11-13-2014, 10:26 | #1 (permalink) |
Insane Poster Join Date: Feb 2014
Member: 2122406 Status: Offline Sonork: sabaharans Thanks Meter: 8 | samsung i9301i unlock done but emergency calls only [Solved] 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Reading info, please wait... Detected phone model: GT-I9301I Firmware compiled date: Tue Aug 12 16:25:56 KST 2014 PDA version: I9301IXXUANH1 CSC version: I9301IAUTANF1 SW version: I9301IXXUANF2 Phone IMEI: 355835063660005 Phone SN: RV1F83MSQ8B Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Detected phone model: GT-I9301I Firmware compiled date: Tue Aug 12 16:25:56 KST 2014 PDA version: I9301IXXUANH1 CSC version: I9301IAUTANF1 SW version: I9301IXXUANF2 Phone IMEI: 355835063660005 Phone SN: RV1F83MSQ8B Android version: 4.4.2 (KOT49H) Cheking Root Phone is not rooted Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 31 2014 Firmware compiled time: 12:00:00 Firmware released date: Jun 19 2014 Firmware released time: 19:15:09 Phone IMEI: 355835-06-366000-5 SW version: M8626A-AAAANAZM-1.0.4050 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Detected phone model: GT-I9301I Firmware compiled date: Tue Aug 12 16:25:56 KST 2014 PDA version: I9301IXXUANH1 CSC version: I9301IAUTANF1 SW version: I9301IXXUANF2 Phone IMEI: 355835063660005 Phone SN: RV1F83MSQ8B Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9301I-355835063660005-12-11-2014_13-38-40-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. 4. Note: phone screen must be active Connecting to phone, please wait... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Last edited by Octopus box; 11-16-2014 at 17:32. |
The Following User Says Thank You to sabaharans For This Useful Post: |
11-13-2014, 10:26 | #2 (permalink) |
Member: 2122406 Status: Offline Sonork: sabaharans Thanks Meter: 8 | Welcome to Octoplus/Octopus Box Samsung software version 1.6.8 ----------------------------------------------------------------------------------- To connect GT-I9301I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: I9301IXXUANC6_I9301IITVAND2 _I9301IXXUANC6_HOME.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9301I into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing SBL1 section... SBL1 section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9301I Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM154 Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 Incorrect IMEI SW version: M8626A-AAAANAZM-1.0.4044 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 Incorrect IMEI SW version: M8626A-AAAANAZM-1.0.4044 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 Incorrect IMEI SW version: M8626A-AAAANAZM-1.0.4044 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Detected phone model: GT-I9301I Firmware compiled date: Sat Mar 22 04:16:57 KST 2014 PDA version: I9301IXXUANC6 CSC version: I9301IITVAND2 SW version: I9301IXXUANC6 Phone IMEI: Unknown Phone SN: RV1F83MSQ8B Android version: 4.4.2 (KOT49H) Cheking Root Phone is not rooted Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 Incorrect IMEI SW version: M8626A-AAAANAZM-1.0.4044 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 Incorrect IMEI SW version: M8626A-AAAANAZM-1.0.4044 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Detected phone model: GT-I9301I Firmware compiled date: Sat Mar 22 04:16:57 KST 2014 PDA version: I9301IXXUANC6 CSC version: I9301IITVAND2 SW version: I9301IXXUANC6 Phone IMEI: Unknown Phone SN: RV1F83MSQ8B Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9301I-13-11-2014_14-25-04-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. 4. Note: phone screen must be active Connecting to phone, please wait... IMEI successfully repaired. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 Incorrect IMEI SW version: M8626A-AAAANAZM-1.0.4044 Repairing 3G/4G... Reading nv... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\NV-GT-I9301I-004400152020000-13-11-2014_14-28-32-.nv file 3G/4G repair successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 Incorrect IMEI SW version: M8626A-AAAANAZM-1.0.4044 Creating NVM backup NVM reading process canceled Writing NVM... Writing NVM canceled NVM writing completed successfully Phone will restart now |
11-13-2014, 10:30 | #3 (permalink) |
No Life Poster Join Date: Oct 2014 Location: EARTH
Member: 2283947 Status: Offline Sonork: 100:1662279 Thanks Meter: 317 | minimum 200phone tested with octopus i9301i :P please use search button and unlock properly :P write this nvm>>>>> https://mega.co.nz/#!X4YDFaAI!w_ZQUT...Rh7QvZxtt9znqA |
11-14-2014, 09:12 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,438 | Do exactly the next: 1. Write firmware "I9301IXXUANC6_I9301IITVAND2_I9301IXXUANC6_HOM E" from the Support Area. 2. Re-start the phone. 3. Root the phone by using TowelRoot. 4. Write the second service's IMEI from the Software list (not any IMEI). 5. Make Repair 3G/4G. 6. Restart the phone. 7. Write this NVM backup https://mega.co.nz/#!X4YDFaAI!w_ZQUT...Rh7QvZxtt9znqA 8. Write here FULL Software log with ALL of these actions. |
11-14-2014, 10:46 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,438 | Perform all steps 1-7 again and post here full Software log with all of them. |
11-14-2014, 11:53 | #7 (permalink) |
Member: 2122406 Status: Offline Sonork: sabaharans Thanks Meter: 8 | Welcome to Octoplus/Octopus Box Samsung software version 1.7.4 ----------------------------------------------------------------------------------- To connect GT-I9301I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: I9301IXXUANC6_I9301IITVAND2_I9301IXXUANC6_HOME.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9301I into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing SBL1 section... SBL1 section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9301I Detected phone model: GT-I9301I Firmware compiled date: Sat Mar 22 04:16:57 KST 2014 PDA version: I9301IXXUANC6 CSC version: I9301IITVAND2 SW version: I9301IXXUANC6 Phone IMEI: Unknown Phone SN: RV1F83MSQ8B Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9301I-14-11-2014_16-11-02-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. 4. Note: phone screen must be active Connecting to phone, please wait... IMEI successfully repaired. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9301I Port is busy Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9301I Port is busy Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9301I Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM154 Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 Incorrect IMEI SW version: M8626A-AAAANAZM-1.0.4044 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 Incorrect IMEI SW version: M8626A-AAAANAZM-1.0.4044 Repairing 3G/4G... Reading nv... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\NV-GT-I9301I-004400152020000-14-11-2014_16-17-57-.nv file 3G/4G repair successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 Incorrect IMEI SW version: M8626A-AAAANAZM-1.0.4044 Creating NVM backup Reading NVM done! Writing NVM... NVM writing completed successfully Please, restart the phone to apply changes |
11-14-2014, 12:56 | #9 (permalink) |
Registered User Join Date: Sep 2003 Location: Marruecos Age: 44
Member: 39250 Status: Offline Thanks Meter: 64 | first write security -original - and u phone will be restored to first and original imei after u can - root phone without flashing -write the segund imei -repair 3g -and write NVM |
11-14-2014, 13:07 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,438 | Also, we have prepared and sent test Software version to PM. Try to do the next: 1. Install this Software. 2. Write firmware "I9301IXXUANC6_I9301IITVAND2_I9301IXXUANC6_HOM E" from the Support Area. 3. Re-start the phone. 4. Root the phone. 5. Make "Wipe Security" ("Repair Security/Wipe Security" button in the Software). 6. Write the second service's IMEI from the Software list (not any IMEI). 7. Make Repair 3G/4G. 8. Restart the phone. 9. Write this NVM backup https://mega.co.nz/#!X4YDFaAI!w_ZQUT...Rh7QvZxtt9znqA |
11-14-2014, 14:52 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,438 | Check your PM, we have sent You new test Software version. Repeat all the steps 1-9 ("Repair Security/Wipe Security" button is enabled in this version) and post here the result. |
11-14-2014, 15:47 | #14 (permalink) |
Member: 2122406 Status: Offline Sonork: sabaharans Thanks Meter: 8 | Welcome to Octoplus/Octopus Box Samsung software version 1.7.5 ----------------------------------------------------------------------------------- To connect GT-I9301I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: I9301IXXUANC6_I9301IITVAND2_I9301IXXUANC6_HOME.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9301I into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing SBL1 section... SBL1 section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9301I Reading info, please wait... Detected phone model: GT-I9301I Firmware compiled date: Sat Mar 22 04:16:57 KST 2014 PDA version: I9301IXXUANC6 CSC version: I9301IITVAND2 SW version: I9301IXXUANC6 Phone IMEI: Unknown Phone SN: RV1F83MSQ8B Android version: 4.4.2 (KOT49H) Platform: Samsung Android Selected port: COM1 Selected model: GT-I9301I Detected phone model: GT-I9301I Firmware compiled date: Sat Mar 22 04:16:57 KST 2014 PDA version: I9301IXXUANC6 CSC version: I9301IITVAND2 SW version: I9301IXXUANC6 Phone IMEI: Unknown Phone SN: RV1F83MSQ8B Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 SW Version: M8626A-AAAANAZM-1.0.4044 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\QCN-GT-I9301I-14-11-2014_19-57-43-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9301I-14-11-2014_20-00-29-.asec file Wiping EFS... EFS wipe successfully Phone will restart now Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 SW Version: M8626A-AAAANAZM-1.0.4044 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9301I Detected phone model: GT-I9301I Firmware compiled date: Sat Mar 22 04:16:57 KST 2014 PDA version: I9301IXXUANC6 CSC version: I9301IITVAND2 SW version: I9301IXXUANC6 Phone IMEI: Unknown Phone SN: RV1F83MSQ8B Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9301I-14-11-2014_20-04-33-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. 4. Note: phone screen must be active Connecting to phone, please wait... IMEI successfully repaired. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9301I Port is busy Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9301I Port is busy Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9301I Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM154 Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 Incorrect IMEI SW version: M8626A-AAAANAZM-1.0.4044 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 Incorrect IMEI SW version: M8626A-AAAANAZM-1.0.4044 Repairing 3G/4G... Reading nv... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\NV-GT-I9301I-004400152020000-14-11-2014_20-10-06-.nv file 3G/4G repair successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM154 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 Incorrect IMEI SW version: M8626A-AAAANAZM-1.0.4044 Creating NVM backup Reading NVM done! Writing NVM... NVM writing completed successfully Please, restart the phone to apply changes again Incorrect IMEI............... |
11-14-2014, 15:58 | #15 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,438 | Quote:
