Miracle Box GSMCampus |
07-16-2014, 11:47 | #1 (permalink) |
No Life Poster Join Date: Sep 2010
Member: 1398631 Status: Offline Sonork: 100.1614508 Thanks Meter: 691 | micromaxx a62 not supported cpc 8810 pls help SoftWare Version 1.89 Update:14-07-08 Firmware Version:1.12 Connected OK. Connecting Internet... You use Latest Miracte Software 1.89 Fuzzy Logic Method is very safe and reliable ! Please scan ports first! SPDScaning Pinouts,Need not press Power-Key... <<..... OK. Spread Boot not OK,Please Manually set(Haved All pull down) Definition Applied Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys >>3.Pulled low may not, manually set. br 3cellcare |
