04-05-2015, 05:05 | #1 (permalink) |
Crazy Poster Join Date: Sep 2014
Member: 2260630 Status: Offline Thanks Meter: 11 | Samsung read info ERROR - VolcanoBox I have GT-S5839I that works fine , i just wanted to test it on my new box and here is the log =============================== For unlock need to enable ADB. For "Read Info" button , select phone modem or use rj45 cable. For "Pattern Unlock" button , select phone modem or use rj45 cable. Version over "4.X.X is not supported for pattern unlock. Model Selected : GT-S5839I Reading Phone Info... Phone Found. Phone DATE : xp~CDMG Phone model : G ERRO Phone product code : Phone version : -CDMG ERRO/ Phone Imei : Reading info finish. >>=============================== Any other tool can read info easily for this simple model , is it a problem in my box or what ? I enabled ADB and i'm using the original USB cable, tested even on the latest Volcano 3.0.0. In my way trying to solve this i noticed that ADB.exe doesn't launch , is that normal ? Ps: every other tab works fine , other mobile phones except Samsung are working OK. used latest samsung drivers too. thank you. |
04-05-2015, 05:19 | #2 (permalink) | |
No Life Poster Join Date: Jan 2014 Location: Pakistan Age: 26
Member: 2105681 Status: Offline Sonork: Stoped Using... Thanks Meter: 909 | post screen short. Try with older version 2.5.0 or 2.7.2 and post results. Quote:
The Following User Says Thank You to masterRt1994 For This Useful Post: |
04-05-2015, 23:23 | #6 (permalink) | |
Member: 2105681 Status: Offline Sonork: Stoped Using... Thanks Meter: 909 | Whats is problem in phone ? plz provide more details u can also read info in android in adb mode . use volcANO VERSION 3.0.0 [LATEST] ,check drivers,choose correct model,if still u get any eror post detail with screen shot (tool version showing) here. Quote:
