LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
02-01-2016, 13:44 | #61 (permalink) |
No Life Poster Join Date: Dec 2013 Location: England Manchester
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | sending 'boot' (8628 KB)... OKAY writing 'boot'... OKAY Execution time is 1(s) C:\adb&fastboot>fastboot flash recovery recovery.img sending 'recovery' (9210 KB)... OKAY writing 'recovery'... OKAY Execution time is 1(s) C:\adb&fastboot>fastboot flash system system.img sending 'system' (702500 KB)... OKAY writing 'system'... OKAY Execution time is 82(s) C:\adb&fastboot>fastboot flash cache cache.img sending 'cache' (13348 KB)... OKAY writing 'cache'... OKAY Execution time is 2(s) C:\adb&fastboot>fastboot flash userdata.img unknown partition 'userdata.img' error: cannot determine image filename for 'userdata.img': No error C:\adb&fastboot>fastboot flash userdata userdata.img sending 'userdata' (137318 KB)... OKAY writing 'userdata'... OKAY Execution time is 16(s) C:\adb&fastboot>fastboot reboot rebooting... Execution time is 15(ms) C:\adb&fastboot> bro phone flash 100% ok but imei or baseband unknow. |
02-02-2016, 09:57 | #63 (permalink) |
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | sending 'bootloader' (2508 KB)... OKAY writing 'bootloader'... FAILnot supported in locked device FAILED (remote: not supported in locked device) Execution time is 1(s) rebooting into bootloader... OKAY Execution time is 46(ms) sending 'radio' (42049 KB)... OKAY writing 'radio'... FAILnot supported in locked device FAILED (remote: not supported in locked device) Execution time is 2(s) rebooting into bootloader... OKAY Execution time is 46(ms) usage: fastboot [ <option> ] <command> commands: flash <partition> [ <filename> ] write a file to a flash partition erase <partition> erase a flash partition getvar <variable> display a bootloader variable getfb <filename> get frame buffer boot <kernel> [ <ramdisk> ] download and boot kernel devices list all connected devices reboot reboot device normally reboot-bootloader reboot device into bootloader help show this help message version show Version num dump emmc <filename> <start sector> <sector number> dump the emmc content to the specified file dump ram <filename> <start address> <size> dump the memory conten t to the specified file duplicate <partition> <source SN> <target SN> duplicate the specific partition from source device to target device options: -d disable the auto resend function for Hboot pre-update -w erase userdata and cache -s <serial number> specify device serial number -p <product> specify product name -c <cmdline> override kernel commandline -i <vendor id> specify a custom USB vendor id -b <base_addr> specify a custom kernel base address -n <page size> specify the nand page size(Bytes). De fault: 2048 -m <memory usage> specify the Max. memory usage(1~50MB) for zip flashing. Default: 2 Press any key to exit... AUTO FLASH ERROR SHOW |
02-02-2016, 10:03 | #64 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Why are you not listening to me cant yu post yur model nuber here? 1st unlock yur bootloader by tis cmmd fastboot oem unlock Then try again. if you dnt listen then dnt expect helps .. |
02-02-2016, 10:12 | #65 (permalink) |
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | Sorry boss it,s hammerhead D820(H) 16GB. C:\adb&fastboot>fastboot oem unlock < waiting for device > ... OKAY Execution time is 25(s) C:\adb&fastboot> same problem. |
04-01-2016, 08:30 | #67 (permalink) |
No Life Poster Join Date: Apr 2009 Location: lebanon Age: 37
Member: 1008455 Status: Offline Sonork: 0000 Thanks Meter: 99 | hello mr james i have nexus 4 running on 4.4.4 all was working good problem is suddenly hang after shutdown on bootloop i download skipsoft andriod toolkit for programing i unlock bootloader i flashed with 5 files version 4.2.2 -- 4.3---4.4.2----4.4.4----5.1.1 after each firmware i relock bootloader and wipe in recovery but phone still same problem hang ant advice sir |
10-02-2016, 09:23 | #71 (permalink) |
No Life Poster Join Date: Mar 2010 Location: bhubaneswar
Member: 1267573 Status: Offline Thanks Meter: 144 | C:\Program Files\Minimal ADB and Fastboot> C:\Program Files\Minimal ADB and Fastboot>fastboot oem unlock < waiting for device > ... OKAY [ 15.828s] finished. total time: 15.828s C:\Program Files\Minimal ADB and Fastboot> target reported max download size of 1073741824 bytes sending 'bootloader' (2579 KB)... OKAY [ 0.297s] writing 'bootloader'... FAILED (remote: not supported in locked device) finished. total time: 0.406s rebooting into bootloader... OKAY [ 0.062s] finished. total time: 0.062s < waiting for device > how can solve this................. model---LG-D821 (16gb) set is google logo then moving some circle......... |
10-02-2016, 09:33 | #72 (permalink) |
Member: 1267573 Status: Offline Thanks Meter: 144 | then manual,,but some error........ Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Program Files\Minimal ADB and Fastboot> C:\Program Files\Minimal ADB and Fastboot>astboot flash boot boot.img 'astboot' is not recognized as an internal or external command, operable program or batch file. C:\Program Files\Minimal ADB and Fastboot>fastboot flash boot boot.img target reported max download size of 1073741824 bytes sending 'boot' (8980 KB)... OKAY [ 0.500s] writing 'boot'... FAILED (remote: not supported in locked device) finished. total time: 0.594s C:\Program Files\Minimal ADB and Fastboot>fastboot oem unlock ... OKAY [ 3.812s] finished. total time: 3.812s C:\Program Files\Minimal ADB and Fastboot>fastboot flash boot boot.img target reported max download size of 1073741824 bytes sending 'boot' (8980 KB)... OKAY [ 0.484s] writing 'boot'... OKAY [ 0.750s] finished. total time: 1.234s C:\Program Files\Minimal ADB and Fastboot>fastboot flash recovery recovery.img target reported max download size of 1073741824 bytes sending 'recovery' (9696 KB)... OKAY [ 0.516s] writing 'recovery'... FAILED (remote: flash write failure) finished. total time: 0.688s C:\Program Files\Minimal ADB and Fastboot>fastboot flash system system.img target reported max download size of 1073741824 bytes erasing 'system'... FAILED (remote: failed to erase partition) finished. total time: 0.109s C:\Program Files\Minimal ADB and Fastboot> |
10-07-2016, 11:12 | #73 (permalink) |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Lg google nexus 5 flash file need DETAILED INFORMATION: PRODUCT NAME: hammerhead VARIANT- hammerhead D820 16GB HW VERSION: rev_11 BOOTLOADER VERSION- HHZ11d BASEBAND VERSION- M8974A-2.0.50.2.29 CARRIER INFO-NONE SERIAL NUMER-xxxxxxxxxxx SIGNING-production SECURE BOOT- enable LOCK STATE- locked flashing instructions and flash file need.. B/R SHERAZ... |
10-12-2016, 11:32 | #74 (permalink) |
Freak Poster Join Date: May 2007 Location: portugal
Member: 515940 Status: Offline Thanks Meter: 29 | how to flash LG NEXUS 5 i need flasher and flash file FASTBOOT MODE PRODUCT NAME: hammerhead VARIANT- hammerhead D821 (E) 16GB HW VERSION: rev_11 BOOTLOADER VERSION- HHZ20h BASEBAND VERSION- M8974A-2.0.50.2.29 CARRIER INFO-NONE SERIAL NUMER-0404c842xxxxxxxx SIGNING-production SECURE BOOT- enable LOCK STATE- UNlocked James SIR PLZ HELP ME BR// SAINI |
