08-06-2022, 10:00 | #256 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
08-12-2022, 09:34 | #258 (permalink) |
Freak Poster Join Date: Sep 2018 Location: korea
Member: 2863121 Status: Offline Thanks Meter: 8 | ufs SAMSUNG-KM2V8001CM-B707 firmware update error hello easy jtag team i came across error when i wanned to write ufs firmware for SAMSUNG-KM2V8001CM-B707 chip here is the log: Write UFS Firmware. Input file :C:\Program Files\Z3X\EASYJTAG\UFS Firmware\SAMSUNG-KM2V8001CM-B707.bin Getting Firmware information from file name Update Firmware Can't write firmware to chip, Code: -405, Reason: UAP SCSI: Command sense: ILLEGAL_REQUEST Done. thanks in advanced |
12-04-2022, 14:59 | #261 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2469387 Status: Offline Thanks Meter: 0 | ufs 2.2 need help Health: Device life time method A: 0x03 (20%-30% device life time used) Device life time method B: 0x04 (30%-40% device life time used) Pre End of Life: 0x01 (Used less then 80% of reserved blocks) Write UFS Chip Config. Can't write Configuration from file, Code: -2303, Reason: UTP: UPIU QUERY result fail: General failure Done. |
01-16-2023, 15:33 | #263 (permalink) |
Freak Poster Join Date: Dec 2017 Location: Uganda
Member: 2793734 Status: Offline Thanks Meter: 22 | help guys Z3X Card Serial: AADDE0C9 EasyJtag Plus Box Found at: COM27 EasyJtag Plus Box Firmware: 2.53.2 Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: ON UFS Safe Mode: ON UFS: Socket Info: S/N: 0x0123D1B3252FDFB5EE Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 27.09.22 Type: EasyJtag UFS Socket BGA-254 ID: 9697 Initialize UFS Engine Fail. Code: -60/ERROR_UFS_BOX_INIT_LINK_AFC Scanner Thread Terminated Elapsed: 00:00:00:676 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. help please http://ibb.co/VjKqFqf Last edited by layder; 01-16-2023 at 15:39. Reason: merge 2 posts to one |
01-25-2023, 12:25 | #264 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 41
Member: 56948 Status: Offline Thanks Meter: 15 | Hello! I need some help, on my easy jtag plus and easyjtag ufs254 isp adapter , on 3 from 5 phone with ufs 3.1 chip, first time identify chip works very nice, then if i press second time identify get error 113, then 3rd time works identify correct, 4th not work.....any ideea???? i will atach a video to show the problem better! thanks! kind regards! https://youtube.com/shorts/WKzQU9voe0Y?feature=share |
01-25-2023, 13:30 | #265 (permalink) | |
The Following User Says Thank You to layder For This Useful Post: |
05-19-2023, 21:01 | #269 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.8.0.4 UFS Socket Info. Serial: 01235ED5408B79B5EE Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 22.05.21 Identify UFS Chip. UFS Chip Voltage: Low Can't init device, Code: -112, Reason: Can't boot device VCC: 3306mV VCCQ2: 1943mV Chip Info: Manufacturer: SKhynix ProductName: H9HQ21AFAMADAR SerialNumber: 0x2520B55CAB20 OemID: 01AD UFS Reference Clock: 19.2MHz UFS Version: 2.2 Done. |
05-19-2023, 21:12 | #270 (permalink) |
