09-02-2016, 06:14 | #1 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1540917 Status: Offline Sonork: [email protected] Thanks Meter: 1 | FRP samsung J500F Code: Вас приветствует Octoplus/Octopus Box Samsung software версии 2.3.4 ----------------------------------------------------------------------------- Платформа: Samsung Android Выбранный порт: COM11 Выбранная модель: SM-J500H To put SM-J500H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! Performed by 2.3.4 software version FRP is not reset ! ((( why, if the operation is successful ? |
09-02-2016, 06:44 | #2 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Gampaha, Srilanka
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | Find on google and you can find lot of method to remove it without risk. But if you can get risk downgrade it suitable version in octopus support area Did you try this? http://forum.gsmhosting.com/vbb/f453...patch-2129405/ If not next time at least use forum search button bro... |
09-02-2016, 08:01 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. Try to reflash the phone with older (by release date) firmware, then repeat "Reset FRP/Reactivation/EE" operation. |
09-02-2016, 08:12 | #4 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | @ muradx flash this file useing any box in pda tab, and then reset frp operation useing octopus... J500F-FRP-VICKYJADHAV6161-OFA_TESTED - Download - 4shared - vicky jadhav |
The Following User Says Thank You to vickyjadhav6161 For This Useful Post: |
09-06-2016, 07:04 | #5 (permalink) |
Member: 1540917 Status: Offline Sonork: [email protected] Thanks Meter: 1 | Firmware 5.1.1 and OTG! )) )) |
