Old 05-20-2015, 21:01   #76 (permalink)
aman_aks87's Avatar
Member: 2023204
Sonork: 100.1653995
Thanks Meter: 23
Originally Posted by javed.tak View Post
ADB FULL DUMP command please
adb shel
su
dd if=/dev/block/mmcblk0 of=/sdcard/N7100_Dump.bin bs=1024 count=262144
Old 05-20-2015, 21:25   #77 (permalink)
aman_aks87's Avatar
Member: 2023204
Sonork: 100.1653995
Thanks Meter: 23
Originally Posted by blang View Post
EasyJTAG Magic SD Card Tool Operation Manual
Here are the instruction on creating recovery sd-card and boot sd-card to recover bricked Samsung Phones in case your phone got broken.*Before doing this, if your device are detected by usb as Qualcomm HS-USB QDLoader 9008 ( If you device are EXYNOS MCU Based it not need to be detected by USB at all)
Creating MAGIC CARD from ZBIN Image.
1. Download both PIT and ZBIN files for yor phone from support area.
2. Insert clean formatted SD Card in USB SD Card Reader
3. Run EasyJTAG Software and select SD Image Plugin
4. Select ZBIN file for creating recovery card by clicking button
5. Select yur SD card in drives list. And click button.
6. After few seconds magic SD card will be done. Close plugin and remove it from reader
Recovery Phone by SD Unbrick card
1. Insert SD Card in phone SD card slot and attach battery
2. Put phone in Download mode by USB-JIC either by keyboard combination ( make sure that you have used file with newer firmware than current phone firmware. If you don't know what firmware have ben in phone before software damage – just use latest zbin file from support!)
3. If phone go in ODIN mode, download firmware with same version as in ZBIN file e.g if you used
4. Samsung_GT-I9200_I9200XXUDNE4_GPT_UEFI.zbin you should use I9200XXUDNE4 firmware or newer one.
5. Flash phone with ODIN with PIT file!
6. Repair Done;
Creating MAGIC CARD from BIN Dump
If your phone have more actual firmware version than ZBIN file on support or you have unsupported phone – you can make ZBIN file by yourself from BINary dump ( eMMC Direct Dump or ADB Full Dump)
1. Run EasyJTAG Software and select SD Image Plugin
2. Select (128mbt DUMP)BIN* file for creating recovery card by clicking button
3. Click [Convert From BIN] button
4. After operation complete you will get ZBIN and PIT file in source folder.
• Different Platforms requires different ROM parts for Magic SD
SAMSUNG GALAXY NOTE 2 N7100 16GB ( INDIAN MODEL )
history :
last STOCK VERSION:  "N7100XXFUN1_N7100ODDFNI1_INU"
After use custom ROM then unfortunately boot looping ..
 then after client again flash N7100XXFUN1_N7100ODDFNI1_INU
stock file .. this time stuck in flashing process..
then after never boot and no sign of life..
we use your process for unbrick ..through SD CARD METHOD...
using ""Samsung_GT-N7100_N7100XXUENA1_SBOOT_4.3_V2.zbin"" this file
working in phone.
after that, when i am flash through odin using "Samsung_GT-N7100_16G.pit" file
with "N7100XXUFNL1_N7100ODDFNI1_INU"
but not flash just stuck in ""PIT FOR MAPPING""
i am also try 4.3 ROM 4.1 ROM but same error..
plz guide how solve this problem ... ?
Old 07-02-2015, 19:06   #78 (permalink)
Member: 1637281
Sonork: 100.1657188
Thanks Meter: 95
when i try to ake image i get this plz help
Old 07-02-2015, 19:14   #79 (permalink)
Member: 1637281
Sonork: 100.1657188
Thanks Meter: 95
This is what i get when i try to use this tool!!! help someone
https://drive.google.com/file/d/0B-w...ew?usp=sharing
and this
please help
Old 07-02-2015, 19:15   #80 (permalink)
Member: 1637281
Sonork: 100.1657188
Thanks Meter: 95
we spend all this money ansd get scarce support y dont they hire more people!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 07-02-2015, 19:28   #81 (permalink)
Member: 1637281
Sonork: 100.1657188
Thanks Meter: 95
easy jtag executable unbricker has stopped working
this is the messge i get when i try to format my card. help plz blang someone
Old 07-02-2015, 19:29   #82 (permalink)
Member: 1637281
Sonork: 100.1657188
Thanks Meter: 95
and this is the error message
Old 07-02-2015, 19:37   #83 (permalink)
Member: 1637281
Sonork: 100.1657188
Thanks Meter: 95
repoting back problem solved.
opened as administartor
Old 09-04-2015, 17:44   #84 (permalink)
ttechno1985's Avatar
Member: 2426327
Sonork: 100.4294967295
Thanks Meter: 70
N9005 SDC REPAIRE FILE CREATED AND TRY TO BOOT THE PHONE BUT ALWAYS SHOWING LIKE THIS ERROR SHOWING ON FIGUR
I USED
(1) 32GB SANDISCK SD CARD
(2) Samsung_SM-N9005_N9005XXUENC2_GPT_UEFI_4.4.2.zbin -SDC REPAIRE FILE I USED DOWNLOAD FROM SHELL
PLZ HELP ME TO FIX THIS PROBLEM......
Old 09-07-2015, 13:42   #85 (permalink)
Member: 1311577
Sonork: 100.1658005
Thanks Meter: 3
need file SD card tool for samsung SM-T215... please help....
thx
Old 09-08-2015, 09:05   #86 (permalink)
kpkgsm's Avatar
Member: 2164664
Sonork: 100.1654214
Thanks Meter: 119
Excuse me Mr.blang I did nOt understand This Steps
Kindly Explaing this with pics or make video
we need to have other working phone in hands for doing this or this can be without having working phone can u explain plz kindly reply..
The Following User Says Thank You to kpkgsm For This Useful Post:
Old 09-08-2015, 09:22   #87 (permalink)
kpkgsm's Avatar
Member: 2164664
Sonork: 100.1654214
Thanks Meter: 119
Step 1 Run Plugin
Step 2 Browse zbin file
Step 3 Select SD cared reader
Step 4 Write SD cared
Magic Cared is ready for boot repair now do these steps.
6. Repair Done.
Do step 1 and 2 same as above.
Step 3 and 4.
BR.
Siddeque.
For this opertation do we need to have other working phone in hands??
Old 10-27-2015, 05:28   #88 (permalink)
Member: 2077936
Thanks Meter: 21
If device goes into sd card mode but doesn't allow me to enter download mode by pressing volume up does this mean that my EMMC is dead or I will need to do EMMC direct? It's a Note 2 i317m and with magic sd card it goes into sd card mode but won't let me go into full download mode by pressing volume up afterwards...
Old 11-04-2015, 17:24   #89 (permalink)
Member: 2077936
Thanks Meter: 21
Step-by-step how to create magic bin file for s4 sgh-i337m if I have another working device and connect to Jtag? What partition do I save and then convert through your awesome tool?
Old 11-05-2015, 19:29   #90 (permalink)
Member: 959485
Thanks Meter: 16
What is magic card plz tell me im new here
Page generated in 0.26294 seconds with 8 queries
