10-29-2013, 16:48 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: iran-tehran Age: 41
Member: 742476 Status: Offline Thanks Meter: 40 | can i write file (6820/8810) can i write this file in the phone or change the file to pac file? |
10-29-2013, 19:25 | #2 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | you can not change bin to pac first read info must need then try write flash file and please always post screenshot |
10-30-2013, 08:37 | #3 (permalink) |
Member: 742476 Status: Offline Thanks Meter: 40 | here is the info my phone and error in write bin file in the phone Code: Volcano Updated: 2013-10-25 Connecting... Connection successful,connected state! Version: V3.8 SN:479-830-261 Port:COM4 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Available Ports:COM1 COM4 Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 6.49 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4 Setting... Find USB device:SCI USB2Serial (COM5), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC8810/6820 [88100001] Flash ID: 002C00BC90555600 Flash Type:[Micron] MT29C4G48MAZAPAKD FLASH LEN:0x20000000 mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjaluna),10m(modem),3840k(fixnv),3840k(backupfixnv),5120k(dsp),3840k(runtimenv),10m(boot),10m(recovery),227m(system),158m(userdata),60m(cache),256k(misc),1m(boot_logo),1m(fastboot_logo),3840k(productinfo),512k(kpanic),512k(simlock),5m(intmemory) Analysis flash internal data successfully. Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 5.99 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4 Setting... Find USB device:SCI USB2Serial (COM5), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. Flash ID: 002C00BC90555600 Flash Type:[Micron] MT29C4G48MAZAPAKD FLASH LEN:0x20000000 Please read the phone partition. >>Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. |
10-30-2013, 10:10 | #4 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Brother Post Screenshot Select Boot 14 Then Read Info After Try Write Flash If Same Flash With Pac File , Find On Google Or Read With Volcano To Factory Format Then Make Pac File Br, AzimBahar |
03-09-2014, 16:23 | #5 (permalink) |
Junior Member Join Date: Nov 2008
Member: 913338 Status: Offline Thanks Meter: 6 | my phone have hang when go to menu and my phone hang very very after cft calibration with volcano was hang on logo Boot downloaded. CPU TYPE:SC8810/6820 [88100001] Flash ID: 002C00BC90555600 Flash Type:[Micron] MT29C4G48MAZAPAKD FLASH LEN:0x20000000 mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjal una),10m(modem),3840k(fixnv),3840k(backupfixnv),51 20k(dsp),3840k(runtimenv),10m(boot),10m(recovery), 227m(system),158m(userdata),60m(cache),256k(misc), 1m(boot_logo),1m(fastboot_logo),3840k(productinfo) ,512k(kpanic),512k(simlock),5m(intmemory) >>Analysis flash internal data successfully. spd 6820 model ccit z6 ples pac file |
03-10-2014, 17:19 | #7 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | @ trt ... Whats your phone status ....? Why you post in old thread...? Post a new Thread with details about the Phone ...!! Br, AniAXN |
The Following User Says Thank You to AniAxn For This Useful Post: |
