Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 11-25-2017, 08:39   #76 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,413
Originally Posted by Dulaljan View Post
Samsung A310f 7.0 Frp failed
My phone A310f 7.0 mid Iraq sboot failed, then I flash other firmware same CSC,but same problem Frp failed sboot
Help me
Sent from my iPhone using Tapatalk
Hello.
Please look here: http://forum.gsmhosting.com/vbb/f684...olved-2290996/.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 11-25-2017, 09:55   #77 (permalink)
HP GSM's Avatar
Member: 917355
Thanks Meter: 25
Originally Posted by Octopus box View Post
I finished installing v2.6.2, launching the Octoplus program, seeing the update report as the image below?
Old 11-25-2017, 10:00   #78 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
this mean bug.
it is bug fixed version
Old 11-25-2017, 11:14   #79 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 128
Originally Posted by geovanny78 View Post
One question, about unlocking is permanent for Samsung G935T T Mobile, that is, if after a hard reset or a firmware is passed, the phone will always be unlocked ???
it is permanent.
i upgraded phone to nougat and the phone remains still unlocked.
if in startup - custom icon is annoying you then u can safely flash similar OR higher version of your choice to get rid of that "start-up custom" screen.
The Following User Says Thank You to i_seeque For This Useful Post:
Old 11-25-2017, 11:17   #80 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 128
Originally Posted by Conejo27 View Post
my credits have been consumed and the phone has not been unlocked
10 minutes ago I paid 500 credits, and I have been deducted 210 credits and the release was failed
Welcome to Octoplus Box Samsung software version 2.6.2 -------------------------------------------------- --------------------------------- To connect SM-G935T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu-> Settings-> More-> About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu-> Settings-> More-> Developer options. 5. Turn on "USB Debugging" option. Connecting to server .. Username: Authorization .. Login error: Wrong username! Performed by 2.6.2 Software version. Connecting to server .. Username: the_tipico1998 Authorization .. Login error: Wrong password! Performed by 2.6.2 Software version. Connecting to server .. Username: [email protected] Authorization .. Login error: Wrong username! Performed by 2.6.2 Software version. Connecting to server .. Username: the_tipico1998 Authorization .. Login error: Wrong password! Performed by 2.6.2 Software version. Connecting to server .. Username: the_tipico1998 Authorization .. Checking smart card ... Smart card successfully checked. Checking balance .. Your balance: 500 credits. Performed by 2.6.2 Software version. Factory Unlock Notice: - Devices which DO NOT ASK FOR UNLOCK CODE are not supported and credits will not be refunded! - Devices with triggered KNOX in most cases are not eligible for Factory Unlock! Credits will not be refunded! - Devices with "Device Unlock App" (T-Mobile, MetroPCS and AT & T) are not supported and credits will not be refunded! - Sprint devices are not supported and credits will not be refunded! - Verizon devices, which IMEIs starting with 99xx are not supported and credits will not be refunded! Selected interface: USB Searching for device. Please wait ... Waiting for device ... Found device on COM44 Reading info ... Detected device model: SM-G935T HW Version: TMB PDA version: G935TUVU4BQB1 CSC version: G935TTMB4BQB1 CP version: G935TUVU4BQB1 Device SN: unknown Device IMEI: 356164-07-633145-7 FRP / Reactivation: UNLOCK Can not read necessary data from phone via USB! Please select UART interface, connect the phone via UART cable and repeat then "Factory Unlock" operation. Performed by 2.6.2 Software version. Connecting to server .. Username: the_tipico1998 Authorization .. Checking smart card ... Smart card successfully checked. Checking balance .. Your balance: 500 credits. Performed by 2.6.2 Software version. Factory Unlock Notice: - Devices which DO NOT ASK FOR UNLOCK CODE are not supported and credits will not be refunded! - Devices with triggered KNOX in most cases are not eligible for Factory Unlock! Credits will not be refunded! - Devices with "Device Unlock App" (T-Mobile, MetroPCS and AT & T) are not supported and credits will not be refunded! - Sprint devices are not supported and credits will not be refunded! - Verizon devices, which IMEIs starting with 99xx are not supported and credits will not be refunded! Selected interface: USB Searching for device. Please wait ... Waiting for device ... Found device on COM46 Reading info ... Detected device model: SM-G935T HW Version: TMB PDA version: G935TUVU4BQB1 CSC version: G935TTMB4BQB1 CP version: G935TUVU4BQB1 Device SN: unknown Device IMEI: 356164-07-633145-7 FRP / Reactivation: UNLOCK Can not read necessary data from phone via USB! Please select UART interface, connect the phone via UART cable and repeat then "Factory Unlock" operation. Performed by 2.6.2 Software version. Connecting to server .. Username: the_tipico1998 Authorization .. Checking smart card ... Smart card successfully checked. Checking balance .. Your balance: 500 credits. Requesting history .. History not found! Requesting service status .. Service status successfully obtained! Performed by 2.6.2 Software version. Factory Unlock Notice: - Devices which DO NOT ASK FOR UNLOCK CODE are not supported and credits will not be refunded! - Devices with triggered KNOX in most cases are not eligible for Factory Unlock! Credits will not be refunded! - Devices with "Device Unlock App" (T-Mobile, MetroPCS and AT & T) are not supported and credits will not be refunded! - Sprint devices are not supported and credits will not be refunded! - Verizon devices, which IMEIs starting with 99xx are not supported and credits will not be refunded! Selected interface: USB Searching for device. Please wait ... Waiting for device ... Found device on COM46 Reading info ... Detected device model: SM-G935T HW Version: TMB PDA version: G935TUVU4BQB1 CSC version: G935TTMB4BQB1 CP version: G935TUVU4BQB1 Device SN: unknown Device IMEI: 356164-07-633145-7 FRP / Reactivation: UNLOCK Can not read necessary data from phone via USB! Please select UART interface, connect the phone via UART cable and repeat then "Factory Unlock" operation. Performed by 2.6.2 Software version. -------------------------------------------------- --------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G935T Can not kill external ADB references. Please, close Connecting to server ... OK Checking smart card ... OK Username: the_tipico1998 Authorizing ... OK Checking balance ... OK Checking operation ... OK Your balance: 500 credits. -------------------------------------------------- --------------------------------- Sending device information ... OK Rebooting phone in Download Mode ... Searching for a phone. Please wait ... Phone found. Firmware write started. Writing the Data section ... The Data section has been written successfully Searching for a phone. Please wait ... Can not kill external ADB references. Please, close all programs that use ADB server.OK Reading security backup, please wait ... Backup saved as C: \ Program Files (x86) \ Octoplus \ Octoplus_Samsung \ BACKUP \ Security-SM-G935T-RF8HC0C4LHR-24-11-2017_22-50- 54-.asec file Rebooting phone in Download Mode ... Searching for a phone. Please wait ... Phone found. Firmware write started. Writing the Data section ... The Data section has been written successfully Searching for a phone. Please wait ... Can not kill external ADB references. Please, close all programs that use ADB server.OK Initializing .. The charger can not be written The phone's release has been failed Performed by 2.6.2 Software version.
although your problem has been resolved..
i would like to add that - the problem you had faced was of ADB drivers only, nothing else.
the credits are consumed at a very first stage but if process fails in between the server has still stored your IMEI and operation info. SO it does not EAT credits again.
Old 11-25-2017, 12:17   #81 (permalink)
Temporary banned !!
Member: 2652903
Thanks Meter: 11
how to creat acount !!!!
any one help me
Old 11-25-2017, 12:27   #82 (permalink)
Member: 1146942
Sonork: 100.1587278
You need to buy Octopus/Octoplus Server Credits - You will get Username, Password and Credits on account.
You can buy Octopus/Octoplus Server Credits from your local reseller or directly HERE.
Also, You can contact to our managers in on-line Sales Chat ("Chat with us") at www.gsmserver.com, they will help You with purchasing.
The Following 2 Users Say Thank You to Octopus box For This Useful Post:
Old 11-25-2017, 19:17   #83 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Originally Posted by armandogarriga View Post
Hello.. i reset my password, but i dont want to use the generated password, i want to put my own pass.. i can change the pass?
You can contact product managers in on-line Sales Chat ("Chat with us") at www.gsmserver.com, they will help You with changing...if possible.
The Following User Says Thank You to allumts For This Useful Post:
Old 11-26-2017, 07:07   #84 (permalink)
Member: 2779031
Sonork: 500802
Octoplus / Octopus Box Samsung v.2.6.2 good updated
Old 11-26-2017, 08:46   #85 (permalink)
Member: 847906
Sonork: 1654522
Thanks Meter: 5
how about SM-N920c 7.0 pls add thank you
Old 11-26-2017, 10:26   #86 (permalink)
Member: 1691448
Sonork: 1619100
Thanks Meter: 40
add directly unlock or read code without root
Old 11-26-2017, 17:14   #87 (permalink)
Member: 2653449
Thanks Meter: 58
unlock s7 s7 edge
sir, to unlock the s7 and s7 edge you need the modem and boot, the device is rooted, and automatically saves a security, after the phone is rebooted the first time, turn on with the security damaged and then write the security and is unlocked and with security in good condition. all good
Old 11-27-2017, 05:25   #88 (permalink)
Celmaster2's Avatar
Member: 1526099
Sonork: 100.1579632
Thanks Meter: 84
is posible use this update without box?, only buy credits and make unlock?
Old 11-27-2017, 06:12   #89 (permalink)
Member: 1146942
Sonork: 100.1587278
Yes, for unlocking these devices without card/Box, You can use Octoplus Suite Software, please look here: http://forum.gsmhosting.com/vbb/f699...8-out-2291763/.
Old 11-27-2017, 07:38   #90 (permalink)
Member: 977512
g935t dead after changing firmware after unlock. cannot go to download mode. only 'recovery mode' words and off again
Page generated in 0.30951 seconds with 9 queries
