10-20-2016, 07:30 | #16 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To reset FRP You need to find and try to use another Combination firmware, or use Factory Reset FRP service. |
10-20-2016, 08:10 | #17 (permalink) | |
Freak Poster Join Date: Jun 2013
Member: 1953780 Status: Offline Thanks Meter: 6 | Quote:
10-20-2016, 08:22 | #18 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Currently we don't have other Combination firmwares for this model. When we manage to find another firmwares - files will be available in the Support Area as well. |
07-28-2018, 09:42 | #19 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: KARACHI PAKISTAN Age: 45
Member: 207561 Status: Offline Thanks Meter: 820 | Samsung J320FN FRP RESET DONE .. Quote:
----------------------------------------------------------------------------------- To connect SM-J320FN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J320FN Operation: Reset FRP - UserData Reset FRP/ Reactivation lock operation for SM-J320FN will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J320FN into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.6.9 Software version. | |
The Following User Says Thank You to love_4all For This Useful Post: |
