10-15-2013, 13:25 | #1 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Pampanga, Philippines
Member: 1871628 Status: Offline Thanks Meter: 22 | Is it possible to flash OT-4030? Is it Possible to Flash Alcatel OT-4030D? Problem of Phone is It Just Failed the Upgrade Process VIA the Alcatel Software Update. Status of Phone as of Now results to dead set. |
10-15-2013, 13:33 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ dindincpr, Flashing is not supported for OT-4030D phone model by SigmaKey, at the moment. Alcatel OT-4030 as other supported MTK Alcatel Smartphones based on the MT657x/6589 CPUs is supported for Calculate Unlock Code by IMEI operation, as for now. P.S. In order to be able to check what phone models and operations for them are already supported refer to this link. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
10-15-2013, 13:36 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | dindincpr, have you tried repeating the operation once again with the official firmware upgrader? Couple basic tips of advice: fully charge the battery, connect phone to USB port placed on the back side of PC (motherboard's USB port), avoid hubs; close all the side programs, that may interfere with the phone. |
The Following User Says Thank You to mcandre For This Useful Post: |
10-15-2013, 14:17 | #4 (permalink) | |
Member: 1871628 Status: Offline Thanks Meter: 22 | Quote:
Fully Charge Battery and Directly Connected to USB Port Sir. | |
10-15-2013, 14:33 | #5 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | If you are a 100 percent sure that you are using the correct firmware upgrader and it refuses to flash this phone, then you may also flash this device using SP Flash Tool. |
