09-03-2013, 12:05 | #33 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Quote:
09-04-2013, 13:03 | #35 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,767 | @ Moha_Med, Direct Unlock Manual for phones that are based on MT625A, MT6219, MT6223, MT6225, MT6226, MT6235, MT6236, MT6238, MT6239, MT6250, MT6251, MT6252, MT6253, MT6268 CPU:
* MTK models have to be connected to PC COM port via original COM data cable or any COM port emulator. If you are SigmaBox owner, connect phone to PC via SigmaBox. Best Regards GSMServer team |
09-04-2013, 13:58 | #36 (permalink) |
Freak Poster Join Date: Jan 2003 Location: Tomislavgrad Bosna i hercegovi
Member: 19473 Status: Offline Thanks Meter: 12 | just tried G5520 by this instruction (((((((((((MTK models have to be connected to PC COM port via original COM data cable or any COM port emulator. If you are SigmaBox owner, connect phone to PC via SigmaBox.)))))))) yes, I've tried everything, but nothing, I used a Samsung Z3X as com C3300K cables, LG GW 300, 230 g, 290 g, 102 g, but nothing. The sigma software, select the COM where Z3X, and tried all of these cables, but nothing .. no response from sikma s / wa.klik unlock in the sigma-wu have a message press and hold pover it, but s / w is not responding, no response |
09-04-2013, 15:06 | #38 (permalink) |
Member: 19473 Status: Offline Thanks Meter: 12 | No I have not asked, but I read somewhere a pointer to one of these cables should work, although it is possible that you need to find the right pinout |
09-05-2013, 07:25 | #39 (permalink) |
Freak Poster Join Date: May 2004 Location: Proud Serbia
Member: 65352 Status: Offline Thanks Meter: 118 | as I say in previous post,problem is pinout..........i don't have pinfinder,but when i measure voltage in pins of conector only one pin is 2,75V @ sigma team Does we have confirmed unlock of huawei g5520 ? |
09-05-2013, 16:26 | #41 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Dominican Republic
Member: 1493530 Status: Offline Thanks Meter: 36 | Just tried to unlock Blu Tank (T180B) but failed, thisīs the log: SigmaKey 1.29.02 919083313 Sigma dongle 1.31, Initializing...OK --- 2013-09-04 10:52:42 --- SigmaKey 1.29.02 MTK: Get unlock codes Prolific USB-to-Serial Bridge (COM10), Provider: Prolific, Driver ver.: 2.0.0.24, Date: 01/12/2003, USB\Vid_067b&Pid_2303&Rev_0300 Baud rate: 115200 Release "Power on" button! Baseband Processor: MT6250, HW Rev. A.05, SW Rev. 1.01 Serial number: F29D447CDC169B04F29D447CDC169B04 Testing external RAM...4 Mb Detecting flash...SPI, ID: 00EF4015-00000000 Flash size: 2 Mb, block size: 4 Kb File system: 168 Kb @ 001D6000 Firmware: TINNO52_10A_GEMINI16_PCB01_GSM_MT6252_S01.T1050A_M P_F3_BLU_VIVA_01_13 Hardware IMEI: Not found Software IMEI: Not found Mounting system disk...Failed to decrypt phone data --- 2013-09-04 11:04:46 --- SigmaKey 1.29.02 MTK: Direct unlock Prolific USB-to-Serial Bridge (COM10), Provider: Prolific, Driver ver.: 2.0.0.24, Date: 01/12/2003, USB\Vid_067b&Pid_2303&Rev_0300 Baud rate: 115200 Release "Power on" button! Baseband Processor: MT6250, HW Rev. A.05, SW Rev. 1.01 Serial number: F29D447CDC169B04F29D447CDC169B04 Testing external RAM...4 Mb Detecting flash...SPI, ID: 00EF4015-00000000 Flash size: 2 Mb, block size: 4 Kb File system: 168 Kb @ 001D6000 Firmware: TINNO52_10A_GEMINI16_PCB01_GSM_MT6252_S01.T1050A_M P_F3_BLU_VIVA_01_13 Hardware IMEI: Not found Software IMEI: Not found Mounting system disk...Failed to decrypt phone data Then read backup for u guys to check it out: --- 2013-09-04 11:05:56 --- SigmaKey 1.29.02 MTK: Read backup Prolific USB-to-Serial Bridge (COM10), Provider: Prolific, Driver ver.: 2.0.0.24, Date: 01/12/2003, USB\Vid_067b&Pid_2303&Rev_0300 Baud rate: 115200 Release "Power on" button! Baseband Processor: MT6250, HW Rev. A.05, SW Rev. 1.01 Serial number: F29D447CDC169B04F29D447CDC169B04 Testing external RAM...4 Mb Detecting flash...SPI, ID: 00EF4015-00000000 Flash size: 2 Mb, block size: 4 Kb File system: 168 Kb @ 001D6000 Firmware: TINNO52_10A_GEMINI16_PCB01_GSM_MT6252_S01.T1050A_M P_F3_BLU_VIVA_01_13 Hardware IMEI: Not found Software IMEI: Not found Reading calibration data...Skipped "F29D447CDC169B04F29D447CDC169B04_TINNO52_10A_GEMI NI16_PCB01_GSM_MT6252_S01_T1050A_MP_F3_BLU_VIVA_01 _13.skb" saved, 1.89 Mb Blu Tank 180B - Download - 4shared tried to Backup calibration but failed too: --- 2013-09-04 11:08:17 --- SigmaKey 1.29.02 MTK: Backup calibration data Prolific USB-to-Serial Bridge (COM10), Provider: Prolific, Driver ver.: 2.0.0.24, Date: 01/12/2003, USB\Vid_067b&Pid_2303&Rev_0300 Baud rate: 115200 Release "Power on" button! Baseband Processor: MT6250, HW Rev. A.05, SW Rev. 1.01 Serial number: F29D447CDC169B04F29D447CDC169B04 Testing external RAM...4 Mb Detecting flash...SPI, ID: 00EF4015-00000000 Flash size: 2 Mb, block size: 4 Kb File system: 168 Kb @ 001D6000 Firmware: TINNO52_10A_GEMINI16_PCB01_GSM_MT6252_S01.T1050A_M P_F3_BLU_VIVA_01_13 Hardware IMEI: Not found Software IMEI: Not found Mounting system disk...Failed to decrypt phone data |
