07-24-2020, 08:52 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: KRJ
Member: 993718 Status: Offline Thanks Meter: 91 | realme c2 not connect with jtag always show cmd time out error gives cmd time out error Qualcomm based emmc always connect in first try please give some solution here is log Z3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 8C30F9F3F3B1121F, ,FW Ver.: 02.52 CMD Pullup Level:1884 mV CMD Active Level:2233 mV Box IO Level:2800 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 8C30F9F3F3B1121F, ,FW Ver.: 02.52 CMD Pullup Level:1882 mV CMD Active Level:2235 mV Box IO Level:2800 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Last edited by dev.saini; 07-24-2020 at 08:59. |
07-24-2020, 10:27 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Try set 1,8 IO You need set HiPower CLK mode only with power device from USB (not 1,8/2,8 from box) also you can add pull-up resistors 100-200 ohm for D0/CMD lines |
07-24-2020, 11:57 | #3 (permalink) | |
Member: 993718 Status: Offline Thanks Meter: 91 | Quote:
sir i try all methods not working for me realme 2 and oppo a3s etc working fine only C2 gives error | |
07-25-2020, 13:05 | #5 (permalink) |
Member: 993718 Status: Offline Thanks Meter: 91 | Yes u r right bro I try with sd card reader and m...emmc tool and it's working fine I think some issue with JTAG box or software Team please solve this type of issue Thank u |
07-27-2020, 06:20 | #6 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Mediatek CPU can connect only via HiPower CLK mode (power from USB, not use 1,8/2,8 lines) Also at ISP connection You Need use TOLD GND wire For some devices you can add 15-20 ohm resistor to CLK line Last edited by layder; 07-27-2020 at 08:34. |
07-28-2020, 17:44 | #8 (permalink) |
Member: 993718 Status: Offline Thanks Meter: 91 | Yesterday I unlocked c2 with easy JTAG 18Mhz, and 1.8 volt without hiPower mode Phone successfully unlocked But Tool Some time gives cmd timeout error When I unlocked with sd card reader Clk and cmd voltage approx 3.3 volt So it's connected first try |
