Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
06-09-2012, 11:20 | #1 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Turkey
Member: 1058593 Status: Offline Sonork: 100.1625725 Thanks Meter: 433 | [Guide] Samsung GT-I9100G - usb boot repair phone mustbe off connect phone without battery and use usb_drv_windows this driver than run this bat file omap4430hs_espresso_1200MHZ and wait 20 30 sec phone will aliwe again Last edited by axecom; 11-26-2014 at 15:32. Reason: replaced link with direct one without password |
The Following 46 Users Say Thank You to R3İS For This Useful Post: |
06-09-2012, 12:03 | #6 (permalink) |
Freak Poster Join Date: May 2012 Location: AsanSam-inG!
Member: 1754434 Status: Offline Sonork: 100.1603928 Thanks Meter: 41 | Code: Driver configuration: rpapi_base = 0x00028400 MMC sid = 0x01 MMC mmc_volt = 0x01 MMC data_width = 0x04 MMC card_rca = 0x04 MMC card_type = 0x03 MMC data_width_support = 0x08 MMC transfer_clk_max = 0xBB80 MMC card_size = 0x1D5A000 eMMC CID MID = 0x15 // Manufacturer ID eMMC CID CBX = 0x01 // Card/BGA eMMC CID OID = 0x00 // OEM/Application ID eMMC CID PNM = 0x70280000BE01 // Product name eMMC CID PRV = 0x19 // Product revision eMMC CID PSN = 0x0000BE01 // Product serial number eMMC CID MDT = 0xBE // Manufacturing date eMMC CID CRC = 0x00 // CRC7 checksum eMMC CSD CSD_STRUCTURE = 0x03 // CSD structure eMMC CSD SPEC_VERS = 0x04 // System specification version eMMC CSD TAAC = 0x27 // Data read access-time 1 eMMC CSD NSAC = 0x01 // Data read access-time 2 in CLK cycles (NSAC*100) eMMC CSD TRAN_SPEED = 0x32 // Max. bus clock frequency eMMC CSD CCC = 0x00F5 // Card command classes eMMC CSD READ_BL_LEN = 0x09 // Max. read data block length eMMC CSD READ_BL_PARTIAL = 0x00 // Partial blocks for read allowed eMMC CSD WRITE_BLK_MISALIGN = 0x00 // Write block misalignment eMMC CSD READ_BLK_MISALIGN = 0x00 // Read block misalignment eMMC CSD DSR_IMP = 0x00 // DSR implemented eMMC CSD C_SIZE = 0x00FF // Device size eMMC CSD VDD_R_CURR_MIN = 0x06 // Max. read current @ VDD min eMMC CSD VDD_R_CURR_MAX = 0x06 // Max. read current @ VDD max eMMC CSD VDD_W_CURR_MIN = 0x06 // Max. write current @ VDD min eMMC CSD VDD_W_CURR_MAX = 0x06 // Max. write current @ VDD max eMMC CSD C_SIZE_MULT = 0x01 // Device size multiplier eMMC CSD ERASE_GRP_SIZE = 0x1F // Erase group size eMMC CSD ERASE_GRP_MULT = 0x1F // Erase group size multiplier eMMC CSD WP_GRP_SIZE = 0x0F // Write protect group size eMMC CSD WP_GRP_ENABLE = 0x01 // Write protect group enable eMMC CSD DEFAULT_ECC = 0x00 // Manufacturer default ECC eMMC CSD R2W_FACTOR = 0x02 // Write speed factor eMMC CSD WRITE_BL_LEN = 0x09 // Max. write data block length eMMC CSD WRITE_BL_PARTIAL = 0x00 // Partial blocks for write allowed eMMC CSD CONTENT_PROT_APP = 0x00 // Content protection application eMMC CSD FILE_FORMAT_GRP = 0x00 // File format group eMMC CSD COPY = 0x01 // Copy flag (OTP) eMMC CSD PERM_WRITE_PROTECT = 0x00 // Permanent write protection eMMC CSD TMP_WRITE_PROTECT = 0x00 // Temporary write protection eMMC CSD FILE_FORMAT = 0x00 // File format eMMC CSD ECC = 0x00 // ECC code eMMC CSD CRC = 0x33 // CRC eMMC EXT_CSD S_CMD_SET = 0x00 // Supported Command Sets eMMC EXT_CSD BOOT_INFO = 0x15 // Boot information eMMC EXT_CSD BOOT_SIZE_MULTI = 0x0A // Boot partition size eMMC EXT_CSD ACC_SIZE = 0x07 // Access size eMMC EXT_CSD HC_ERASE_GRP_SIZE = 0x00 // High-capacity erase unit size eMMC EXT_CSD ERASE_TIMEOUT_MULT = 0x04 // High-capacity erase timeout eMMC EXT_CSD REL_WR_SEC_C = 0x07 // Reliable write sector count eMMC EXT_CSD HC_WP_GRP_SIZE = 0x01 // High-capacity write protect group size eMMC EXT_CSD S_C_VCC = 0x01 // Sleep current (VCC) eMMC EXT_CSD S_C_VCCQ = 0x01 // Sleep current (VCCQ) eMMC EXT_CSD S_A_TIMEOUT = 0x07 // Sleep/awake timeout eMMC EXT_CSD SEC_COUNT = 0x01D5A000 // Sector Count eMMC EXT_CSD MIN_PERF_W_8_52 = 0xA0 // Minimum Write Performance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_52 = 0x00 // Minimum Read Performance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_W_8_26_4_52 = 0x00 // Minimum Write Performance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_26_4_52 = 0x00 // Minimum Read Performance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_W_4_26 = 0x00 // Minimum Write Performance for 4bit at 26MHz eMMC EXT_CSD MIN_PERF_R_4_26 = 0x00 // Minimum Read Performance for 4bit at 26MHz eMMC EXT_CSD PWR_CL_26_360 = 0x00 // Power class for 26MHz at 3.6V eMMC EXT_CSD PWR_CL_52_360 = 0x00 // Power class for 52MHz at 3.6V eMMC EXT_CSD PWR_CL_26_195 = 0x00 // Power class for 26MHz at 1.95V eMMC EXT_CSD PWR_CL_52_195 = 0x00 // Power class for 52MHz at 1.95V eMMC EXT_CSD CARD_TYPE = 0x01 // Card type eMMC EXT_CSD CSD_STRUCTURE = 0x00 // CSD structure version eMMC EXT_CSD EXT_CSD_REV = 0x00 // Extended CSD revision eMMC EXT_CSD CMD_SET = 0x02 // Command set eMMC EXT_CSD CMD_SET_REV = 0x05 // Command set revision eMMC EXT_CSD POWER_CLASS = 0x00 // Power class eMMC EXT_CSD HS_TIMING = 0x00 // High-speed interface timing eMMC EXT_CSD BUS_WIDTH = 0x00 // Bus width mode eMMC EXT_CSD ERASED_MEM_CONT = 0x00 // Erased memory content eMMC EXT_CSD BOOT_CONFIG = 0x00 // Boot configuration eMMC EXT_CSD BOOT_BUS_WIDTH = 0x00 // Boot bus width1 eMMC EXT_CSD ERASE_GROUP_DEF = 0x00 // High-density erase group definition EMMC eMMC DRIVER INIT COMPLETE » Downloading complete » Elapsed time: 0:02.203 (21430 bytes/s) » End loading driver » Downloading » Downloading 'Targets\Projects\espresso\MLO.hs' » Sending data (262144 bytes) :::::::::::::::::::: [262144] » Downloading complete » Elapsed time: 0:00.281 (932896 bytes/s) » Looking for a driver for 'EMMC' » chip_driver EMMC Targets\Flash-Drivers\emmc_drv.bin sid 1 width 4 delay 9 rpapi_base 0x00028400 » Downloading driver EMMC eMMC DRIVER DEINIT COMPLETE » Downloading 'Targets\Flash-Drivers\emmc_drv.bin' » Sending data (47160 bytes) :::::::::::::::::::: [47160] Interface 'OMAPFLASH DRIVER v6' Driver 'eMMC JESD84-A43' Driver configuration: sid = 0x00000001 Driver configuration: width = 0x00000004 Driver configuration: delay = 0x00000009 Driver configuration: rpapi_base = 0x00028400 MMC sid = 0x01 MMC mmc_volt = 0x01 MMC data_width = 0x04 MMC card_rca = 0x04 MMC card_type = 0x03 MMC data_width_support = 0x08 MMC transfer_clk_max = 0xBB80 MMC card_size = 0x1D5A000 eMMC CID MID = 0x15 // Manufacturer ID eMMC CID CBX = 0x01 // Card/BGA eMMC CID OID = 0x00 // OEM/Application ID eMMC CID PNM = 0x70280000BE01 // Product name eMMC CID PRV = 0x19 // Product revision eMMC CID PSN = 0x0000BE01 // Product serial number eMMC CID MDT = 0xBE // Manufacturing date eMMC CID CRC = 0x00 // CRC7 checksum eMMC CSD CSD_STRUCTURE = 0x03 // CSD structure eMMC CSD SPEC_VERS = 0x04 // System specification version eMMC CSD TAAC = 0x27 // Data read access-time 1 eMMC CSD NSAC = 0x01 // Data read access-time 2 in CLK cycles (NSAC*100) eMMC CSD TRAN_SPEED = 0x32 // Max. bus clock frequency eMMC CSD CCC = 0x00F5 // Card command classes eMMC CSD READ_BL_LEN = 0x09 // Max. read data block length eMMC CSD READ_BL_PARTIAL = 0x00 // Partial blocks for read allowed eMMC CSD WRITE_BLK_MISALIGN = 0x00 // Write block misalignment eMMC CSD READ_BLK_MISALIGN = 0x00 // Read block misalignment eMMC CSD DSR_IMP = 0x00 // DSR implemented eMMC CSD C_SIZE = 0x00FF // Device size eMMC CSD VDD_R_CURR_MIN = 0x06 // Max. read current @ VDD min eMMC CSD VDD_R_CURR_MAX = 0x06 // Max. read current @ VDD max eMMC CSD VDD_W_CURR_MIN = 0x06 // Max. write current @ VDD min eMMC CSD VDD_W_CURR_MAX = 0x06 // Max. write current @ VDD max eMMC CSD C_SIZE_MULT = 0x01 // Device size multiplier eMMC CSD ERASE_GRP_SIZE = 0x1F // Erase group size eMMC CSD ERASE_GRP_MULT = 0x1F // Erase group size multiplier eMMC CSD WP_GRP_SIZE = 0x0F // Write protect group size eMMC CSD WP_GRP_ENABLE = 0x01 // Write protect group enable eMMC CSD DEFAULT_ECC = 0x00 // Manufacturer default ECC eMMC CSD R2W_FACTOR = 0x02 // Write speed factor eMMC CSD WRITE_BL_LEN = 0x09 // Max. write data block length eMMC CSD WRITE_BL_PARTIAL = 0x00 // Partial blocks for write allowed eMMC CSD CONTENT_PROT_APP = 0x00 // Content protection application eMMC CSD FILE_FORMAT_GRP = 0x00 // File format group eMMC CSD COPY = 0x01 // Copy flag (OTP) eMMC CSD PERM_WRITE_PROTECT = 0x00 // Permanent write protection eMMC CSD TMP_WRITE_PROTECT = 0x00 // Temporary write protection eMMC CSD FILE_FORMAT = 0x00 // File format eMMC CSD ECC = 0x00 // ECC code eMMC CSD CRC = 0x33 // CRC eMMC EXT_CSD S_CMD_SET = 0x00 // Supported Command Sets eMMC EXT_CSD BOOT_INFO = 0x15 // Boot information eMMC EXT_CSD BOOT_SIZE_MULTI = 0x0A // Boot partition size eMMC EXT_CSD ACC_SIZE = 0x07 // Access size eMMC EXT_CSD HC_ERASE_GRP_SIZE = 0x00 // High-capacity erase unit size eMMC EXT_CSD ERASE_TIMEOUT_MULT = 0x04 // High-capacity erase timeout eMMC EXT_CSD REL_WR_SEC_C = 0x07 // Reliable write sector count eMMC EXT_CSD HC_WP_GRP_SIZE = 0x01 // High-capacity write protect group size eMMC EXT_CSD S_C_VCC = 0x01 // Sleep current (VCC) eMMC EXT_CSD S_C_VCCQ = 0x01 // Sleep current (VCCQ) eMMC EXT_CSD S_A_TIMEOUT = 0x07 // Sleep/awake timeout eMMC EXT_CSD SEC_COUNT = 0x01D5A000 // Sector Count eMMC EXT_CSD MIN_PERF_W_8_52 = 0xA0 // Minimum Write Performance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_52 = 0x00 // Minimum Read Performance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_W_8_26_4_52 = 0x00 // Minimum Write Performance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_26_4_52 = 0x00 // Minimum Read Performance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_W_4_26 = 0x00 // Minimum Write Performance for 4bit at 26MHz eMMC EXT_CSD MIN_PERF_R_4_26 = 0x00 // Minimum Read Performance for 4bit at 26MHz eMMC EXT_CSD PWR_CL_26_360 = 0x00 // Power class for 26MHz at 3.6V eMMC EXT_CSD PWR_CL_52_360 = 0x00 // Power class for 52MHz at 3.6V eMMC EXT_CSD PWR_CL_26_195 = 0x00 // Power class for 26MHz at 1.95V eMMC EXT_CSD PWR_CL_52_195 = 0x00 // Power class for 52MHz at 1.95V eMMC EXT_CSD CARD_TYPE = 0x01 // Card type eMMC EXT_CSD CSD_STRUCTURE = 0x00 // CSD structure version eMMC EXT_CSD EXT_CSD_REV = 0x00 // Extended CSD revision eMMC EXT_CSD CMD_SET = 0x02 // Command set eMMC EXT_CSD CMD_SET_REV = 0x05 // Command set revision eMMC EXT_CSD POWER_CLASS = 0x00 // Power class eMMC EXT_CSD HS_TIMING = 0x00 // High-speed interface timing eMMC EXT_CSD BUS_WIDTH = 0x00 // Bus width mode eMMC EXT_CSD ERASED_MEM_CONT = 0x00 // Erased memory content eMMC EXT_CSD BOOT_CONFIG = 0x00 // Boot configuration eMMC EXT_CSD BOOT_BUS_WIDTH = 0x00 // Boot bus width1 eMMC EXT_CSD ERASE_GROUP_DEF = 0x00 // High-density erase group definition EMMC eMMC DRIVER INIT COMPLETE » Downloading complete » Elapsed time: 0:01.843 (26200 bytes/s) » End loading driver » Downloading » Downloading 'Targets\Projects\espresso\Sbl.bin' » Sending data (1310720 bytes) :::::::::::::::::::: [1310720] » Downloading complete » Elapsed time: 0:00.938 (1397356 bytes/s) » cold_sw_reset » Elapsed time: 0:11.812 Appuyez sur une touche pour continuer... BR Asangsm team |
06-09-2012, 12:51 | #7 (permalink) |
Junior Member Join Date: Apr 2012
Member: 1752435 Status: Offline Thanks Meter: 1 | I have a dead i9250m galaxy nexus Below I will copy the result of the tool..when I use the tuna one the omap connects and disconnects quickly..when i use the one for i9000 the omap stays connected longer..I think i need different configurations some how..any hep would be appreciated..been trying to deal with this issue for some time: I will copy the tuna log below where the one for i9000 no second found and i tried to use other seconds no luck: » OMAPFlash v4.15 (Aug 12 2011) » -v » Entering parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.txt at line : 1 » -omap 4 » -t 36000 » -p OMAP4460_TUNA_8G_HS_PRO » -2 » -rxtx_trace » chip_download EMMC Targets\Projects\tuna\MLO_4460_HS_PRO » chip_download EMMC Targets\Projects\tuna\sbl.img » command cold_sw_reset » Leaving parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.txt » @Targets\Projects\tuna\omap4460_tuna_hs_pro.txt » Looking for device (omap usb) » Please turn on device » Waiting for device (omap usb) » Found device (omap usb) » Requesting ASIC id 00130-000-TX 4 raw bytes: 03 00 03 F0 '????' » AsicId items 05 » AsicId id 01 05 01 44 40 07 01 » AsicId secure_mode 13 02 01 00 » AsicId public_id 12 15 01 97 1E D2 40 84 FC E8 16 AA 20 26 62 0C 90 E0 83 26 88 80 7B » AsicId root_key_hash 14 21 01 67 98 9B 35 54 CC 86 B4 67 32 47 05 36 74 E2 25 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC » AsicId checksum 15 09 01 22 9E 85 BA DC 58 74 BC 00130-001-TX 4 raw bytes: 02 00 03 F0 '????' » Searching 2nd for: OMAP4460_TUNA_8G_HS_PRO 444007 01 HS » Loading second file Targets/2nd-Downloaders/dnld_startup_omap4_hs_8g_es2.s2.si gned.2nd.hs_pro » Entering parameter filemapflash2nd.txt at line: 46 » -pheriphalboot_reopen » Reading board configuration file Targets\Configurations\configuration_omap4460 _tuna_8g.txt » Reading definition file .\targets\definitions\definitions_omap4.txt » -board_config Targets\Configurations\configuration_omap4460_tuna_8g.txt » Leaving parameter filemapflash2nd.txt » Sending size of second file (0x000071B0 bytes) 00130-002-TX 4 raw bytes: B0 71 00 00 '?q??' » Transferring second file to target (0x71B0 bytes) 00130-003-TX 29104 raw bytes: B0 1C 00 00 00 4D 00 00 00 00 00 00 00 00 00 00 '?????M??????????' ... » Closing boot connection » Waiting for device (omap usb) » Found device (omap usb) » Waiting for 2nd 00463-004-TX ACK 00571-005-RX: 4 raw bytes: 70 EC 8F 00 'p???' » Unknown status message 'p???' during peripheral boot (waiting for 2nd) Press any key to continue . . . -------------- thanx for your support..I posted on the main post by ligejja and got no help there.. |
06-09-2012, 13:24 | #9 (permalink) | |
Member: 1752435 Status: Offline Thanks Meter: 1 | Quote:
06-09-2012, 13:57 | #10 (permalink) |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,715 | @ ...:::JamalMustafa:::... Hey...! Your link is Broken.. Plz Check link. |
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post: |
Nokia "Contact Service" Repairer | Dirk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-04-2011 05:45 |
New!! Nokia Flash Checksum And Contact Service Repair | HookerGsM | Main Sales Section | 0 | 01-02-2001 10:12 |
Unlock all locks all phones *HERE* | manfred | GSM Mobile Links | 0 | 02-19-2000 10:50 |
buy your GSM here | midlandcellular | Main Sales Section | 0 | 09-04-1999 17:14 |
