09-03-2018, 18:29 | #78 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1079917 Status: Offline Sonork: 100.1663316 Thanks Meter: 49 | Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 1774 mV CMD Active Level: 1849 mV EMMC Device Information : EMMC CID: 90014A48344732621101CCEB55DB323D EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: CCEB55DB , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_CCEB55DB_20180903_232430.extcsd EMMC Init completed. Scanning soft partitions Partition table not found Get firmware version BL_J100HXXU0AOB4_CL375756_QB4030225_REV01_user_low _ship.tar.md5 The list of files in the firmware: spl.img sboot.bin sboot2.bin param.lfs Firmware info not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 1799 mV CMD Active Level: 1850 mV EMMC Device Information : EMMC CID: 90014A48344732621101CCEB55DB323D EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: CCEB55DB , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_CCEB55DB_20180903_232554.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #1 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #2 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #3 Too many errors. Writing has been stopped |
09-03-2018, 18:59 | #79 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
09-03-2018, 21:49 | #80 (permalink) |
Member: 1079917 Status: Offline Sonork: 100.1663316 Thanks Meter: 49 | Samsung SM-J100h Dead Boot Repair 100% Done EMMC CID: 90014A48344732621101CCEB55DB323D EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB EMMC NAME: H4G2b , Vendor: SKHYNIX , S/N: CCEB55DB , rev. 01 EMMC NAME (HEX): 483447326200 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot from: ROM2 (Boot partition 1) , width: 1 bit Boot Partition [179] / Bus Config [177] : 0x08 / 0x00 H/W Reset Function [162] : 0x01 , RST_n signal is permanently enabled Partition setting [PARTITION_SETTING_COMPLETE] : 0x01 EMMC Permanent / Temporary Write Protection : No / No Brand = samsung Manufacturer = samsung Model = SM-J100H Phone platform = sc8830 CPU Abi = armeabi-v7a Android release = 4.4.4 Firmware version = KTU84P.J100HXXU0AOB4 Firmware date = Wed Feb 11 11:15:08 KST 2015 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 1799 mV CMD Active Level: 1850 mV EMMC Device Information : EMMC CID: 90014A48344732621101CCEB55DB323D EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G2b , EMMC NAME (HEX): 483447326200 , S/N: CCEB55DB , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 3/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H4G2b_CCEB55DB_20180904_012830.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Unpacking file: nvitem.bin Unpacking file: sprddsp.img Unpacking file: sprdcp.img Unpacking file: param.lfs Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: cache.img Unpacking file: system.img Unpacking file: hidden.img Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 347.49 KB/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1239.69 KB/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1233.41 KB/s Partition name: WFIXNV2 Filename: nvitem.bin , Offset: 000000900000 , filesize: 174856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1038.82 KB/s Partition name: WDSP Filename: sprddsp.img , Offset: 000000C00000 , filesize: 1968128 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1263.93 KB/s Partition name: MODEM Filename: sprdcp.img , Offset: 000001000000 , filesize: 7383892 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1283.17 KB/s Partition name: PARAM Filename: param.lfs , Offset: 000002900000 , filesize: 634880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1279.67 KB/s Partition name: KERNEL Filename: boot.img , Offset: 000004500000 , filesize: 5665792 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1283.10 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005500000 , filesize: 6996992 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1273.46 KB/s Partition name: CSC Filename: cache.img , Offset: 000006500000 , filesize: 19317008 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 1281.36 KB/s Partition name: SYSTEM Filename: system.img , Offset: 000012D00000 , filesize: 988463504 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 23 Done writing partition. Write speed: 1282.97 KB/s Partition name: HIDDEN Filename: hidden.img , Offset: 000053D00000 , filesize: 7762160 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 13 Done writing partition. Write speed: 1248.14 KB/s Partition EFS : formatting as EXT4. Please wait ... Formatting completed All done time: [00:14:24:792] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 1798 mV CMD Active Level: 1849 mV EMMC Device Information : EMMC CID: 90014A48344732621101CCEB55DB323D EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G2b , EMMC NAME (HEX): 483447326200 , S/N: CCEB55DB , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 3/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H4G2b_CCEB55DB_20180904_014332.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sboot, [000000400000 - 000000600000], size: 000000200000 Partition: sboot2, [000000600000 - 000000800000], size: 000000200000 Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000 Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000 Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000 Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000 Partition: wdsp, [000000C00000 - 000001000000], size: 000000400000 Partition: modem, [000001000000 - 000001800000], size: 000000800000 Partition: modem2, [000001800000 - 000002000000], size: 000000800000 Partition: tddsp, [000002000000 - 000002400000], size: 000000400000 Partition: fota_sig, [000002400000 - 000002500000], size: 000000100000 Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000 Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000 Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000 Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000 Partition: param, [000002900000 - 000002B00000], size: 000000200000 Partition: efs, [000002B00000 - 000003F00000], size: 000001400000 Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000 Partition: reserved2, [000004400000 - 000004500000], size: 000000100000 Partition: kernel, [000004500000 - 000005500000], size: 000001000000 Partition: recovery, [000005500000 - 000006500000], size: 000001000000 Partition: csc, [000006500000 - 000012D00000], size: 00000C800000 Partition: system, [000012D00000 - 000053D00000], size: 000041000000 Partition: hidden, [000053D00000 - 000056500000], size: 000002800000 Partition: userdata, [000056500000 - 0000E8FFBE00], size: 000092AFBE00 GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J100H Phone platform = sc8830 CPU Abi = armeabi-v7a Android release = 4.4.4 Firmware version = KTU84P.J100HXXU0AOB4 Firmware date = Wed Feb 11 11:15:08 KST 2015 |
09-05-2018, 13:02 | #81 (permalink) | |
Registered User Join Date: May 2009 Location: Bangladesh
Member: 1021931 Status: Offline Thanks Meter: 128 | J100H Dead boot repair Fail all time set only logo come flash by dead After J100H Dead boot repair Fail Need working 128mb dump file i flash all But still dead see info HEAR is log Quote:
09-05-2018, 22:33 | #82 (permalink) | |
Second: if no success, post log and check phone hardware | |
09-07-2018, 10:08 | #83 (permalink) |
Junior Member Join Date: Nov 2008 Location: colombo, sri lanka
Member: 900168 Status: Offline Thanks Meter: 2 | j100h restarting after emmc repair after repair j100h emmc by easy jtag , phone goes to " Samsung J1 " screen . after the went to download mode and , downloaded CSC- SLK latest firmware by using z3x pro . after 100% firmware updated , phone restarted , after restart it comes to " Samsung J1 " screen , after few seconds phone restart . ( phone wont go to Samsung logo " ).please help me on this & please tell how to do this with simple steps , because im new to easy jtag & emmc programming . thanks . |
09-08-2018, 04:50 | #84 (permalink) |
Member: 900168 Status: Offline Thanks Meter: 2 | j100h restarting after emmc repair & firmware update after repair j100h emmc by easy jtag , phone goes to " Samsung J1 " screen . then went to download mode and , downloaded CSC- SLK latest firmware by using z3x pro . after 100% firmware updated , phone restarted , after restart it comes to " Samsung J1 " screen , after few seconds phone restart . ( phone wont go to Samsung logo " ).please help me on this to solve the matter . thanks |
09-08-2018, 05:04 | #85 (permalink) | |
Freak Poster Join Date: Nov 2016 Location: INDONESIA
Member: 2650126 Status: Offline Thanks Meter: 42 | Quote:
Sent from my SM-G530H using Tapatalk | |
The Following User Says Thank You to zardjuna For This Useful Post: |
09-08-2018, 06:04 | #86 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Sri Lanka@cellularsolutions
Member: 230004 Status: Offline Thanks Meter: 174 | you must repartition the emmc before write the boot sections. hynix emmc there is a risk of coming back later logo again .. |
The Following User Says Thank You to gayansuranga For This Useful Post: |
09-13-2018, 14:58 | #89 (permalink) |
No Life Poster Join Date: Mar 2012 Location: BHANGLADESH
Member: 1741293 Status: Offline Sonork: 100.1664286 Thanks Meter: 131 | Samsung J100H Repair errors EasyJTAG HiPower mode is ON Setting frequence to 21 Mhz CMD Pullup Level: 1608 mV CMD Active Level: 1753 mV EMMC Device Information : EMMC CID: 90014A4834473262110169E732B43264 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 69E732B4 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_69E732B4_20180913_195346.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #1 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #2 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #3 Too many errors. Writing has been stopped |
09-13-2018, 17:25 | #90 (permalink) | |
Run "random verify test" with option "Check first 100MB" at settings. | |
