œ[Y*{â.¶Ä¼âÍô\)E$ç-Ü»Q_;
 6091FCD5 2E70C3B9 39052306 052696F6 1CE8EA42 378F32CD 09CF9E47 81A70963     `‘üÕ.pù9.#..&–ö.èêB7.2Í    ÏžG.§    c;
 7C509A71 0DF0EA57 9760BD0F 0A35CFE8 74588CBE A056D056 3659D8E7 5C5D17C3     |Pšq.ðêW—`½..5ÏètXŒ¾ VÐV6YØç\].Ã;
 96400D86 6AE4CA50 AFC4CA5C 856ABC9C C1A13A0E B72700F6 F4C69947 F01F554C     –@.†jäÊP¯ÄÊ\…j¼œÁ¡:.·'.öôÆ.Gð.UL;
 C84467DB 14D42259 854700FE 166795B9 115A5B4E 0B08F37A BF11A864 82F42AF0     ÈDgÛ.Ô"Y…G.þ.g•¹.Z[N..óz¿.¨d‚ô*ð;
 F791BB72 765B7642 EAB29D26 74F814AF D91323C5 83EFFF73 485BAEB0 AB226B98     ÷‘»rv[vBê².&tø.¯Ù.#ŃïÿsH[®°«"k.;
Done.
Running:Format FRP Partition...
CMD Active Level:3083 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
EMMC ROM1 (Main User Data)   Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) , formatting...
Done.
Done.
Done.
NO CUTTING SHIELD
The Following 2 Users Say Thank You to .::THE ROCK::. For This Useful Post:
Old 02-16-2020, 15:06   #709 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Oppo a3s pattern/pass unlock no data loss 2 handset done easy jtag
DETECT INFO
Z3X EasyJtag Software ver. 3.6.2.3
CMD Pullup Level:2010 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
eMMC CID : 150100514536334D420372A8A8F575CE
eMMC Date: 07/2018  Rev.0x3
eMMC NAME: QE63MB , S/N: 1923655925
EMMC RPMB is programmed and written 68199 times
Backup saved: QE63MB_1923655925_20200216_1816.extcsd
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Security Path:  2018-11-05
Build Description:  msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20181103.202305 release-keys
Backup saved: BuildProp_20200216_1816.txt
 A9601F1A E964DD4A 203490CD 7D954AC2 089ABFA4 66E862A7 94E711BD 82DB4836     ©`..édÝJ 4.Í}•JÂ.š¿¤fèb§”ç.½‚ÛH6;
 25380C40 BB4029C0 D69FEC50 591D0F2D C08F2796 6315557D 5A2B681A CE743902     %8.@»@)ÀÖŸìPY..-À.'–c.U}Z+h.Ît9.;
 36F4A922 408FBADC 843C6232 557DF0AB 7FCE03C8 289BD5C6 F4AD67DA 2B1DDA36     6ô©"@.ºÜ„<b2U}ð«.Î.È(›ÕÆô*gÚ+.Ú6;
 1E6937E5 FC5BDBBC 04119EBB 4770C9EE 32BFA65E 08B35BBB 92F53552 3BBF86BE     .i7åü[Û¼..ž»GpÉî2¿¦^.³[»’õ5R;¿†¾;
 446B886D D0A10067 1759F517 C15C7758 F08573E8 6DFF9641 1F113B38 7A097387     Dk.mС.g.Yõ.Á\wXð…sèmÿ–A..;8z    s‡;
 69A8A06D D6490740 EFF90384 AD21C93C EA326B6B 8F510BF8 9A24BF39 F5C6E1E3     i¨ mÖI.@ïù.„*!É<ê2kk.Q.øš$¿9õÆáã;
 EE1AF430 B3982FE9 4A0E846C D364590A A3D75279 938BFF1F F68B6F8E 4E0C8AFF     î.ô0³./éJ.„lÓdY.£×Ry“‹ÿ.ö‹oŽN.Šÿ;
 6A00F2B4 1A49E151 FCE6F5A8 29632157 F81BA502 B3A50CC7 020297FE D872A384     j.ò´.IáQüæõ¨)c!Wø.¥.³¥.Ç..—þØr£„;
Done.
DETECT INFO
Loading eMMC GEN1 Firmware... IO: 2800 mV
CMD Pullup Level:2072 mV
CMD Active Level:2660 mV
Box IO Level:2800 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
eMMC CID : 13014E51334A393756100C16F1A5659C
eMMC CSD : D07F01328F5913FFFFFFFFEF9240009E
eMMC Manufacturer ID: 0013 , OEM ID: 014E
eMMC Date: 06/2018  Rev.0x10
eMMC NAME: Q3J97V , S/N:  202830245
eMMC NAME (HEX): 51334A393756
EMMC ROM1 (Main User Data)   Capacity: 29820 MB
EMMC RPMB is programmed and written 67153 times
Backup saved: Q3J97V_ 202830245_20200216_1841.extcsd
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Logical sector size: 0x200  bytes ,First/Last usable sector: 34,61071326
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Security Path:  2020-01-05
Build Description:  msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20191225.101315 release-keys
Backup saved: BuildProp_20200216_1841.txt
Detected USERDATA USERDATA : 0x0158000000 (23.745GB)
 C7C8A184 C19ED85B C9958D64 B69593F6 838FC494 CEF9332B 1339CA3E A8988D94     ÇÈ¡„ÁžØ[É•.d¶•“öƒ.Ä”Îù3+.9Ê>¨..”;
 C957C604 52D30CBB A6F99746 BFAFA74B 69C4A8BC 88D37BE1 D7721B61 C2073454     ÉWÆ.RÓ.»¦ù—F¿¯§KiĨ¼.Ó{á×r.aÂ.4T;
 AD5DFEE1 2F246DA0 03350481 E3A6CACC 1D3C59CD BEDC1D75 2A370F38 D0A2AA4D     *]þá/$m .5..ã¦ÊÌ.<Y;Ü.u*7.8ТªM;
 167FDF2B B24831AA 970226C9 8B58E88B 289E2BC5 98B58341 0397B228 F416FF6E     ..ß+²H1ª—.&É‹Xè‹(ž+Å.µƒA.—²(ô.ÿn;
 D87BA2B5 B1155F93 E772AA60 5366610B 52CC9C3C E09FB1D8 970242B1 8A11152B     Ø{¢µ±._“çrª`Sfa.RÌœ<àŸ±Ø—.B±Š..+;
 B9BA329F 3DA40190 0F74D5B6 B5CAAAD1 AF15D647 991D4E2D 891760A6 CD4F7A7E     ¹º2Ÿ=¤...tÕ¶µÊªÑ¯.ÖG..N-‰.`¦ÍOz~;
 6B301F24 5F5F31BF 3506AD15 D49BED29 C6FF16B1 461780CA FDC55D5D 1AA96983     k0.$__1¿5.*.Ô›í)Æÿ.±F..ÊýÅ]].©iƒ;
 2A052BBD CDE9810E 2801EAFF 4A3BEF41 B7167FB2 65CA583A 86E60747 288B3FEA     *.+½Íé..(.êÿJ;ïA·..²eÊX:†æ.G(‹?ê;
Done.
Old 02-17-2020, 08:19   #710 (permalink)
Member: 50772
Sonork: 100.1590990
Thanks Meter: 320
Originally Posted by .::THE ROCK::. View Post
DETECT INFO
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Done.
DETECT INFO
CLK Rate:14000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Done.
which option use without data loss
Old 02-17-2020, 13:07   #711 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
reset oppo > safe only media file
Old 02-22-2020, 18:23   #712 (permalink)
Member: 2185549
Thanks Meter: 535
samsung g532f boot repair done
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 8.1 (32 bit) build 9600 (6.3.9600.18217)
Looking for EasyJTAG box...
EasyJTAG API ver. 3307
EasyJTAG Box Serial = 417A1E88471829FA
Card Serial = AAF96E71
EasyJTAG Box Firmware = 2.50
Changelog:
30.06.2019 (ver 1.6.1.0)
Fix: Bugs that have been found through your crash report
Setting interface to EasyJtag2/E-Socket
Setting bus width to 1 Bit
Setting frequence to 1 MHz
EMMC Device Information :
EMMC CID: 90014A4838473475920123106D2D25B5
EMMC CSD: D02701320F5903FFFFFFFFE78A40002B
EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 23106D2D , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G4u_23106D2D_20200222_201755.extcsd
EMMC Init completed.
Backup saved: H8G4u_23106D2D_20200222_201811.extcsd
Operation: Writing all eMMC Regions...
Operation: Writing BootConfig ...
Reg: 179 Value: 0x48
Reg: 177 Value: 0x00
Reg: 162 Value: 0x01
Done
Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000
Filename: EMMC_QN16BB_ROM2_000000000000_000000400000.bin
eMMC switching to ROM2
Writing partition...
Error writing at address: 000000270000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1
Error writing at address: 000000270000 , error: -1, CMD Timeout Error ... Retry #2
Error writing at address: 000000270000 , error: -1, CMD Timeout Error ... Retry #3
Too many errors. Writing has been stopped
Backup saved: H8G4u_23106D2D_20200222_201931.extcsd
Opening file: GRANDPPLTE_CIS_SER.pit
Pit: GRANDPPLTE_CIS_SER.pit
Entry count: 34
The size of the last section has been updated
BL_G532FXWU1ASB1_CL15382149_QB21998039_REV00_user_ low_ship_MULTI_CERT.tar.md5
The list of files in the firmware:
preloader.img
lk.bin
param.bin
trustzone.bin
efuse.img
Backup saved: H8G4u_23106D2D_20200222_201940.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 0001D1FFBE00
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: preloader.img
Unpacking file: lk.bin
Unpacking file: efuse.img
Unpacking file: trustzone.bin
Unpacking file: param.bin
Partition name: BOOTLOADER
Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
Erasing partition...
Error erasing at address: 000000098000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1
Error erasing at address: 000000098000 , error: -1, CMD Timeout Error ... Retry #2
Error erasing at address: 000000098000 , error: -1, CMD Timeout Error ... Retry #3
Too many errors. Erasing has been stopped
Backup saved: H8G4u_23106D2D_20200222_202012.extcsd
Done writing partition. Write speed: 57.50 KB/s
Partition name: LK
Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 97.91 KB/s
Partition name: EFUSE
Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
Done writing partition. Write speed: 30.84 KB/s
Partition name: TEE1
Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
Done writing partition. Write speed: 118.22 KB/s
Partition name: PARAM
Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
Done writing partition. Write speed: 119.20 KB/s
Partition USERDATA : formatting as EXT4. Please wait ...
Formatting completed
Check BootConfig for the selected vendor
All done time: [00:02:19:466]
Old 02-24-2020, 09:58   #713 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Realme c2 pattern unlock easy jtag
REALME C2 PATTERN UNLOCK
EASY JTAG
DETECT INFO + FRP LOG
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
eMMC CID : 150100514536334D4203158E07865646
eMMC Date: 05/2019  Rev.0x3
eMMC NAME: QE63MB , S/N:  361629574
EMMC RPMB is programmed and written 1223 times
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x02 , width 8bits  , Partition config [179]: 0x48.
Backup saved: QE63MB_ 361629574_20200224_1403.extcsd
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Detected LINUX(Android) SYSTEM : 0x0060000000 (3.601GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 232464
Short Android info:
Unable to read prop.plist , code : 2
Backup saved: BuildProp_20200224_1403.txt
Detected USERDATA USERDATA : 0x015B000000 (9.80GB)
 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000     ................................;
Done.
CMD Active Level:2949 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Formatting FRP...
Detected LINUX(Android) FRP : 0x000BE88000 (1.0MB) formatting...
Done.
Detected LINUX(Android) CACHE : 0x0146800000 (328.0MB) , formatting...
Done.
Detected LINUX(Android) USERDATA : 0x015B000000 (9.80GB) , formatting...
Done.
Done.
Done.
Old 03-04-2020, 12:09   #714 (permalink)
Member: 50772
Sonork: 100.1590990
Thanks Meter: 320
vivo u10
eMMC CID : 13014E53304A394A381012A438728623
eMMC CSD : D05F01328F5913FFFFFFFFEF964000A9
eMMC Date: 08/2019 Rev.0x10
eMMC NAME: S0J9J8 , S/N: 312752242
eMMC NAME (HEX): 53304A394A38
EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 3337 times
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Disk identifier (GUID): F7B3C8B7-467A-B343-2334-45085C170D1A
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686
Formatting FRP...
Detected LINUX(Android) FRP : 0x002DDD0000 (512.0KB) formatting...
Done.
Detected LINUX(Android) CACHE : 0x01E8200000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) USERDATA : 0x01F8200000 (50.364GB) , formatting...
Done.
Done.
Done.
Old 03-05-2020, 08:20   #715 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 941
OPPO A7 pattern lock done
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AA23-17A6 , ver: 22
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 5 serial devices
COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1)
COM5 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM5)
COM4 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Plus Control Port (COM4)
COM8 root\rimports RIM Virtual Serial Port v2 (COM8)
COM9 root\rimports RIM Virtual Serial Port v2 (COM9)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Box S/N: 0F01300C22E581EB, ,FW Ver.: 01.63
CMD Active Level:2340 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
eMMC CID : 150100524836344142050C6F9AE8163C
eMMC Date: 01/2019 Rev.0x5
eMMC NAME: RH64AB , S/N: 208640744
eMMC NAME (HEX): 524836344142
EMMC RPMB is programmed and written 20827 times
Backup saved: RH64AB_ 208640744_20200305_1330.extcsd
Detected LINUX(Android) SYSTEM : 0x003E800000 (3.968GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 256000
Short Android info:
Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20191231.163024 release-keys
Backup saved: BuildProp_20200305_1330.txt
Detected USERDATA USERDATA : 0x017E800000 (52.264GB)
5F2889E5 D13D71E4 9618A7B1 08599BEF 7B1826DA 33D9C1CA 4013FEEA 72BA769E _(‰åÑ=qä–.§±.Y›ï{.&Ú3ÙÁÊ@.þêrºvž;
0BAB02AB 7ADE17C7 E1D3A13A 9626802F A7086C64 E72F6633 A9D89756 585EB309 .«.«zÞ.ÇáÓ¡:–&./§.ldç/f3©Ø—VX^³ ;
2297718F 42FE7231 43843845 40900A3C 2AE2397B 5C57775D CF932AAE 59264F6A "—q.Bþr1C„8E@..<*â9{\Ww]Ï“*®Y&Oj;
513BBC56 DBA4F2B7 EF4B713B 4134E243 7D47BB85 3F1CB561 907459F9 EE13FAC4 Q;¼VÛ¤ò·ïKq;A4âC}G»…?.µa.tYùî.úÄ;
94F96811 F13C56FB AD28C604 30E2DFD3 2868F33B 0E04FD8A 5620E1F7 677BAE08 ”ùh.ñ<Vû*(Æ.0âßÓ(hó;..ýŠV á÷g{®.;
28274709 08293094 9C7BA0DF CBED0122 6DDAE332 B5275E21 37EFB912 1F5DD4A0 ('G .)0”œ{*ßËí."mÚã2µ'^!7ï¹..]Ô*;
767459CD 0046D984 85CA7D82 98AF9EAC 603EBF0C D8AF0E56 B3E035B2 021A7E18 vtYÍ.FÙ„…Ê}‚.¯ž¬`>¿.د.V³à5²..~.;
A38D9B28 092DF3C2 ECFDC574 E86C549E 661E600B C06B7408 36130D22 415B2281 £.›( -óÂìýÅtèlTžf.`.Àkt.6.."A[".;
Done.
CMD Active Level:2619 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Detected (Android Userdata) USERDATA : 0x017E800000 (52.264GB)
Erasing...
Done.
Detected (Android Cache)) CACHE : 0x001F300000 (256.0MB)
Erasing...
Done.
Done.
Old 03-05-2020, 10:33   #716 (permalink)
Member: 575256
Thanks Meter: 34
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 256000
Short Android info:
Done.
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Erasing...
Done.
Erasing...
Done.
Done.
pinout isp howw to devicess????
Old 03-06-2020, 15:34   #717 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
open easy jtag select a7 cph1901 or click emmc/ufs pinout
Old 03-06-2020, 16:50   #718 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Realme c1 rmx1811 pattern unlock easy jtag
REALME C1 RMX1811
PATTERN UNLOCK
EASY JTAG
INFO OR UNLOCK LOG
CMD Active Level:2516 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
eMMC CID : 150100514536334D4203A2C7F29075D2
eMMC NAME: QE63MB , S/N: 2731012752
EMMC RPMB is programmed and written 90067 times
Backup saved: QE63MB_2731012752_20200306_1909.extcsd
Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Backup saved: BuildProp_20200306_1909.txt
Detected USERDATA USERDATA : 0x015B800000 (9.129GB)
 C7B40695 D0E99D9F A96B68E8 51C4E7DF 39CBB2D5 4E7B5F04 F1A3B88F BFF61D3F     Ç´.•Ðé.Ÿ©khèQÄçß9˲ÕN{_.ñ£¸.¿ö.?;
 3D612FB4 B2841E06 28656A5F 39DEC212 BC7BE6A2 0CA823AC 42D33D1A 92FBA1E8     =a/´²„..(ej_9ÞÂ.¼{æ¢.¨#¬BÓ=.’û¡è;
 943AEAB0 C5866DA7 2F2F03E5 2B8ADD8D 2B856AF1 73C262EE 1A324FBB CA1A5889     ”:ê°Å†m§//.å+ŠÝ.+…jñsÂbî.2O»Ê.X‰;
 10602E41 9F465760 EC0F701A 7C5D02FA 0595271F 3EBA2180 7AFF0D51 7A918534     .`.AŸFW`ì.p.|].ú.•'.>º!.zÿ.Qz‘…4;
 F5B23F21 1B18CA8D 36947E89 3BCBF75F 857A611D 15EF3131 26DDC7EB 1E2FC43B     õ²?!..Ê.6”~‰;Ë÷_…za..ï11&ÝÇë./Ä;;
 CE36EA0B E667D925 416B729F 4B415D75 3CB27BBD 18EE2B88 20DAECDC 8A9F7394     Î6ê.ægÙ%AkrŸKA]u<²{½.î+. ÚìÜŠŸs”;
 114E3050 D21A1AEC D2B0AA76 7BDFB787 B6BAB1BD BA3688D2 C9FD72B0 DDAC30C2     .N0PÒ..ìÒ°ªv{ß·‡¶º±½º6.ÒÉýr°Ý¬0Â;
 E6C5AA93 F16D04E2 4B9743D7 E1A487F5 C4E04B1F 9031151F 0820352F 193E7F1F     æŪ“ñm.âK—C×ᤇõÄàK..1... 5/.>..;
Done.
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Writing Recovery Command to MISC (33)
Done.
Old 03-07-2020, 11:38   #719 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Oppo a1k cph1923 pattern unlock easy jtag
OPPO A1K CPH1923
PATTERN UNLOCK
EASY JTAG
INFO OR UNLOCK LOG
CMD Pullup Level:2052 mV
CMD Active Level:2970 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
eMMC CID : 150100514436334D4203781EDE2FC592
eMMC Date: 12/2018  Rev.0x3
eMMC NAME: QD63MB , S/N: 2015288879
eMMC NAME (HEX): 514436334D42
EMMC RPMB is programmed and written 4441 times
Backup saved: QD63MB_2015288879_20200307_1514.extcsd
Detected LINUX(Android) SYSTEM : 0x0074800000 (4.687GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 302512
Short Android info:
Backup saved: BuildProp_20200307_1514.txt
Detected USERDATA USERDATA : 0x01BB800000 (22.132GB)
Done.
CMD Active Level:3021 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
EMMC ROM1 (Main User Data)   Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
Formatting FRP...
Done.
Detected LINUX(Android) CACHE : 0x01A0800000 (432.0MB) , formatting...
Done.
Detected LINUX(Android) USERDATA : 0x01BB800000 (22.132GB) , formatting...
Done.
Done.
Done.
The Following 3 Users Say Thank You to .::THE ROCK::. For This Useful Post:
Old 03-09-2020, 04:36   #720 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
Nova 3i INE-LX2 frp removed
HiPower mode is ON
Setting frequence to 21 MHz
CMD Pullup Level: 1680 mV
CMD Active Level: 1753 mV
EMMC CID: 450100444134313238019D6B690665CA
EMMC CSD: D00F00328F5903FFFFFFFFEF8A404022
EMMC Manufacture : SANDISK , EMMC NAME: DA4128 , HEX: 444134313238 , S/N: 9D6B6906 , rev. 0x01
EMMC ROM 1 (Main User Data) Capacity: 119276 MB (001D1EC00000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 6542 , Response: Not Clean
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x08 / 0x02 / 0x01
Backup saved: DA4128_9D6B6906_20200304_102629.extcsd
Scanning soft partitions
GPT header is found and is valid
Partition: frp, [000000080000 - 000000100000], size: 000000080000 (512. KB)
Partition: persist, [000000100000 - 000000300000], size: 000000200000 (2.00 MB)
Partition: reserved1, [000000300000 - 000000800000], size: 000000500000 (5.00 MB)
Partition: reserved6, [000000800000 - 000000880000], size: 000000080000 (512. KB)
Partition: vrl, [000000880000 - 000000900000], size: 000000080000 (512. KB)
Partition: vrl_backup, [000000900000 - 000000980000], size: 000000080000 (512. KB)
Partition: modem_secure, [000000980000 - 000001200000], size: 000000880000 (8.50 MB)
Partition: nvme, [000001200000 - 000001700000], size: 000000500000 (5.00 MB)
Partition: certification, [000001700000 - 000001800000], size: 000000100000 (1.00 MB)
Partition: oeminfo, [000001800000 - 000005800000], size: 000004000000 (64.0 MB)
Partition: secure_storage, [000005800000 - 000007800000], size: 000002000000 (32.0 MB)
Partition: modem_om, [000007800000 - 000009800000], size: 000002000000 (32.0 MB)
Partition: modemnvm_factory, [000009800000 - 00000A800000], size: 000001000000 (16.0 MB)
Partition: modemnvm_backup, [00000A800000 - 00000B800000], size: 000001000000 (16.0 MB)
Partition: modemnvm_img, [00000B800000 - 00000DA00000], size: 000002200000 (34.0 MB)
Partition: reserved7, [00000DA00000 - 00000DC00000], size: 000000200000 (2.00 MB)
Partition: hisee_encos, [00000DC00000 - 00000E000000], size: 000000400000 (4.00 MB)
Partition: veritykey, [00000E000000 - 00000E100000], size: 000000100000 (1.00 MB)
Partition: ddr_para, [00000E100000 - 00000E200000], size: 000000100000 (1.00 MB)
Partition: modem_driver_a, [00000E200000 - 00000F600000], size: 000001400000 (20.0 MB)
Partition: reserved2, [00000F600000 - 00000FD00000], size: 000000700000 (7.00 MB)
Partition: splash2, [00000FD00000 - 000014D00000], size: 000005000000 (80.0 MB)
Partition: bootfail_info, [000014D00000 - 000014F00000], size: 000000200000 (2.00 MB)
Partition: misc, [000014F00000 - 000015100000], size: 000000200000 (2.00 MB)
Partition: dfx, [000015100000 - 000016100000], size: 000001000000 (16.0 MB)
Partition: rrecord, [000016100000 - 000017100000], size: 000001000000 (16.0 MB)
Partition: fw_lpm3_a, [000017100000 - 000017140000], size: 000000040000 (256. KB)
Partition: reserved3_a, [000017140000 - 000017500000], size: 0000003C0000 (3.75 MB)
Partition: hdcp_a, [000017500000 - 000017600000], size: 000000100000 (1.00 MB)
Partition: hisee_img_a, [000017600000 - 000017A00000], size: 000000400000 (4.00 MB)
Partition: hhee_a, [000017A00000 - 000017E00000], size: 000000400000 (4.00 MB)
Partition: hisee_fs_a, [000017E00000 - 000018600000], size: 000000800000 (8.00 MB)
Partition: fastboot_a, [000018600000 - 000019200000], size: 000000C00000 (12.0 MB)
Partition: vector_a, [000019200000 - 000019600000], size: 000000400000 (4.00 MB)
Partition: isp_boot_a, [000019600000 - 000019800000], size: 000000200000 (2.00 MB)
Partition: isp_firmware_a, [000019800000 - 00001A600000], size: 000000E00000 (14.0 MB)
Partition: fw_hifi_a, [00001A600000 - 00001B200000], size: 000000C00000 (12.0 MB)
Partition: teeos_a, [00001B200000 - 00001BA00000], size: 000000800000 (8.00 MB)
Partition: sensorhub_a, [00001BA00000 - 00001CA00000], size: 000001000000 (16.0 MB)
Partition: erecovery_kernel_a, [00001CA00000 - 00001E200000], size: 000001800000 (24.0 MB)
Partition: erecovery_ramdisk_a, [00001E200000 - 000020200000], size: 000002000000 (32.0 MB)
Partition: erecovery_vendor_a, [000020200000 - 000021200000], size: 000001000000 (16.0 MB)
Partition: kernel_a, [000021200000 - 000022A00000], size: 000001800000 (24.0 MB)
Partition: eng_system_a, [000022A00000 - 000023600000], size: 000000C00000 (12.0 MB)
Partition: recovery_ramdisk_a, [000023600000 - 000025600000], size: 000002000000 (32.0 MB)
Partition: recovery_vendor_a, [000025600000 - 000026600000], size: 000001000000 (16.0 MB)
Partition: dts_a, [000026600000 - 000026E00000], size: 000000800000 (8.00 MB)
Partition: dto_a, [000026E00000 - 000028600000], size: 000001800000 (24.0 MB)
Partition: trustfirmware_a, [000028600000 - 000028800000], size: 000000200000 (2.00 MB)
Partition: modem_fw_a, [000028800000 - 00002C000000], size: 000003800000 (56.0 MB)
Partition: eng_vendor_a, [00002C000000 - 00002CC00000], size: 000000C00000 (12.0 MB)
Partition: modem_patch_nv_a, [00002CC00000 - 00002D000000], size: 000000400000 (4.00 MB)
Partition: preload_a, [00002D000000 - 00002D800000], size: 000000800000 (8.00 MB)
Partition: recovery_vbmeta_a, [00002D800000 - 00002DA00000], size: 000000200000 (2.00 MB)
Partition: erecovery_vbmeta_a, [00002DA00000 - 00002DC00000], size: 000000200000 (2.00 MB)
Partition: vbmeta_a, [00002DC00000 - 00002E000000], size: 000000400000 (4.00 MB)
Partition: modemnvm_update_a, [00002E000000 - 00002F000000], size: 000001000000 (16.0 MB)
Partition: modemnvm_cust_a, [00002F000000 - 000030000000], size: 000001000000 (16.0 MB)
Partition: reserved8, [000030000000 - 000032000000], size: 000002000000 (32.0 MB)
Partition: version_a, [000032000000 - 000034000000], size: 000002000000 (32.0 MB)
Partition: vendor_a, [000034000000 - 000063800000], size: 00002F800000 (760. MB)
Partition: product_a, [000063800000 - 0000A2000000], size: 00003E800000 (1000 MB)
Partition: cust_a, [0000A2000000 - 0000AE000000], size: 00000C000000 (192. MB)
Partition: odm_a, [0000AE000000 - 0000B9000000], size: 00000B000000 (176. MB)
Partition: cache, [0000B9000000 - 0000BF800000], size: 000006800000 (104. MB)
Partition: system_a, [0000BF800000 - 0001A4000000], size: 0000E4800000 (3.57 GB)
Partition: preas, [0001A4000000 - 0001DE800000], size: 00003A800000 (936. MB)
Partition: preavs, [0001DE800000 - 0001E0800000], size: 000002000000 (32.0 MB)
Partition: patch_a, [0001E0800000 - 0001ED000000], size: 00000C800000 (200. MB)
Partition: userdata, [0001ED000000 - 001D1EC00000], size: 001B31C00000 (108. GB)
GPT header successfully parsed
HiPower mode is ON
CMD Pullup Level: 1670 mV
Backup saved: DA4128_9D6B6906_20200304_102649.extcsd
Operation: Remove FRP
Searching GPT ...
FRP signature found (partname: frp)
Erasing FRP partition ...
Done erasing partition.
The Following 3 Users Say Thank You to rico_deep For This Useful Post:
Page generated in 0.49824 seconds with 9 queries
