04-07-2002, 00:26 | #31 (permalink) |
Junior Member Join Date: Mar 2002
Member: 10088 Status: Offline Thanks Meter: 0 | First : Thanks for your agrentment. I'm starting translate for simenu4.00 page to chinese. Second : Yes Taiwan has GSM System. Here're more than 5 system provider both GSM-900 and GSM-1800 system. Ans I've try 3 system provider and one pre-paid card, both simenu v3 and v4 work perfectlly!! And as I know in China also have several GSM provide and that's why i want to translate the page to chinese!! The bad news is some system providers use limited SIM card (like Gemplus and else..). The SIM will be destoried with cardinal. Third : I've try simenu v4 on Motorola cd-928 , Timeport p7689 , m3188 the change phone function on all of these phones work fine!! But I still has some question: a. Change phone will take more time than use Reset function!! Sometimes the phonoe will research system twice even it has already registered. b. All 8 position has same SMS center number , could it be sloved? c.Is it possible to expand phone book character and quote with larger Sliver card (16f877 + 24C128) Best regards and sorry for my poor english!! |
04-07-2002, 02:05 | #32 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Spain Age: 62
Member: 10582 Status: Offline Thanks Meter: 99 | For asykgsm I would like that you do not put my Sim_Emu_4.00.zip in that page. Put a link to my pages for download it, so I can view the statistics of visits. Thanks. When you finish with it, tell me which is the URL. To avoid the destruction of SIM, use the SimScan instead of Cardinal, because it has an option to limit the queries to the SIM of the GSM ALGORITHM. In some models is better to use the Reset option for that reason. It is a problem of the phone, not of the SIM-EMU. In SIM-EMU, each position has your own SMS Centre Number, you must enter it in each one. I'll release a version of SIM-EMU for those cards. Best regards |
04-07-2002, 02:11 | #33 (permalink) |
Member: 10582 Status: Offline Thanks Meter: 99 | For wojtek For 18 characters per entry and 36 SMS's, the number of phones remaining is 131. Is it ok ? To obtain more is necesary to reduce the number of SMS's (5.5 entries for each SMS). Regards |
04-07-2002, 23:57 | #36 (permalink) |
Member: 10088 Status: Offline Thanks Meter: 0 | For Simenu: Thanks for your kindly support and answer!! Of course I won't put the dile on my page!! And I will translate the page to Chinese Traditional for Taiwan and Chinese simplex to China ,It may take a little days! Best regards |
04-08-2002, 06:26 | #37 (permalink) | |
Member: 10582 Status: Offline Thanks Meter: 99 | For wojtek Quote:
Code: Offset Instead of Put this 0891 34 1E 34 0A 0894 34 1B 34 10 0895 34 58 34 60 089E 34 1C 34 20 08A0 34 0D 34 18 0F72 30 54 30 60 To modify the english version of SIM-EMU 4.00 to obtain 36 SMS's and 131 ADN with 18 characters each, you must edit the original Sim_Emu_4.00_eng.hex with the following changes: Code: Offset Instead of Put this 0891 34 1E 34 0A 0894 34 1B 34 10 0895 34 58 34 60 089E 34 1C 34 20 08A0 34 0D 34 18 0F6D 30 54 30 60 To modify the spanish version of SIM-EMU 4.00 to obtain 20 SMS's and 219 ADN with 18 characters each, you must edit the original Sim_Emu_4.00.hex with the following changes: Code: Offset Instead of Put this 0891 34 1E 34 0A 0895 34 58 34 60 089E 34 1C 34 20 0F72 30 54 30 60 To modify the english version of SIM-EMU 4.00 to obtain 20 SMS's and 219 ADN with 18 characters each, you must edit the original Sim_Emu_4.00_eng.hex with the following changes: Code: Offset Instead of Put this 0891 34 1E 34 0A 0895 34 58 34 60 089E 34 1C 34 20 0F6D 30 54 30 60 After this, you MUST not change the amount of SMS's from menu, because the results are impredictable. Regards Last edited by simemu; 04-15-2002 at 03:26. | |
04-14-2002, 12:03 | #39 (permalink) |
Junior Member Join Date: Apr 2002
Member: 10991 Status: Offline Thanks Meter: 0 | Umm... even more SMS's Hi Simemu... I think now that many many people's got phones with internal phone book... could the emu be changed so that the ADN's are reduced to... e.g. 25 and SMS increased accordingly ??? In my T65 the 300 built-in phone book is far enough, BUT SMS's get deleted after changing Sim position... I think itll be great to have like 60 sms or so [by the way... is there any theoretical limit to SMS entries in a sim card???] Thanks De pata negra de pata negraaaaaa hehehe ;P saludos. |
04-14-2002, 17:13 | #40 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Poland Age: 47
Member: 10850 Status: Offline Thanks Meter: 0 | to Simemu Hi Simemu! I've got a little question for You: You described how to make 18 char entries in phone book, but the last modification at offset 0F72 corresponds correctly only to spanisch version... so the question is: what change i have to made for english version of flash to get the same results? I need this advice, because "Yo no entiendo espaniol" and one more q : You wrote: "For 18 characters per entry and 36 SMS's, the number of phones remaining is 131"; "To obtain more is necesary to reduce the number of SMS's (5.5 entries for each SMS)" so.... if I wanted to reduce # of SMSs to 20 i can get 5.5*16+131 phone book entries (each 18 characters) ... correct? Haw can i do this? and one more : I use s-e-4 with Nokia 6210... I've got two problems: - after switching operators (using of course "reset method") it takes a quite long time to find network... I think that it's possible coused by updating "forbidden operators list". I deleted it, but two operators that i have put each other in forbidden list every time i swich op's... I don't know if it's exactly that problem... but i think so... Can I deny acces to "forbidden op's list" so they can't update this??? - my two clones have the same card number, but after switch my "last dialled numbers are deleted". Why? Does my nokia recognize cards by IMSI or something ..... I thought, that phone recognize card by card number thx in advance for reply! p.s. thanks for v4.0 ..... is very good stuff Last edited by Milenko; 04-14-2002 at 18:39. |
04-14-2002, 22:47 | #41 (permalink) |
Member: 10582 Status: Offline Thanks Meter: 99 | For khyros I think that all the phones have a limitation of amount of SMS's allowed. For example, the Nokia 3310, does not support more tha 30 SMS's in your memory. I store the SMS's only in EEPROM and in this place the maximun is 40 SMS's. In the next version for GreenCard I'll try to support more than 40 SMS's. In Ericsson phones, the SMS's must be save manually in SIM before changing IMSI, because they noy shown in the other positions. Do you know how can you do it ? If not, I can explain you how. Regards |
04-14-2002, 23:54 | #42 (permalink) |
Member: 10991 Status: Offline Thanks Meter: 0 | Ok.. anyway i was thinking about that and i realised something... in my T65, for example, and my Movistar SIM... the inbox loading time is extremely large (well, the same in 3310) as i can store 25 sms in the original card.... so imagine 80 or somethng DD but i still think its quite a good idea. About the sms deleting problem.... i think its stupid for ericsson to have such "problem".. i mean.... nowadays its LARGE the number of people having more than 1 sim...... and I know how to save them.. thanks :P but i feel the phone gets too slow when using SIM storage for SMS... |
04-15-2002, 03:29 | #43 (permalink) |
Member: 10582 Status: Offline Thanks Meter: 99 | For Milenko I'm sorry for not to indicate the modification to the english version. I'd edited the post to clarify this and to include 20 SMS's and 219 ADN's. About Nokia problems, I recomend to use *3370# to reset the phone and it is normal in Nokia phones to loose the last dialed numbers, because they are not stored in the SIM by this phones. Ericsson and Alcatel correctly store LND in the SIM and the change of position does not loose this numbers. Regards Last edited by simemu; 04-15-2002 at 03:33. |
04-15-2002, 13:14 | #44 (permalink) |
Member: 10850 Status: Offline Thanks Meter: 0 | for Simemu Thank You very much for your reply! I will play with my SIM phone book today I don't understand why You prefer *3370# in nokia phones more then imlemented in simemu "reset" method? Do You think that could solve my problem with "forbidden op's list"? By the way ... codes for change prefered codec (like *3370# - for EFR) don't work in nokia 6210 Regards |
04-16-2002, 01:06 | #45 (permalink) | |
Member: 10582 Status: Offline Thanks Meter: 99 | Re: for Simemu Quote:
Regards | |
New version SIM-EMU 6.00 for GreenCard 2/GreenCard/SilverCard (RELEASED) | simemu | Sim Cloning and Scaning | 217 | 11-17-2020 07:00 |
New version SIM-EMU 6.00 for GreenCard 2 | simemu | Sim Cloning and Scaning | 140 | 04-27-2012 07:27 |
New Version!!! Sim-Emu (16 in 1) | swinaky | Sim Cloning and Scaning | 11 | 06-09-2005 07:42 |
New version SIM-EMU 5.00 for GreenCard | simemu | Sim Cloning and Scaning | 45 | 04-06-2003 22:39 |
New revision SIM-EMU 4.01 | simemu | Sim Cloning and Scaning | 54 | 06-20-2002 06:49 |
