05-14-2017, 06:45 | #1 (permalink) | |
Freak Poster Join Date: Mar 2010 Location: Earth Age: 39
Member: 1265640 Status: Offline Sonork: 100.1622602 Thanks Meter: 51 | problem with GT-I9192 emmc and boot repair i did change emmc of sam GT-I9192 several time successfully,but this time after change emmc device work correctly until sd card-Tflash (contain boot repair from sd card create by ATF 4.4.2) is into device . without Tflash won't turn on. also i did boot repair via jtag log: Quote:
05-16-2017, 07:22 | #2 (permalink) |
Member: 1265640 Status: Offline Sonork: 100.1622602 Thanks Meter: 51 | did boot configuration can be reasonable? how can i fix it? please help |
The Following User Says Thank You to parsa_dig For This Useful Post: |
05-17-2017, 01:29 | #3 (permalink) |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | as i see from your log your emmc is sandisk 8g which was in phone already which is bad emmc this sandisk,you can replace and upgrade to 16g with KMVTU000LM-B503 |
The Following User Says Thank You to abo anas zayan For This Useful Post: |
03-29-2019, 22:30 | #4 (permalink) |
Junior Member Join Date: Nov 2016 Age: 32
Member: 2643735 Status: Offline Thanks Meter: 6 | Can u plz tell me after write dump phone not turn on its detect as 9008 port. Before 8gb san disk emmc and after b503 emmc 16gb so i m confused about programing. Sent from my SM-G928G using Tapatalk |
03-29-2019, 23:06 | #5 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
check eMMC solder, check CLK line "short" soldering Post, please correct eMMC name. 503 - it's not a eMMC name | |
03-30-2019, 06:30 | #6 (permalink) |
Freak Poster Join Date: Sep 2014 Location: Bahawal Nagar
Member: 2250995 Status: Offline Thanks Meter: 47 | Not Only Repair even Upgraded to 32GB With New z3x easy jtag Suite Youtube Tuturial https://*********/H_Gs3Pzn9Wo Last edited by najrazlug; 03-30-2019 at 06:33. Reason: add sm link |
