05-01-2014, 23:20 | #1 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Honolulu Hawaii
Member: 2091124 Status: Offline Thanks Meter: 15 | Note 3 " Still Searching" UART Don't work The UART Cables provided by Octopus do not work and nether do some other UART Cable I ordered. Does anyone have an alternate mehod Sent from my Nexus 5 using Tapatalk |
05-01-2014, 23:35 | #3 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | i keepo getting imei failed i keep getting imei failed Welcome to Octoplus/Octopus Box Samsung software version 1.5.5 ----------------------------------------------------------------------------------- To connect SC-01C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N900T Detected phone model: SM-N900T Firmware compiled date: Fri Sep 13 23:52:13 KST 2013 PDA version: N900TUVUBMI7 CSC version: N900TTMBBMI7 SW version: N900TUVUBMI7 Phone IMEI: 358917052974741 Phone SN: RV8F10NT4FA Android version: 4.3 (JSS15J) Rebooting phone in Download mode... Rebooting phone failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N900T Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N900T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM8 Mode: Normal Phone model: SM-N900T Firmware compiled date: Sep 13 2013 Firmware compiled time: 18:20:25 Firmware released date: Sep 13 2013 Firmware released time: 18:20:25 Phone IMEI: 358917-05-297474-1 SW version: SET_BY_CM ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SM-N900T Mode: Normal Phone model: SM-N900T Firmware compiled date: Sep 13 2013 Firmware compiled time: 18:20:25 Firmware released date: Sep 13 2013 Firmware released time: 18:20:25 SW version: SET_BY_CM Old IMEI: 358917-05-297474-1 New IMEI: 357507-05-006324-0 Creating NVM backup Reading NVM done! Connecting to ADB, please waite... ADB server killed. Firmware compiled date: Fri Sep 13 23:52:13 KST 2013 PDA version: N900TUVUBMI7 CSC version: N900TTMBBMI7 SW version: N900TUVUBMI7 Phone IMEI: 358917052974741 Phone SN: RV8F10NT4FA Android version: 4.3 (JSS15J) Cheking Root Erasing old IMEI. It can take some time. Please wait... Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900T-358917052974741-01-05-2014_18-15- 24-.asec file Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. Serching phone... Phone found. Writing new IMEI. Please wait... Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SM-N900T Port is busy Mode: Emergency Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SM-N900T Mode: Normal Phone model: SM-N900T Firmware compiled date: Sep 13 2013 Firmware compiled time: 18:20:25 Firmware released date: Sep 13 2013 Firmware released time: 18:20:25 SW version: SET_BY_CM Old IMEI: 004400-15-202000-0 New IMEI: 357507-05-006558-3 Creating NVM backup Reading NVM done! Connecting to ADB, please waite... Firmware compiled date: Fri Sep 13 23:52:13 KST 2013 PDA version: N900TUVUBMI7 CSC version: N900TTMBBMI7 SW version: N900TUVUBMI7 Phone IMEI: Unknown Phone SN: RV8F10NT4FA Android version: 4.3 (JSS15J) Cheking Root Erasing old IMEI. It can take some time. Please wait... Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900T-01-05-2014_18-22-51-.asec file Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. Serching phone... Phone found. Writing new IMEI. Please wait... Write IMEI failed |
05-02-2014, 07:57 | #5 (permalink) | |
Member: 2091124 Status: Offline Thanks Meter: 15 | Quote:
Few things 1. I can read and perform most of the operations via micro USB except at the end it does not complete that's because I am on a micro USB 2. Support......PLEASE none of the cables work and I ordered another as did a few other people and those don't work. 3. Since UART is not really working...... at all some cases. Is it possible you can you get it to work via Micro USB? I write IMEI on other phones via micro USB and it only seems logical to get that working all things considered . I've tried everything so far and ordering another cable seems fruitless. Sent from my Nexus 5 using Tapatalk | |
05-02-2014, 08:02 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | 1. Most likely, the problem is with Samsung Micro UART cable You used. You should use Samsung Micro UART cable C3300k/C3303k with 523-525 kOhm resistor inside. Check resistor nominal and write here the result. As You can see here: http://forum.gsmhosting.com/vbb/f684...cable-1809652/, Mr. Gambitv01 have solved the same problem by using another Samsung Micro UART cable. 2. Post here full Software log with the Repair IMEI operation. |
05-02-2014, 08:22 | #7 (permalink) | |
I am pretty sure this has to do with not being able to access the ServiceMode DIAG CONFIG and not being able to change those settings. Have you considered trying to get it to work from micro USB. Sent from my Nexus 5 using Tapatalk | |
05-03-2014, 21:00 | #10 (permalink) | |
Freak Poster Join Date: Oct 2010 Location: 32.7798° N, 96.8084° W
Member: 1430518 Status: Offline Thanks Meter: 25 | this solution worked for me-it was provided to me this morning by octopus team- http://forum.gsmhosting.com/vbb/f684...epair-1809997/ Quote:
05-04-2014, 08:27 | #11 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Quote:
