Old 05-15-2017, 17:33   #151 (permalink)
Member: 1832186
Sonork: 100.1678084
Thanks Meter: 72
is this suitable for n7100 ?
Old 06-08-2017, 13:11   #152 (permalink)
Member: 1864687
Thanks Meter: 22
sd card imaging tool targate drive not shown in easy jtag any body know how to solve this problem
Old 06-08-2017, 20:46   #153 (permalink)
Member: 1112585
Sonork: 100.1645028
Thanks Meter: 91
Run as Administrator
Old 06-18-2017, 22:17   #154 (permalink)
Member: 208428
Thanks Meter: 12
Anyone have TP location i9500 ?
Old 08-20-2017, 09:20   #155 (permalink)
farsi_007's Avatar
Member: 472592
Sonork: 100.1664052
Thanks Meter: 180
will SD card process works on A700fd?
Anyone Tested?
Old 01-20-2018, 04:18   #156 (permalink)
dharyadi's Avatar
Member: 369678
Thanks Meter: 192
will SD card process works on SAMSUNG G532G?
Old 01-21-2018, 17:10   #157 (permalink)
Member: 2438408
Thanks Meter: 380
good update easy jtag
The Following User Says Thank You to alexid For This Useful Post:
Old 02-04-2018, 08:20   #158 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
No not work on MTk Phones.
Old 05-31-2018, 15:22   #159 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 788
any body have C900f zbin ?
Old 06-01-2018, 10:38   #160 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
i need samsung sm-g530h/ds zbin file please help.zbin file not support area.
Old 06-11-2018, 03:19   #161 (permalink)
Member: 2103265
Thanks Meter: 59
Originally Posted by gjalvarez View Post
When writing the micro sd I am getting this error, can anyone help me?
Compression thread encountered exception: "Exception of type Compression Exception thrown, cause buffer error (-5)"
Also, how can I know when do I need to use it? I mean what error is giving the phone?
Thank you
I have same problem even a few more...
Already done:
1. Redownloaded BIN file from Support files. Twice. via shell. will try with torrent next.
2. Before WRITE SD card with ZBIN FIlE, READED SD card... (solved only that got different error)
3. Used diffrent cards 3. Kingston, SAndisk, Toshiba.
4. Used external and internal card readers, external universal, internal, not working at all.
Still have problems. First was the Buffer error -5.
Now its shows up another error. INCORRECT PARAMETER.
Im using Windows 10, 64Bits. Build 17134.rs4_release.180410-1804
Installed z3X soft in english, and using in english, i do prefer russian anyway, but to avoid any problem with char encoding because im using Portuguese language in Windows, and encoding works with error in russian. and somehow some parts of soft show up correctly in russian. im not sure if its good or bad x)
Screenshots below:
1. Buffer error:
2. Incorrect parameter:
While using this small handy tool found many small bugs.
1. When click on Format, nothing heppends or shows up. Next moment card bocomes unacessible via windows explorer and not active. After reconnecting the same SD card with Z3X software running card will not show up anywhere. If you replug the card with closed software, it will be correctly regonised and work as usual, and it will still remain untoched, so by observation, FORMAT button does not work at all. tested with 3 different vendors of sd cards, and different sizes, 2GB 16 and 32. all the same result. software running as administrator.
2. not important, cosmetic bug, but still confuses alot. WHen you are creating .ZBIN file from .BIN the process runs and when it finishes, you have a pop up saying that "SD CARD OPERATION FINISHED" that does not make sense, there was no opearion with SDCARD but, only that info confuses alot because after some time you are not sure, if you really pressed read, write or create ZBIN? For ex. when it heppend to me i was AFK for 15min and when came back to check, i was sure that I made SDCARD, and ready to go, and actually it was only ZBIN file ready x/ . so somebody can simply do the same process twise or skip any other thinking that its already done.
3. Would be awesome to see somewhere what process is currently running while working (READING/WRITING/CONVERTING/FORMATTING)
4. What for we need to see Internal hard drives of out pc? just hide them? no need to show them IMO.
Old 06-11-2018, 03:20   #162 (permalink)
Member: 2103265
Thanks Meter: 59
Thank you
Already done:
Screenshots below:
1. Buffer error:
The Following User Says Thank You to d1m0n69 For This Useful Post:
Old 06-28-2018, 17:42   #163 (permalink)
Member: 2804603
I have this problems too
Old 07-03-2018, 16:38   #164 (permalink)
Member: 1520712
Thanks Meter: 19
is any way with easy jtag pluss to bypass micro sd card to export user data? like jpeg audio and other files ?
some way to read from dead micro sd card like expensive tools can do
like vnr from multicom
Old 08-20-2018, 06:18   #165 (permalink)
Member: 1692778
Sonork: coolman78
Thanks Meter: 2
Urgent help, need unbrick img for SM-N900K using sdcard method
I have hard brick galaxy note 3 due to flash wrong NHLOS partition /mmcblk0p1 , now it cannot enter bootloader mode/downloader mode
If phone plugs in PC, it recognized as Qualcomm HS-USB QLoader 9008 (com7)
Can I use USB dongle jig to enable download mode ?
Can I use 301k Ohm SMT resistor type instead of 4bands color resistor type ?
It is not working.
Help please,....THANKS
p/S: lasted ROM SM-N900K_20150304_N900KKKU0GOC4_N900KKTT0GOC4_5.0
Page generated in 0.24990 seconds with 8 queries
