04-17-2015, 21:29 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: NYC
Member: 1105429 Status: Offline Thanks Meter: 118 | Galaxy S5 SM-G900A Lollipop 5.0 IMEI Repair? I got a Galaxy S5 G900A USA AT&T model. running 5.0. COM Ports disabled, cannot downgrade. any solution on writing certs? tried to downgrade and it got soft-bricked. I was able to recover it back to 5.0 OC4 Version.. Last edited by Octopus box; 04-18-2015 at 07:14. |
04-18-2015, 07:13 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Unfortunately, currently no solution without downgrading phone's firmware to lower Android version. We work on this. |
04-18-2015, 09:08 | #5 (permalink) |
Banned Join Date: Mar 2015
Member: 2371548 Status: Offline Thanks Meter: 27 | There is no need to downgrade it if you can obtain root on lollipop. Will it allow you to downgrade just the kernel to nd3 so you can use towel root to root it? Last edited by iowahawk; 04-18-2015 at 09:14. |
04-18-2015, 09:19 | #6 (permalink) |
Member: 2371548 Status: Offline Thanks Meter: 27 | Flash the nd3 kernel below to the phone via pda/ap tab in odin. See if it will stick if not just flash the lollipop rom back. If it does stick let me know and I will tell you how to fix imei without having to downgrade. http://16005b5c80abd029d678-e001c05e...Kernel.tar.md5 |
04-18-2015, 14:10 | #7 (permalink) | |
Member: 1105429 Status: Offline Thanks Meter: 118 | Quote:
I was able to find the Upgrade file for the lollipop but require me to flash another file first. Found some instructions on xda. Our problem seems to be NO DM COM PORT.. Not root.. Assume we can root it, how do we fix IMEI without the com ports enabled? | |
The Following User Says Thank You to hyratech For This Useful Post: |
04-18-2015, 17:06 | #8 (permalink) | |
Freak Poster Join Date: May 2014
Member: 2188261 Status: Offline Thanks Meter: 13 | Quote:
04-20-2015, 04:35 | #11 (permalink) |
Member: 2371548 Status: Offline Thanks Meter: 27 | I am not sure if the hidden service menu is available on at&t s5 on lollipop. Even if it was you would still have an issue. If you cant root the phone you will not be able to write the qcn back to phone and you will have new imei but no signal. |
04-20-2015, 04:41 | #12 (permalink) |
Member: 1105429 Status: Offline Thanks Meter: 118 | I'm seeing about 10-20 % of the phones i'm repairng requiring qcn to fix the network. most works fine.. even LTE.. and about 50% of them, I will get 4G, and will require a qcn to fix the LTE.. for example the ATT Note 4, without QCN, i will get 4G, qcn will fix it to LTE. i also saw a post on the z3x forum,. they say to enable the com ports, you all you need to do it go to recovery mode, select enable cp logging.. that will enable the com ports,, I do not have a samsung with 5.0 installed now.. can someone with a samsung s5 or similair with firmware 5.0 installed confirm this? |
04-20-2015, 04:53 | #14 (permalink) |
Member: 2371548 Status: Offline Thanks Meter: 27 | Yeah, you are correct. Was thinking of something else. If you can wipe the efs without root you will be able to write the cert via UART and qcn via usb. There are other tools that will allow you to wipe the s5 efs via download mode. So once you wipe efs via download just write cert via UART and write qcn back using USB. No need to downgrade then. |
04-20-2015, 05:11 | #15 (permalink) | |
you got any ideas? | |
