02-16-2023, 17:45 | #1 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Ukraine
Member: 2425619 Status: Offline Thanks Meter: 24 | UNISOC WITH UFS 2.1 config There is a Blackview tab 15 UNISOC T610 UFS2.1 bga254 tablet, the tablet worked for two weeks and went out, turns on with a long vibration, enters the fastboot (fastboot mode inscription in the left corner), "fastboot getvar all"does not give out anything at all in. Blackview support only give me firmware and the tool, so I try to reflash it :after uploading fdl1, fdl2 hangs on PhaseCheck, if you untick backup, it hangs on repartition failed. Erase all function doesn't help. Unsolder memory (Skhynix H9HQ22AECMMDAR) ufs2.1 bga254 256gb. the strange thing is that in the internet there are such tablets only for 128, and on the box, the back cover, as well as on the sticker that 128 is also written under the display. The memory is alive, but besides the fact that it is larger, it has only one lun for all memory and w-lun (rpmb) for 16mb. There are no partitions on lun1. The rpmb counter is clean. Have no otp. Flash is writable and erasable ,and reconfigure is working as well. Naturally, there are no dumps for this device, well, at least I did not find it. The question is how to allocate UFS memory for UNISOC cpu, how many Luns should there be, what sizes, what bootable ? As I understand it, there is no way to write *pac by vendor yet. When I try to choose spreadtrum and pac in easy jtag plus 1.6.6.0 it says :"not supported yet , use emmc 2" , but EJ plus 2 have no spreadtrum/unisoc option . I have no experience at new Unisoc cpu with UFS MEMORY . Blackview support only send template response with pac firmware. 1.did unisoc use w-Lun(rpmb) ? 2.where I can find ufs config for unisoc or information about it except to reading it from another same working device ? 3.can I use ufs config from another device that have same or similar specs(unisoc t610 and ufs 2.1) ? - if yes - can I use it without writing partitions because there are no dumps found on web,will device enter to spd diag com flashing without firmware on memory ( because when I connect it without installed memory I see spd comport in device manager)? Many thanks in advance for any information. |
02-16-2023, 17:46 | #2 (permalink) |
Member: 2425619 Status: Offline Thanks Meter: 24 | 11.02.2023 15:59:20> Z3X EasyJtag EMMC File Manager v 1.22 Started.. 11.02.2023 15:59:25> Build: 1.22.0.1187 11.02.2023 15:59:25> Build Date/Time: May 25 2022 11:46:56 11.02.2023 15:59:25> Box API Version: 3505 11.02.2023 15:59:25> FS Driver Version: 04012021 11.02.2023 15:59:25> SQLite Version: 3.37.1 11.02.2023 15:59:25> FSCK Engine Version: 04012021 11.02.2023 15:59:25> ESE DB Version: 04012021 11.02.2023 15:59:25> System Util Version: 04012021 11.02.2023 15:59:25> System: Windows NT 6.2 (Build 9200) / 64 BIT 11.02.2023 15:59:25> CPU: Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 11.02.2023 15:59:25> Total RAM: 15,87 GB 11.02.2023 15:59:25> System Date: 11.02.2023 15:59:25 11.02.2023 15:59:25> Official Site: https://efm.easy-jtag.com/ 11.02.2023 15:59:25> Site: https://emmc-fm.com/ 11.02.2023 15:59:25> Telegram Russian Support: https://t.me/z3xefm 11.02.2023 15:59:25> FRP Apps: https://efm.easy-jtag.com/frp/ 11.02.2023 15:59:25> 11.02.2023 15:59:28> Z3X Card Serial: AADD66FE 11.02.2023 15:59:28> EasyJtag Plus Box Found at: COM16 11.02.2023 15:59:28> EasyJtag Plus Box Firmware: 2.53.2 11.02.2023 15:59:28> 11.02.2023 15:59:31> Source: EasyJtag Port [UFS] 11.02.2023 15:59:31> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 11.02.2023 15:59:31> UFS Power Mode: HIGH 11.02.2023 15:59:31> Scanner Thread Created.. 11.02.2023 15:59:31> 11.02.2023 15:59:31> Running EasyJtag UFS Mode... 11.02.2023 15:59:31> UFS ISP Mode: OFF 11.02.2023 15:59:31> UFS Safe Mode: ON 11.02.2023 15:59:31> 11.02.2023 15:59:37> Init UFS Engine: 0/OK 11.02.2023 15:59:37> 11.02.2023 15:59:37> EasyJtag Plus S/N: 20F14D5812F4282C 11.02.2023 15:59:37> EasyJtag Plus Box FirmWare: 2.53.2 11.02.2023 15:59:37> Box Hardware = EasyJtag 2nd Generation 11.02.2023 15:59:37> 11.02.2023 15:59:37> UFS: Socket Info: 11.02.2023 15:59:37> S/N: 0x012360063A4FDD00EE 11.02.2023 15:59:37> Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 27.11.20 11.02.2023 15:59:37> Type: EasyJtag UFS Socket BGA-254 11.02.2023 15:59:37> ID: 3871 11.02.2023 15:59:37> 11.02.2023 15:59:37> UFS: Voltage Info: 11.02.2023 15:59:37> Mode: HIGH 11.02.2023 15:59:37> VCC : 3277 mV, VCCQ2: 1923 mV 11.02.2023 15:59:37> 3v3 : 3344 mV, 1v2: 1206 mV 11.02.2023 15:59:37> 11.02.2023 15:59:37> UFS: Memory Info: 11.02.2023 15:59:37> Connection: Socket BGA-254 11.02.2023 15:59:37> Vendor: SKhynix 11.02.2023 15:59:37> Name: H9HQ22AECMMDAR 11.02.2023 15:59:37> S/N: 0x0906E2918321 11.02.2023 15:59:37> OEM ID: 01AD 11.02.2023 15:59:37> Firm Version: A.1.0.2 11.02.2023 15:59:37> UFS Version: 2.1 11.02.2023 15:59:37> Size: 0x003B97800000/238,37 GB 11.02.2023 15:59:37> Max LUNs: 32 11.02.2023 15:59:37> LUNs Cnt: 1 11.02.2023 15:59:37> W-LUNs Cnt: 1 11.02.2023 15:59:37> LUNs ReConfig: Enabled 11.02.2023 15:59:37> 11.02.2023 15:59:37> UFS RPMB Info: 11.02.2023 15:59:37> RPMB Counter: 0 - Not Programmed 11.02.2023 15:59:37> 11.02.2023 15:59:37> UFS Health Info: 11.02.2023 15:59:37> UFS Life Time A: 0x01 - 0% - 10% Life Time Used 11.02.2023 15:59:37> UFS Life Time B: 0x01 - 0% - 10% Life Time Used 11.02.2023 15:59:37> UFS Pre-EOL Info: 0x01 - Used Less 80% of Reserved Blocks 11.02.2023 15:59:37> 11.02.2023 15:59:37> UFS: LUNs Info: 11.02.2023 15:59:37> LUN 0 - Size: 62486528 Block(s)/238,37 GB 11.02.2023 15:59:37> W-LUN 0xC4 (RPMB) - Size: 65536 Block(s)/16,00 MB 11.02.2023 15:59:37> 11.02.2023 15:59:37> UFS Init OK 11.02.2023 15:59:37> Scanning Data From UFS Chip. Please wait.. 11.02.2023 15:59:37> 11.02.2023 15:59:37> Scanning GUID Partition Table from LUN 0 11.02.2023 15:59:37> GPT Signature Not Found. Break.. 11.02.2023 15:59:37> 11.02.2023 15:59:37> Reading Initial Data. Please Wait.. 11.02.2023 15:59:37> 11.02.2023 15:59:37> EmptyCheck: 11.02.2023 15:59:37> EmptyCheck: Done 11.02.2023 15:59:37> 11.02.2023 15:59:37> Scanner Thread Terminated 11.02.2023 15:59:37> Elapsed: 00:00:05:955 11.02.2023 15:59:37> Found 1 Partition(s).. 11.02.2023 15:59:37> Scan Done. Init Main Engine... 11.02.2023 15:59:37> 11.02.2023 15:59:37> Use EasyJtag UFS Device: H9HQ22AECMMDAR 11.02.2023 15:59:37> 11.02.2023 15:59:37> Reader Engine Initialized.. 0/OK 11.02.2023 15:59:37> Source: EasyJtag Port [UFS] 11.02.2023 15:59:37> Power Mode: HIGH 11.02.2023 15:59:37> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 11.02.2023 15:59:37> Config: 1011111111101111 11.02.2023 15:59:37> Operation Done: [Init Engine], Elapsed: 00:00:00:029 11.02.2023 15:59:37> 11.02.2023 15:59:57> Make Zero GP Partition 11.02.2023 15:59:57> 11.02.2023 15:59:57> This Operation is Supported Only for EMMC! 11.02.2023 15:59:57> 11.02.2023 16:00:10> Session is Closed.. 11.02.2023 16:00:10> |
