02-08-2015, 12:02 | #1 (permalink) |
Freak Poster Join Date: Nov 2011 Location: Belarus
Member: 1684963 Status: Offline Thanks Meter: 20 | Repair IMEI SM-G7102 how to use new files from support [Solved] Last edited by Octopus box; 02-10-2015 at 11:46. |
02-08-2015, 12:13 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Hello. If in your phone, firmware is with Android 4.4.2. write this modem firmware ("sm-g7102_special_modem_to_repair_any_imei_4_4_2.oct") , then root the phone and write any IMEI. If in your phone, firmware is with Android 4.3. write this modem firmware ("sm-g7102_special_modem_to_repair_any_imei_4_3.oct"), then root the phone and write any IMEI. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
02-09-2015, 11:09 | #5 (permalink) |
Member: 1684963 Status: Offline Thanks Meter: 20 | Not work: Selected port: COM94 Selected model: SM-G7102 Detected phone model: SM-G7102 Firmware compiled date: Fri Nov 7 14:33:25 KST 2014 PDA version: G7102XXUBNK1 CSC version: G7102OXEBNK1 SW version: G7102DDUBNH1 Phone IMEI: ххххххххххх Phone SN: R51F80L01JV Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Old IMEI: хххххх New IMEI: хххххххххх Repairing IMEI A... Write IMEI failed |
02-09-2015, 11:13 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Have You written modem firmware "sm-g7102_special_modem_to_repair_any_imei_4_4_2.oct"? Post here here full Sowtware log with write firmware and Repair IMEI operations. Also, install the latest Software version (http://octoplusbox.com/en/download/software/). |
02-09-2015, 12:00 | #7 (permalink) |
Member: 1684963 Status: Offline Thanks Meter: 20 | Firmware is latest. Logs: WARN : 09.02.2015 13:04:26 > 1. Reconnect the battery. WARN : 09.02.2015 13:04:26 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 09.02.2015 13:04:26 > 3. When phone turns on, press "Volume+" key. INFO : 09.02.2015 13:04:26 > Found phone on INFO : 09.02.2015 13:04:26 > Firmware write started. INFO : 09.02.2015 13:04:26 > Writing MODEM section... INFO : 09.02.2015 13:04:35 > MODEM section has been written successfully. INFO : 09.02.2015 13:04:35 > Firmware writing successfully completed. INFO : 09.02.2015 13:05:24 > Platform: Samsung Android INFO : 09.02.2015 13:05:24 > Selected port: COM94 INFO : 09.02.2015 13:05:25 > Selected model: SM-G7102 INFO : 09.02.2015 13:05:26 > ADB server killed. INFO : 09.02.2015 13:05:28 > Detected phone model: SM-G7102 INFO : 09.02.2015 13:05:28 > Firmware compiled date: Fri Nov 7 14:33:25 KST 2014 INFO : 09.02.2015 13:05:28 > PDA version: G7102XXUBNK1 INFO : 09.02.2015 13:05:29 > CSC version: G7102OXEBNK1 INFO : 09.02.2015 13:05:29 > SW version: G7102DDUBNH1 INFO : 09.02.2015 13:05:31 > Phone IMEI: XXXXX INFO : 09.02.2015 13:05:31 > Phone SN: R51F80L01JV INFO : 09.02.2015 13:05:31 > Android version: 4.4.2 (KOT49H) INFO : 09.02.2015 13:05:31 > Checking Root: INFO : 09.02.2015 13:05:32 > Phone is Rooted. INFO : 09.02.2015 13:05:32 > Old IMEI: XXXXX INFO : 09.02.2015 13:05:32 > New IMEI: XXXXX INFO : 09.02.2015 13:05:32 > Repairing IMEI A... ERROR : 09.02.2015 13:05:53 > Write IMEI failed Last edited by deezeezzzz; 02-09-2015 at 12:05. |
02-09-2015, 12:07 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Do the next: 1. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 2. Take out SIM and SD cards from the device. 3. Run the Software. 4. Make Factory data reset and wipe cache partition. 5. Write modem firmware "sm-g7102_special_modem_to_repair_any_imei_4_4_2.oct". 6. Root the phone. 7. Make Wipe Security. 8. Make Repair IMEI again. 9. Close the Software. 10. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the links, we will research, where can be the problem with your device. |
02-10-2015, 11:42 | #9 (permalink) | |
Member: 1684963 Status: Offline Thanks Meter: 20 | Quote:
1. Flash With Odin CWM-Touch-6.0.5.0-NG4-ms013g.tar 2. Using CWM flash (install ZIP from SD card) UPDATE-SuperSU-v2.45.zip. 3. Using CWM flash (install ZIP from SD card) DE-SAMSUNGNIZER_KNOX_REMOVAL_SCRIPT_V2.0.zip 4. Reboot system now. 5. Enjoy. | |
The Following User Says Thank You to deezeezzzz For This Useful Post: |
