10-30-2014, 07:39 | #4836 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Hi-Tech HT-4000i Spd6531 Dead Recover by Volcano .. Code: Volcano Updated: 2014-06-28 Connecting... Connection successful,connected state! Version: V3.8 SN:xxxxxxxxxx Port:COM4 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Available Ports:COM1 COM4 Current Port:COM4 For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: null Gnd: 5 Detection initiated... D+ = 3, D- = 2 Detection D+/D- with 0.86 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4 Detection completed. Setting pinouts... Pinout setting complete. Reset USB device and search it... Find USB device:SPRD U2S Diag (COM7), (VID_1782&PID_4D00) Available Ports:COM1 COM4 COM7 Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310000] FLASH ID: 00EF004000160000 Flash Type:[WinBond] W25Q32BV Size:0x400000(4MB) Reading completed. Reset USB device and search it... Find USB device:SPRD U2S Diag (COM7), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310000] FLASH ID: 00EF004000160000 Flash Type:[WinBond] W25Q32BV Size:0x400000(4MB) Set to Factory successfully. Reset USB device and search it... Find USB device:SPRD U2S Diag (COM7), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310000] FLASH ID: 00EF004000160000 Flash Type:[WinBond] W25Q32BV Size:0x400000(4MB) Writing completed. Flash file C:\Documents and Settings\AniAXN\Desktop\tmp_6.bin has been written. Reset USB device and search it... Find USB device:SPRD U2S Diag (COM7), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310000] FLASH ID: 00EF004000160000 Flash Type:[WinBond] W25Q32BV Size:0x400000(4MB) >>Set to Factory successfully. Wbr, AniAXN |
11-02-2014, 17:17 | #4838 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | SAMSUNG GT I5503T PATTERN UNLOICKED WITH VOLCANO BOX Connect the device successfully, the information of the device is as follows: Model: GT-I5503T Android version: 2.1-update1 Baseband: I5503TAJJI2 IMEI1: 353845040659113 The above information is for reference only. Device found. Have been Su Rooted. Being cleared, please wait... >>Clear OK, device is restartting. |
11-02-2014, 17:17 | #4839 (permalink) |
11-03-2014, 08:39 | #4840 (permalink) |
Banned Join Date: Apr 2014
Member: 2161559 Status: Offline Sonork: 100.1640804 Thanks Meter: 2 | Detection initiated, connect the phone and power on it... Vcc: null Gnd: null RX: 4, TX: 6 Connecting... Hardware version:CA01 Software version:0001 CPU TYPE:625A Internal version:8000 Boot downloading complete! Flash ID: 00EF006000180000 Chip Capacity: 0x1000000(16MB) Baud adjust...complete. Format range: Start Address: 0xD60000,Format Length :0x290000 >>Flash erasing complete! |
11-04-2014, 10:54 | #4841 (permalink) |
Member: 1614640 Status: Offline Thanks Meter: 468 | Port:COM28 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Available Ports:COM28 Current Port:COM28 Connect the device successfully, the information of the device is as follows: Model: H830 Android version: 4.1.1 Baseband: DM_BASE_12A_W12.43|sc6820_modem|11-02-2012 17:53:08 IMEI1: 352709200165439 The above information is for reference only. Device found. Have been Su Rooted. Being cleared, please wait... >>Clear OK, device is restartting. |
11-04-2014, 10:54 | #4842 (permalink) |
11-06-2014, 13:58 | #4844 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Chinese HTM SPD Mobile Too Many Pattern lock reset done Volcano Updated: 2014-10-13 Connecting... Connection successful,connected state! Version: V3.8 SN:619-078-953 Port:COM8 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Available Ports:COM8 Current Port:COM8 Available Ports:COM7 COM8 failed to open port. Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. Flash ID: 00AD00BC90555600 Flash Type:[Hyundai] NAND_HY27UT088G2A FLASH LEN:0x20000000 Reading...(0) Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. Waiting for phone's response, press the Power on the phone Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. Flash ID: 00AD00BC90555600 Flash Type:[Hyundai] NAND_HY27UT088G2A FLASH LEN:0x20000000 mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjal una),10m(modem),3840k(fixnv),3840k(backupfixnv),51 20k(dsp),3840k(runtimenv),10m(boot),10m(recovery), 200m(system),180m(userdata),60m(cache),256k(misc), 1m(boot_logo),1m(fastboot_logo),3840k(productinfo) ,512k(kpanic),512k(simlock),10m(intmemory) Analysis flash internal data successfully. Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjal una),10m(modem),3840k(fixnv),3840k(backupfixnv),51 20k(dsp),3840k(runtimenv),10m(boot),10m(recovery), 200m(system),180m(userdata),60m(cache),256k(misc), 1m(boot_logo),1m(fastboot_logo),3840k(productinfo) ,512k(kpanic),512k(simlock),10m(intmemory) Analysis flash internal data successfully. >>Set to Factory successfully. |
11-06-2014, 13:59 | #4845 (permalink) |
