11-27-2012, 17:27 | #1 (permalink) |
Junior Member Join Date: Aug 2009 Location: Ukraine Age: 55
Member: 1101186 Status: Offline Thanks Meter: 0 | McnPro light Box problem (->ANSWERDE) 18:12:25 Welcome to use McnPro light Box 18:12:25 Baud setting ... 18:12:26 Set Baud done 18:12:26 SW V12.20 18:12:26 FW 3,09 18:12:26 SN 18:12:26 AC 18:12:26 Box Connected! 18:12:29 Chip Scaning,Press and HOLD Power button now ! 18:12:29 <<..#.. 18:12:36 CPU: MT6226BA 18:12:36 pinouts: Rx:1 Tx:3 Gnd:10 18:12:38 Pinout Applied 18:12:48 Pinout Applied 18:12:48 Press and HOLD Power button now 18:12:51 None MW 18:12:51 CPUЈєMT6226 Ver: 8A02 SW:8A01 18:13:01 Device enter test mode,error 18:13:01 Maybe PC USB power not enough |
11-29-2012, 02:29 | #2 (permalink) |
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | try adjust baud rate speed & change boot ... |
The Following User Says Thank You to MARVZ_TG For This Useful Post: |
11-30-2012, 11:44 | #3 (permalink) |
Member: 1101186 Status: Offline Thanks Meter: 0 | I've included all of the download speed. The same result. When the phone is placed in test mode, its consumption increases to 1 ampere. The same happens on other phones. This is a faulty box? Or is it a software glitch on the manufacturer? |
11-30-2012, 11:49 | #4 (permalink) | |
Product Manager Join Date: Mar 2008
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Quote:
We will post new upgrade tomorrow if ready, hope you can give a report once you test ! Best regards ! Mcnbox | |
The Following 3 Users Say Thank You to Mcnbox For This Useful Post: |
12-02-2012, 22:29 | #5 (permalink) |
Member: 1101186 Status: Offline Thanks Meter: 0 | Thank you. Very good update. Search pins and connection via USB cable is much better. Works well with the CPU: MT625Ayu But there's a problem, I can not be authorized for support. I keep getting the answer: Sorry, Please double confirm the serial number and activation code. Box serial number and activation code did not match. The serial number and activation code already activated by other member. The serial number and activation code did not found in database. Tell me, how do I get the product activation? |
