04-19-2016, 12:10 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: In Apple Device
Member: 638481 Status: Offline Sonork: 100.1601053 Thanks Meter: 749 | Samsung G355h Full Mamry i have samsung G355h it show mamry full i flashed And flashed Complet but still mamry full in storage hare is Flashing logs To connect SM-G355H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: G355H_DS_OG1_G355HODS_OG1 _G355HDS_AOG1_HOME.oct Please put the phone into Download Mode and connect USB cable. To put SM-G355H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing KERNEL section... KERNEL section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing FIXNV2 section... FIXNV2 section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing WDSP section... WDSP section has been written successfully. Writing system section... system section has been written successfully. Firmware writing successfully completed. Performed by 2.2.2 software version |
04-19-2016, 12:55 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to make Factory Reset. Try to reflash the phone with different firmwares. If problem will remain - check phone's HW. |
