LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
10-11-2015, 12:19 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | lg g4 twrp recovery -can not -help me """"" Root write twrp recovery Ful backup stock so yu can restore back aft get unlocked. Write this global rom Here Insert non supported carrier sim enter unlock code Restore the backup .""""""" i did first step root -got as below jamesjerss sir -look above -i think root sucess-any wrong? so i did next step recovery-downloaded file twrp-2.8.7.1-h811.img and got procedure as below """"""""Prerequisites: * Root * Unlocked bootloader (In developer options, enable oem unlock) Installation: * Flash with flashify (probably the easiest method) * Flash with dd via adb shell or terminal emulator (assuming the image is in the root of your internal sdcard) Get root permission Code:su Flash the image to recovery partition Code: dd if=/sdcard/twrp-2.8.7.1-h811.img of=/dev/block/bootdevice/by-na""""""" this step i can not-how the commands ? is it also set on or download mode? i tried all ways can not --help me |
10-11-2015, 12:51 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Unlock bootloader (google it for guide) Run adb reboot bootloader fastboot write recovery twrp.img fastboot reboot Then yu can write supersu.zip nd custom rom via recovery Sent from my Moto G 2014 using Tapatalk |
