02-03-2020, 07:14 | #706 (permalink) |
Freak Poster Join Date: Sep 2016 Location: BIHAR , INDIA Age: 33
Member: 2630154 Status: Offline Sonork: 1681209 Thanks Meter: 112 | Emmc Reprogram By Easy-Jtag Handset Successfully Recover Done |
The Following 2 Users Say Thank You to ssunil710@gmail For This Useful Post: |
02-07-2020, 16:06 | #707 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Oppo a3s pattern & frp done easy jtag |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
02-11-2020, 10:48 | #708 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Oppo a3s pattern & frp done easy jtag Code: Z3X EasyJtag Software ver. 3.6.2.1 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:3042 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D42039587F0F3455E eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 04/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 2508714227 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 35158 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_2508714227_20200211_1449.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Short EXT fs info: Size: 3.298GB Block size: 4.0KB Inode size: 256 Inodes: 216432 Short Android info: Backup saved: BuildProp_20200211_1449.txt Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2019-12-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20191128.013212 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (9.184GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: B79D3F21 94B8B5F7 190B0287 67AA59B6 95DA4721 2BFD44DC 2FEA78C6 702D306D ·.?!”¸µ÷...‡gªY¶•ÚG!+ýDÜ/êxÆp-0m; 9812DC2F BEC87D4A 3C8E4068 99B16521 62F598E7 36AFBE01 982DA835 3F8AEF9E ..Ü/¾È}J<Ž@h.±e!bõ.ç6¯¾..-¨5?Šïž; 8E5333A5 CFAE7A58 379C5B59 AD7BE204 B6C4BCE2 CDF45C29 4524E72D DCBB515F ŽS3¥Ï®zX7œ[Y*{â.¶Ä¼âÍô\)E$ç-Ü»Q_; 6091FCD5 2E70C3B9 39052306 052696F6 1CE8EA42 378F32CD 09CF9E47 81A70963 `‘üÕ.pù9.#..&–ö.èêB7.2Í ÏžG.§ c; 7C509A71 0DF0EA57 9760BD0F 0A35CFE8 74588CBE A056D056 3659D8E7 5C5D17C3 |Pšq.ðêW—`½..5ÏètXŒ¾ VÐV6YØç\].Ã; 96400D86 6AE4CA50 AFC4CA5C 856ABC9C C1A13A0E B72700F6 F4C69947 F01F554C –@.†jäÊP¯ÄÊ\…j¼œÁ¡:.·'.öôÆ.Gð.UL; C84467DB 14D42259 854700FE 166795B9 115A5B4E 0B08F37A BF11A864 82F42AF0 ÈDgÛ.Ô"Y…G.þ.g•¹.Z[N..óz¿.¨d‚ô*ð; F791BB72 765B7642 EAB29D26 74F814AF D91323C5 83EFFF73 485BAEB0 AB226B98 ÷‘»rv[vBê².&tø.¯Ù.#ŃïÿsH[®°«"k.; Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.2.1 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:3083 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D42039587F0F3455E eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 04/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 2508714227 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 35158 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting... Done. Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting... Done. Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) , formatting... Done. Done. Done. NO CUTTING SHIELD |
The Following 2 Users Say Thank You to .::THE ROCK::. For This Useful Post: |
02-16-2020, 15:06 | #709 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Oppo a3s pattern/pass unlock no data loss 2 handset done easy jtag DETECT INFO Code: Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2010 mV CMD Active Level:3083 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420372A8A8F575CE eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 1923655925 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 68199 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_1923655925_20200216_1816.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Short EXT fs info: Size: 3.298GB Block size: 4.0KB Inode size: 256 Inodes: 216432 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2018-11-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20181103.202305 release-keys Backup saved: BuildProp_20200216_1816.txt --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (9.184GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: A9601F1A E964DD4A 203490CD 7D954AC2 089ABFA4 66E862A7 94E711BD 82DB4836 ©`..édÝJ 4.Í}•JÂ.š¿¤fèb§”ç.½‚ÛH6; 25380C40 BB4029C0 D69FEC50 591D0F2D C08F2796 6315557D 5A2B681A CE743902 %8.@»@)ÀÖŸìPY..-À.'–c.U}Z+h.Ît9.; 36F4A922 408FBADC 843C6232 557DF0AB 7FCE03C8 289BD5C6 F4AD67DA 2B1DDA36 6ô©"@.ºÜ„<b2U}ð«.Î.È(›ÕÆô*gÚ+.Ú6; 1E6937E5 FC5BDBBC 04119EBB 4770C9EE 32BFA65E 08B35BBB 92F53552 3BBF86BE .i7åü[Û¼..ž»GpÉî2¿¦^.³[»’õ5R;¿†¾; 446B886D D0A10067 1759F517 C15C7758 F08573E8 6DFF9641 1F113B38 7A097387 Dk.mС.g.Yõ.Á\wXð…sèmÿ–A..;8z s‡; 69A8A06D D6490740 EFF90384 AD21C93C EA326B6B 8F510BF8 9A24BF39 F5C6E1E3 i¨ mÖI.@ïù.„*!É<ê2kk.Q.øš$¿9õÆáã; EE1AF430 B3982FE9 4A0E846C D364590A A3D75279 938BFF1F F68B6F8E 4E0C8AFF î.ô0³./éJ.„lÓdY.£×Ry“‹ÿ.ö‹oŽN.Šÿ; 6A00F2B4 1A49E151 FCE6F5A8 29632157 F81BA502 B3A50CC7 020297FE D872A384 j.ò´.IáQüæõ¨)c!Wø.¥.³¥.Ç..—þØr£„; Done. DETECT INFO Code: Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2072 mV CMD Active Level:2660 mV Box IO Level:2800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 13014E51334A393756100C16F1A5659C eMMC CSD : D07F01328F5913FFFFFFFFEF9240009E eMMC Manufacturer ID: 0013 , OEM ID: 014E eMMC Date: 06/2018 Rev.0x10 eMMC NAME: Q3J97V , S/N: 202830245 eMMC NAME (HEX): 51334A393756 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 67153 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: Q3J97V_ 202830245_20200216_1841.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Short EXT fs info: Size: 3.298GB Block size: 4.0KB Inode size: 256 Inodes: 216432 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2020-01-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20191225.101315 release-keys Backup saved: BuildProp_20200216_1841.txt --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (23.745GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: C7C8A184 C19ED85B C9958D64 B69593F6 838FC494 CEF9332B 1339CA3E A8988D94 ÇÈ¡„ÁžØ[É•.d¶•“öƒ.Ä”Îù3+.9Ê>¨..”; C957C604 52D30CBB A6F99746 BFAFA74B 69C4A8BC 88D37BE1 D7721B61 C2073454 ÉWÆ.RÓ.»¦ù—F¿¯§KiĨ¼.Ó{á×r.aÂ.4T; AD5DFEE1 2F246DA0 03350481 E3A6CACC 1D3C59CD BEDC1D75 2A370F38 D0A2AA4D *]þá/$m .5..ã¦ÊÌ.<Y;Ü.u*7.8ТªM; 167FDF2B B24831AA 970226C9 8B58E88B 289E2BC5 98B58341 0397B228 F416FF6E ..ß+²H1ª—.&É‹Xè‹(ž+Å.µƒA.—²(ô.ÿn; D87BA2B5 B1155F93 E772AA60 5366610B 52CC9C3C E09FB1D8 970242B1 8A11152B Ø{¢µ±._“çrª`Sfa.RÌœ<àŸ±Ø—.B±Š..+; B9BA329F 3DA40190 0F74D5B6 B5CAAAD1 AF15D647 991D4E2D 891760A6 CD4F7A7E ¹º2Ÿ=¤...tÕ¶µÊªÑ¯.ÖG..N-‰.`¦ÍOz~; 6B301F24 5F5F31BF 3506AD15 D49BED29 C6FF16B1 461780CA FDC55D5D 1AA96983 k0.$__1¿5.*.Ô›í)Æÿ.±F..ÊýÅ]].©iƒ; 2A052BBD CDE9810E 2801EAFF 4A3BEF41 B7167FB2 65CA583A 86E60747 288B3FEA *.+½Íé..(.êÿJ;ïA·..²eÊX:†æ.G(‹?ê; Done. |
02-17-2020, 08:19 | #710 (permalink) |
No Life Poster Join Date: Jan 2004 Location: india
Member: 50772 Status: Offline Sonork: 100.1590990 Thanks Meter: 320 | Quote: |
02-22-2020, 18:23 | #712 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | samsung g532f boot repair done eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 8.1 (32 bit) build 9600 (6.3.9600.18217) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 417A1E88471829FA Card Serial = AAF96E71 EasyJTAG Box Firmware = 2.50 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 1 MHz EMMC Device Information : EMMC CID: 90014A4838473475920123106D2D25B5 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 23106D2D , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_23106D2D_20200222_201755.extcsd EMMC Init completed. Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 1 MHz EMMC Device Information : EMMC CID: 90014A4838473475920123106D2D25B5 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 23106D2D , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_23106D2D_20200222_201811.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QN16BB_ROM2_000000000000_000000400000.bin eMMC switching to ROM2 Writing partition... Error writing at address: 000000270000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 000000270000 , error: -1, CMD Timeout Error ... Retry #2 Error writing at address: 000000270000 , error: -1, CMD Timeout Error ... Retry #3 Too many errors. Writing has been stopped Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 1 MHz EMMC Device Information : EMMC CID: 90014A4838473475920123106D2D25B5 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 23106D2D , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_23106D2D_20200222_201931.extcsd EMMC Init completed. Opening file: GRANDPPLTE_CIS_SER.pit Pit: GRANDPPLTE_CIS_SER.pit Entry count: 34 The size of the last section has been updated BL_G532FXWU1ASB1_CL15382149_QB21998039_REV00_user_ low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: preloader.img lk.bin param.bin trustzone.bin efuse.img Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 1 MHz EMMC Device Information : EMMC CID: 90014A4838473475920123106D2D25B5 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 23106D2D , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_23106D2D_20200222_201940.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0001D1FFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking file: lk.bin Unpacking file: efuse.img Unpacking file: trustzone.bin Unpacking file: param.bin Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes eMMC switching to ROM2 Erasing partition... Error erasing at address: 000000098000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error erasing at address: 000000098000 , error: -1, CMD Timeout Error ... Retry #2 Error erasing at address: 000000098000 , error: -1, CMD Timeout Error ... Retry #3 Too many errors. Erasing has been stopped Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 1 MHz EMMC Device Information : EMMC CID: 90014A4838473475920123106D2D25B5 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 23106D2D , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_23106D2D_20200222_202012.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0001D1FFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking file: lk.bin Unpacking file: efuse.img Unpacking file: trustzone.bin Unpacking file: param.bin Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 57.50 KB/s Partition name: LK Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 97.91 KB/s Partition name: EFUSE Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 30.84 KB/s Partition name: TEE1 Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 118.22 KB/s Partition name: PARAM Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 119.20 KB/s Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed Check BootConfig for the selected vendor All done time: [00:02:19:466] |
02-24-2020, 09:58 | #713 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Realme c2 pattern unlock easy jtag REALME C2 PATTERN UNLOCK EASY JTAG DETECT INFO + FRP LOG Code: Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2072 mV CMD Active Level:3083 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4203158E07865646 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2019 Rev.0x3 eMMC NAME: QE63MB , S/N: 361629574 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 1223 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_ 361629574_20200224_1403.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0060000000 (3.601GB) Short EXT fs info: Size: 3.543GB Block size: 4.0KB Inode size: 256 Inodes: 232464 Short Android info: Unable to read prop.plist , code : 2 Backup saved: BuildProp_20200224_1403.txt --------------------------------------------- Detected USERDATA USERDATA : 0x015B000000 (9.80GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2072 mV CMD Active Level:2949 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4203158E07865646 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2019 Rev.0x3 eMMC NAME: QE63MB , S/N: 361629574 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 1223 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found Formatting FRP... Detected LINUX(Android) FRP : 0x000BE88000 (1.0MB) formatting... Done. Detected LINUX(Android) CACHE : 0x0146800000 (328.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x015B000000 (9.80GB) , formatting... Done. Done. Done. Last edited by .::THE ROCK::.; 02-24-2020 at 10:06. |
03-04-2020, 12:09 | #714 (permalink) |
Member: 50772 Status: Offline Sonork: 100.1590990 Thanks Meter: 320 | vivo u10 --------- eMMC CID : 13014E53304A394A381012A438728623 eMMC CSD : D05F01328F5913FFFFFFFFEF964000A9 eMMC Manufacturer ID: 0013 , OEM ID: 014E eMMC Date: 08/2019 Rev.0x10 eMMC NAME: S0J9J8 , S/N: 312752242 eMMC NAME (HEX): 53304A394A38 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 3337 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): F7B3C8B7-467A-B343-2334-45085C170D1A Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found Formatting FRP... Detected LINUX(Android) FRP : 0x002DDD0000 (512.0KB) formatting... Done. Detected LINUX(Android) CACHE : 0x01E8200000 (256.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x01F8200000 (50.364GB) , formatting... Done. Done. Done. |
03-05-2020, 08:20 | #715 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 941 | OPPO A7 pattern lock done Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA23-17A6 , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 5 serial devices COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1) COM5 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM5) COM4 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Plus Control Port (COM4) COM8 root\rimports RIM Virtual Serial Port v2 (COM8) COM9 root\rimports RIM Virtual Serial Port v2 (COM9) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0F01300C22E581EB, ,FW Ver.: 01.63 CMD Pullup Level:2010 mV CMD Active Level:2340 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100524836344142050C6F9AE8163C eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 01/2019 Rev.0x5 eMMC NAME: RH64AB , S/N: 208640744 eMMC NAME (HEX): 524836344142 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 20827 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: RH64AB_ 208640744_20200305_1330.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003E800000 (3.968GB) Short EXT fs info: Size: 3.905GB Block size: 4.0KB Inode size: 256 Inodes: 256000 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2020-01-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20191231.163024 release-keys Backup saved: BuildProp_20200305_1330.txt --------------------------------------------- Detected USERDATA USERDATA : 0x017E800000 (52.264GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 5F2889E5 D13D71E4 9618A7B1 08599BEF 7B1826DA 33D9C1CA 4013FEEA 72BA769E _(‰åÑ=qä–.§±.Y›ï{.&Ú3ÙÁÊ@.þêrºvž; 0BAB02AB 7ADE17C7 E1D3A13A 9626802F A7086C64 E72F6633 A9D89756 585EB309 .«.«zÞ.ÇáÓ¡:–&./§.ldç/f3©Ø—VX^³ ; 2297718F 42FE7231 43843845 40900A3C 2AE2397B 5C57775D CF932AAE 59264F6A "—q.Bþr1C„8E@..<*â9{\Ww]Ï“*®Y&Oj; 513BBC56 DBA4F2B7 EF4B713B 4134E243 7D47BB85 3F1CB561 907459F9 EE13FAC4 Q;¼VÛ¤ò·ïKq;A4âC}G»…?.µa.tYùî.úÄ; 94F96811 F13C56FB AD28C604 30E2DFD3 2868F33B 0E04FD8A 5620E1F7 677BAE08 ”ùh.ñ<Vû*(Æ.0âßÓ(hó;..ýŠV á÷g{®.; 28274709 08293094 9C7BA0DF CBED0122 6DDAE332 B5275E21 37EFB912 1F5DD4A0 ('G .)0”œ{*ßËí."mÚã2µ'^!7ï¹..]Ô*; 767459CD 0046D984 85CA7D82 98AF9EAC 603EBF0C D8AF0E56 B3E035B2 021A7E18 vtYÍ.FÙ„…Ê}‚.¯ž¬`>¿.د.V³à5²..~.; A38D9B28 092DF3C2 ECFDC574 E86C549E 661E600B C06B7408 36130D22 415B2281 £.›( -óÂìýÅtèlTžf.`.Àkt.6.."A[".; Done. Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0F01300C22E581EB, ,FW Ver.: 01.63 CMD Pullup Level:2010 mV CMD Active Level:2619 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100524836344142050C6F9AE8163C eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 01/2019 Rev.0x5 eMMC NAME: RH64AB , S/N: 208640744 eMMC NAME (HEX): 524836344142 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 20827 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Android information ------ Detected (Android Userdata) USERDATA : 0x017E800000 (52.264GB) Erasing... Done. Detected (Android Cache)) CACHE : 0x001F300000 (256.0MB) Erasing... Done. --------------------------------------------- Done. |
03-05-2020, 10:33 | #716 (permalink) | |
Freak Poster Join Date: Aug 2007
Member: 575256 Status: Offline Thanks Meter: 34 | Quote:
03-06-2020, 16:50 | #718 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Realme c1 rmx1811 pattern unlock easy jtag REALME C1 RMX1811 PATTERN UNLOCK EASY JTAG INFO OR UNLOCK LOG Code: Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:2516 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4203A2C7F29075D2 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 2731012752 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 90067 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_2731012752_20200306_1909.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Short EXT fs info: Size: 3.298GB Block size: 4.0KB Inode size: 256 Inodes: 216432 Short Android info: Unable to read prop.plist , code : 2 Backup saved: BuildProp_20200306_1909.txt --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (9.129GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: C7B40695 D0E99D9F A96B68E8 51C4E7DF 39CBB2D5 4E7B5F04 F1A3B88F BFF61D3F Ç´.•Ðé.Ÿ©khèQÄçß9˲ÕN{_.ñ£¸.¿ö.?; 3D612FB4 B2841E06 28656A5F 39DEC212 BC7BE6A2 0CA823AC 42D33D1A 92FBA1E8 =a/´²„..(ej_9ÞÂ.¼{æ¢.¨#¬BÓ=.’û¡è; 943AEAB0 C5866DA7 2F2F03E5 2B8ADD8D 2B856AF1 73C262EE 1A324FBB CA1A5889 ”:ê°Å†m§//.å+ŠÝ.+…jñsÂbî.2O»Ê.X‰; 10602E41 9F465760 EC0F701A 7C5D02FA 0595271F 3EBA2180 7AFF0D51 7A918534 .`.AŸFW`ì.p.|].ú.•'.>º!.zÿ.Qz‘…4; F5B23F21 1B18CA8D 36947E89 3BCBF75F 857A611D 15EF3131 26DDC7EB 1E2FC43B õ²?!..Ê.6”~‰;Ë÷_…za..ï11&ÝÇë./Ä;; CE36EA0B E667D925 416B729F 4B415D75 3CB27BBD 18EE2B88 20DAECDC 8A9F7394 Î6ê.ægÙ%AkrŸKA]u<²{½.î+. ÚìÜŠŸs”; 114E3050 D21A1AEC D2B0AA76 7BDFB787 B6BAB1BD BA3688D2 C9FD72B0 DDAC30C2 .N0PÒ..ìÒ°ªv{ß·‡¶º±½º6.ÒÉýr°Ý¬0Â; E6C5AA93 F16D04E2 4B9743D7 E1A487F5 C4E04B1F 9031151F 0820352F 193E7F1F æŪ“ñm.âK—C×ᤇõÄàK..1... 5/.>..; Done. Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:3042 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4203A2C7F29075D2 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 2731012752 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 90067 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. |
03-07-2020, 11:38 | #719 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Oppo a1k cph1923 pattern unlock easy jtag OPPO A1K CPH1923 PATTERN UNLOCK EASY JTAG INFO OR UNLOCK LOG Code: Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2052 mV CMD Active Level:2970 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514436334D4203781EDE2FC592 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2018 Rev.0x3 eMMC NAME: QD63MB , S/N: 2015288879 eMMC NAME (HEX): 514436334D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 4441 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QD63MB_2015288879_20200307_1514.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0074800000 (4.687GB) Short EXT fs info: Size: 4.613GB Block size: 4.0KB Inode size: 256 Inodes: 302512 Short Android info: Unable to read prop.plist , code : 2 Backup saved: BuildProp_20200307_1514.txt --------------------------------------------- Detected USERDATA USERDATA : 0x01BB800000 (22.132GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:3021 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514436334D4203781EDE2FC592 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2018 Rev.0x3 eMMC NAME: QD63MB , S/N: 2015288879 eMMC NAME (HEX): 514436334D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 4441 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found Formatting FRP... Detected LINUX(Android) FRP : 0x000BE88000 (1.0MB) formatting... Done. Detected LINUX(Android) CACHE : 0x01A0800000 (432.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x01BB800000 (22.132GB) , formatting... Done. Done. Done. |
The Following 3 Users Say Thank You to .::THE ROCK::. For This Useful Post: |
03-09-2020, 04:36 | #720 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | Nova 3i INE-LX2 frp removed Quote:
The Following 3 Users Say Thank You to rico_deep For This Useful Post: |
