HUA GOLD Old BY HUA TEAM |
09-04-2014, 18:10 | #346 (permalink) |
No Life Poster Join Date: Aug 2013 Location: CHENNAI, TAMILNADU,INDIA
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | samsung e1085f flash successful set braudrate to 921600 |
The Following User Says Thank You to mubarak2344 For This Useful Post: |
09-05-2014, 19:36 | #347 (permalink) |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | samsung e1080f flashing success with asansam box |
09-05-2014, 21:26 | #348 (permalink) |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | samsung e1205t flashing success with asansam box select model as 1200m, use e1205t flash file |
09-11-2014, 19:48 | #349 (permalink) |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Samsung E1200T direct unlock and flash success with asansam box Choose model as E1200M for E1200T flashing and direct unlock, set baudrate to 921600....... Direct unlock Flashing |
09-13-2014, 07:50 | #350 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Amoude-syria Age: 49
Member: 98928 Status: Offline Thanks Meter: 464 | s5280 repaired imei null ok very fast repaired imei null of samsung S5280 HER THE LOG: Code: Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-S5280 Android Version : 4.1.2 PDA Version : S5280XXAMJ3 CS Version : S5280OXXAMJ2 Phone Version : S5280XXAMK1 IMEI : NULL S/N : 00000000000 Checking Root ...OK Phone Root OK. Continue.. Writing IMEI ...OK..OK..OK Rebooting... OK! Operation Completed Operation Time: 00:00:07 Last edited by bavesore; 09-13-2014 at 07:53. Reason: model error |
09-13-2014, 07:59 | #351 (permalink) |
Member: 98928 Status: Offline Thanks Meter: 464 | samsung i9003 repaired imei ok HER THE LOG: Code: Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9003 Android Version : 2.3.6 PDA Version : I9003JPKPH CS Version : I9003OJPKPC Phone Version : I9003JXKP3 IMEI : 004999010640000 Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable and Wait Phone Powering Up Completely (Media Scanners Passed) Then insert UART cable to Phone to Continue Delay 60 Seconds... Searching for phone on COM25 ... Phone Found Reading Data from phone... Model : GT-I9003 S/W Version : I9003JPKPH Unique ID : CSE903376845D9F Memory ID : - IMEI : none Verifying MSL ... OK Bypassing MSL ... OK Writing IMEI ... OK Reset Done! Operation Completed Operation Time: 00:03:54 |
09-13-2014, 09:11 | #352 (permalink) |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Samsung E1200T phone lock successfully readed by asansam box If ur device is locked with phone lock, the operations such as direct unlock and flashing will not remove the phone lock, so what u need to do is click read network lock, here u can see all unlock codes here u can see Lock2 code : 00112345 then ur phone lock code is : 12345 if it show Lock2 code : 00015555 then ur phone lock code is : 5555 if it show lock2 code : 01666668 then ur phone lock code is : 666668 |
09-13-2014, 20:54 | #353 (permalink) |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Samsung E1081T imei repair success with asansam box i flashed e1081t with pnx downloader(provided by asan file support).... flash success and show imei 000000000000000... then i write imei using asansam box, success for imei repair, i choose model as e1080f-SEA to write imei for e1081t.... because e1081t model shows error in writing imei....... |
09-22-2014, 20:37 | #354 (permalink) |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Samsung S3 i9300 imei repair success with asansam box |
09-24-2014, 15:22 | #355 (permalink) |
Product Supporter Join Date: May 2014 Location: IRAN
Member: 2179353 Status: Offline Thanks Meter: 17,022 | 2014/09/24 - 04:04:08 : ----------------------------------------------------------------------------------------------- 2014/09/24 - 04:04:08 : Turn-on the Phone Goto 'Settings > Application > Development' And Check 2014/09/24 - 04:04:08 : 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. 2014/09/24 - 04:04:08 : ----------------------------------------------------------------------------------------------- 2014/09/24 - 04:04:13 : Prepairing ...OK 2014/09/24 - 04:04:13 : Device Found! 2014/09/24 - 04:04:13 : Reading Phone Informations ... 2014/09/24 - 04:04:13 : 2014/09/24 - 04:04:14 : Model : GT-S7262 2014/09/24 - 04:04:14 : Android Version : 4.1.2 2014/09/24 - 04:04:14 : PDA Version : S7262JVUAND2 2014/09/24 - 04:04:14 : CS Version : S7262OJVANC3 2014/09/24 - 04:04:14 : Phone Version : S7262JVUANB1 2014/09/24 - 04:04:14 : IMEI : NULL 2014/09/24 - 04:04:14 : S/N : RV1F71AYVQJ 2014/09/24 - 04:04:16 : Checking Root ...OK 2014/09/24 - 04:04:16 : Phone Root OK. Continue.. 2014/09/24 - 04:04:21 : Writing IMEI A ...OK..OK..OK 2014/09/24 - 04:04:25 : Writing IMEI B ...OK..OK..OK 2014/09/24 - 04:04:25 : Repairing Network.. 2014/09/24 - 04:04:26 : Prepairing ...OK 2014/09/24 - 04:04:27 : Reading Network Settings ...OK,OK 2014/09/24 - 04:04:30 : Repairing Network...OK,OK,OK 2014/09/24 - 04:04:31 : Rebooting... OK! 2014/09/24 - 04:04:31 : Operation Completed 2014/09/24 - 04:04:31 : Operation Time: 00:00:23 |
09-24-2014, 15:22 | #356 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | 2014/09/22 - 21:22:09 : ----------------------------------------------------------------------------------------------- 2014/09/22 - 21:22:09 : Turn-on the Phone Goto 'Settings > Application > Development' 2014/09/22 - 21:22:09 : And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. 2014/09/22 - 21:22:09 : ----------------------------------------------------------------------------------------------- 2014/09/22 - 21:22:14 : Prepairing ...OK 2014/09/22 - 21:22:14 : Device Found! 2014/09/22 - 21:22:14 : Reading Phone Informations ... 2014/09/22 - 21:22:14 : 2014/09/22 - 21:22:14 : Model : GT-S7272 2014/09/22 - 21:22:14 : Android Version : 4.2.2 2014/09/22 - 21:22:14 : PDA Version : S7272XXUANC1 2014/09/22 - 21:22:14 : CS Version : S7272OJVANB1 2014/09/22 - 21:22:15 : Phone Version : S7272XXUANA1 2014/09/22 - 21:22:15 : IMEI : NULL 2014/09/22 - 21:22:22 : Checking Root Permission ...OK 2014/09/22 - 21:22:22 : Phone Root OK. Continue.. 2014/09/22 - 21:22:23 : Reading NVM ... OK 2014/09/22 - 21:22:24 : Prepairing NVM ... OK 2014/09/22 - 21:22:24 : Writing IMEI... OK 2014/09/22 - 21:22:27 : Writing Cooking NV Data ...OK 2014/09/22 - 21:22:27 : Finalizing... OK 2014/09/22 - 21:22:27 : Phone Reset Done! 2014/09/22 - 21:22:28 : Operation Completed 2014/09/22 - 21:22:28 : Operation Time: 00:00:19 |
09-24-2014, 15:23 | #357 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | 2014/09/23 - 01:05:03 : ----------------------------------------------------------------------------------------------- 2014/09/23 - 01:05:03 : Turn-on the Phone Goto 'Settings > Application > Development' 2014/09/23 - 01:05:03 : And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. 2014/09/23 - 01:05:03 : ----------------------------------------------------------------------------------------------- 2014/09/23 - 01:05:07 : Prepairing ...OK 2014/09/23 - 01:05:07 : Device Found! 2014/09/23 - 01:05:07 : Reading Phone Informations ... 2014/09/23 - 01:05:07 : 2014/09/23 - 01:05:07 : Model : GT-S7582 2014/09/23 - 01:05:07 : Android Version : 4.2.2 2014/09/23 - 01:05:07 : PDA Version : S7582DDUANA1 2014/09/23 - 01:05:08 : CS Version : NULL 2014/09/23 - 01:05:08 : Phone Version : S7582XXUANA1 2014/09/23 - 01:05:08 : IMEI 1: 355022062850701 2014/09/23 - 01:05:08 : IMEI 2: 355023062850709 2014/09/23 - 01:05:08 : Checking Root Permission ...OK 2014/09/23 - 01:05:08 : Phone Root OK. Continue.. 2014/09/23 - 01:05:09 : Reading NVM ... OK 2014/09/23 - 01:05:09 : Prepairing NVM ... OK 2014/09/23 - 01:05:09 : Writing IMEI... OK 2014/09/23 - 01:05:10 : Writing Cooking NV Data ...OK 2014/09/23 - 01:05:10 : Finalizing... OK 2014/09/23 - 01:05:10 : Phone Reset Done! 2014/09/23 - 01:05:10 : Operation Completed 2014/09/23 - 01:05:10 : Operation Time: 00:00:07 |
10-18-2014, 11:48 | #358 (permalink) |
Crazy Poster Join Date: Nov 2007
Member: 632859 Status: Offline Thanks Meter: 9 | samsung N7000 imei repair done Device Found! Reading Phone Informations ... Model : GT-N7000 Android Version : 4.1.2 PDA Version : N7000DDLSC CS Version : N7000ODDLSC Phone Version : N7000DDLS6 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable and Wait Phone Powering Up Completely (Media Scanners Passed) Then insert UART cable to Phone to Continue Delay 60 Seconds... Searching for phone on COM11 ... Phone Found Reading Data from phone... Model : GT-N7000 S/W Version : N7000DDLSC Unique ID : CVY19A2922B199E Memory ID : - IMEI : none Verifying MSL ... OK Bypassing MSL ... OK Writing IMEI ... OK Reset Done! Operation Completed Operation Time: 00:02:07 |
10-27-2014, 16:07 | #360 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Earth
Member: 6884 Status: Offline Sonork: 100.1621477 Thanks Meter: 105 | I6410 Unlock done Searching For Phone [SAMSUNG USB PORT]... OK Phone Found on COM21 Reading Phone Information ... Model : GT-I6410 Unique ID : 0010000158477K MSL Addr : R5YZ327140 Build No : M6246A-KPRZL-1.2.0035_7S IMEI : 355717034239350 PDA/CSC Version : i6410BUJI3/i6410BUJI3i Phone Version : 6410BUJA2M Reading Security Area... Calculating is Done Unlocking ... Old Security Detected ALL Lock set to : 00000000 Please Restart Your Phone to Saving New Configurations Operation Completed Operation Time: 00:03:10 |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
