Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 08-17-2016, 21:01   #1 (permalink)
Member: 1813139
Thanks Meter: 45
Help plz failed error
HI PLZ HELP I FLASH SONY F3112 FOR PETREN REMOVE BUT AFTER FLASH PHONE FINISH SETUP AND SHOWS FAILED 2227.55 00 00 00
228.01 03 04 08 0A 0C
229.04 08 0C 01 030 I FLASH ON SETOOL AFTER I TRY TO REPAIR IN Xperia Companion REPAIR ID DONE BUT PROBLEM IS SAME [ATTACH][/ATTACH]
The Following User Says Thank You to yasirsw For This Useful Post:
Old 08-17-2016, 22:07   #2 (permalink)
Member: 2609438
Thanks Meter: 13
Try to flash with Flashtool and in Firmware selector tick all options under the “Wipe” pane.
http://www.xperiablog.net/2016/03/12...erifirm-guide/
Old 08-19-2016, 19:25   #3 (permalink)
Member: 1813139
Thanks Meter: 45
same problem again not fixed
Old 08-19-2016, 20:34   #4 (permalink)
Member: 2609438
Thanks Meter: 13
Try this workaround, you must disable the following system application:
com.sonyericsson.startupflagservice 2
https://www.youtube.com/watch?v=W-bOYFLRhPQ&t=0s
https://talk.sonymobile.com/t5/Xperi...-2/td-p/860449
Old 12-14-2016, 07:37   #5 (permalink)
nathan111284's Avatar
Member: 1370010
Thanks Meter: 57
i have tested one of this problem....
solution flash via setool using this 2 file at the support
APP-SW_Tuba_GLOBALDS-LTE1D_33.2.B.3.81_1300-9504_S1-SW-LIVE-CF2A-PID1-0005-MBR
FSP_Tuba_Customized-SA_GENERIC_33.2.B.3.81_1302-4393_R5A_S1-SW-LIVE-CF2A-PID1-0005-MMC
problem will solved without error....
Old 06-09-2017, 07:07   #6 (permalink)
turkcellgsm's Avatar
Member: 395431
Thanks Meter: 458
same problem help me sony f3311_xperia_e5
Old 07-15-2017, 14:35   #7 (permalink)
Gsm Benghazi's Avatar
Member: 412609
Sonork: 100.1586824
Thanks Meter: 148
if there is no google account update your phone with Xperia Companion to last version
problem solved 100 %
Old 10-29-2017, 16:35   #8 (permalink)
..Ali Abbas..'s Avatar
Member: 2191194
Thanks Meter: 75
same problem with same model any solution bro?
Old 10-30-2017, 14:46   #9 (permalink)
Member: 2191194
Thanks Meter: 75
sony f3311 factory startup service solved
pro solvd with this file ver 37.0.A.2.108 downloded from setool sport...
APP-SW_Bassoon_GLOBAL-LTE1A_37.0.A.2.108_1301-9750_S1-SW-LIVE-8C38-PID1-0005-MBR
FSP_Bassoon_Customized-SA_GENERIC_37.0.A.2.108_1306-1005_R1A_S1-SW-LIVE-8C38-PID1-0005-MMC
The Following User Says Thank You to ..Ali Abbas.. For This Useful Post:
Old 11-17-2017, 15:09   #10 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
Install Xperia Marshmallow using Flashtool and XperiFirm [Guide] | Xperia Blog
hey..
it didnt work on G3121 device.. still failed..
Old 12-18-2017, 09:29   #11 (permalink)
Member: 570373
Thanks Meter: 236
thanks ..Ali Abbas..
workkkkkkk
The Following User Says Thank You to naizer For This Useful Post:
Page generated in 0.16229 seconds with 9 queries
