Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 05-28-2013, 11:21   #1 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
blackberry 9380 initialisation failed done
make this jumber
The Following 8 Users Say Thank You to mohit_kripalu01 For This Useful Post:
Old 05-28-2013, 13:28   #2 (permalink)
chubbie's Avatar
Member: 281801
Sonork: 100.1608672
Thanks Meter: 158
please, I need solution for Torch 1 9800 Initialization failed
Bold 6 9790 cal mode (safemode)
Old 05-28-2013, 13:47   #3 (permalink)
Member: 1812725
Thanks Meter: 17
pls i need solution for blacberry 9380 curv softtouch phone i want to unlock it i have the code now but phone can not display where to enter unlock code samobody help me pls
[IMG]http://www.google.com.gh/imgres?*****l=http://cdn0.mos.techradar.futurecdn.net///Review%2520images/TechRadar/Mobile%2520phones/BlackBerry/BlackBerry%2520Curve%25209380/pr/9380Curve_Front%2520main-380-75.jpg&imgrefurl=http://www.techradar.com/reviews/phones/mobile-phones/blackberry-curve-9380-1042738/review&h=285&w=380&sz=10&tbnid=AbjCqAW4398YdM:&tbn h=90&tbnw=120&prev=/search%3Fq%3Dblackberry%2B9380%26tbm%3Disch%26tbo% 3Du&zoom=1&q=blackberry+9380&usg=__pTpxCF9rFVPkj0j E0LUPXVHXkl0=&docid=cQZjEw_EiLGUYM&sa=X&ei=9aakUab DGYHX7AbJVw&ved=0CC4Q9QEwAQ&dur=3040[/IMG]
Old 05-29-2013, 06:15   #4 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
2. Turn the BlackBerry Curve handset on.
3. On the front menu on the 9380, go to the SETTINGS MENU – then to OPTIONS
4. Select ADVANCED OPTIONS, and then SIM CARD
5. A personalization screen will appear.
6. Type MEPD using the keyboard on the Blackberry 9380 (What you type (MEPD) will not show on the Blackberry’s screen)
7. Type MEP, then press the ALT Button and press 2 on the keyboard of your Blackberry Curve 9380. (What you type (MEP {alt} 2) will not show on the Blackberry screen)
1) Insert any SIM card and turn off all wireless connections
2) Go to Options -> Device -> Advanced System Settings -> Sim Card
2) Hold down the 123 key it will switch to the numeric keyboard with ALT locked down now type the letters "mepe" (without the quotes, you will not see anything on the screen when typing)
3) Once you see the Personalization Screen Press and Hold the ALT key and type MEP2 (you will not see anything on the screen when typing).
Old 05-29-2013, 12:16   #5 (permalink)
Member: 179302
Thanks Meter: 3
bro
i did jumper as above for 9380 sim started working and after few minutes
network gone and on screen massage came sim error and then i restarted
it and agian works for few minutes then simerror ,i tried to remove both capacitor bot same problem when i remove jumper then intilistion failed
Old 05-29-2013, 12:38   #6 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
Originally Posted by pankajgarg View Post
bro
try change the big black ic
Old 05-29-2013, 13:19   #7 (permalink)
Member: 218014
What a wonderful job!?! You made it great! The solution works 100%. Please, cpme back with other great perfect solutions!
Old 05-29-2013, 15:42   #8 (permalink)
Member: 179302
Thanks Meter: 3
any other phone have same ic i do not have 9380 one more
Old 05-30-2013, 09:28   #9 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
i think U can find it @ 9790,z10
Old 05-30-2013, 11:05   #10 (permalink)
wawan tato's Avatar
Member: 1774307
Thanks Meter: 224
also you can find in 9900, 9930
Old 05-31-2013, 11:01   #11 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
try to flash your phone this file
9380alllang_pbr7.0.0_rel2113_pl9.32.0.40_a7.0.0.48 2_thai(BB_EASY)
http://forum.gsmhosting.com/vbb/f489...8/index24.html
Old 06-03-2013, 07:17   #12 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
for next trouble change the ic U2001(black ic) and check FL1800 (sim ic)
Old 07-30-2013, 11:14   #13 (permalink)
Member: 1984444
Sonork: forty28
blackberry 9380 error sim card, initialisation failed help mke jamper ??
Old 07-30-2013, 17:45   #14 (permalink)
wawan tato's Avatar
Member: 1774307
Thanks Meter: 224
Try This .. n don forget to POST the result ..
The Following User Says Thank You to wawan tato For This Useful Post:
Old 08-29-2013, 23:33   #15 (permalink)
Member: 740792
Sonork: raja7866
Thanks Meter: 7
Arrow blackberry 9380 initialisation failed 100%
Postimage.org / gallery - untitled, url
Page generated in 0.20293 seconds with 8 queries
