Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Android based chinese phones
Old 12-07-2014, 11:30   #1 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
Sptool Flasher Problems/Error/ Solution All At One Place
Lots Of time we faces a problem when working with sptool when we flash mtk androids..so frnds we discuss and share here sptool problems/errors..why it happens..and what is its solution...
There is some mode in mtk for connect phone to pc,read below to know more
=: BOOTROM :=
(in Device Manager is usually seen as MTK USB Port with pid = 003).
In order to connect your phone in this mode,we need some key combinations,like vol up + cable connect or home button + cable connect,we have to keep try until we found correct key for this
Sometime we need special cables or test points to get this mode.
=:Preloader :=
(Port MediaTek USB VCOM with pid = 2000).
Its most common mode in mtk android phones,when we trying to flash phone using sptool and connect phone in power on phone condition to usb,phone connect as preloader
Is it sometime hard to install drivers in this mode,as its quickly disappear,but its not much hard if you faster then your pc
Just kidding you should install driver from exe base installer
=: DA_HIGHSPEED :=
(Port MediaTek DA USB VCOM with pid = 2001).
Ok when you flash your phone,you connect first in bootrom mode or in preloader,as sptool detect your phone,its give command to phone for DA_Highspeed download,to load the firmware in phone.
So it will always good to check drivers when flashing phone with sptool,if sptool giving error after the first red line,you should check for Da drivers.
=: Guide How To Disable DA Download All :=
Sometimes off mode DA Download All helps to avoid errors on phones with MTD (nand) flash. The latest versions of FT this can not be done from the menu, you must change the file platform.xml (Inside sptool flasher). You need to change in the platform of your phone keys usb_download_support and da_dl_all_support to "true" to "false" Warning! This only works if not marked daw blocks preloader and dsp_bl! If you need to sew the blocks, it is necessary to put true!
After these changes, you must connect the cable to the PC immediately after clicking on Download , and wait for the end of the frame.
Thanks Thred will Be updated
Best Regards
Rahul_Bhutani
The Following 28 Users Say Thank You to Rahul_Bhutani For This Useful Post:
Old 12-07-2014, 11:31   #2 (permalink)
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
Errors and why Its occures
1] S_UNSUPPORTED_OPERATION(1040):==
Scatter file does not fit the phone. For example, in 6577 the title is present, and the phone is actually 6573
2] S_DA_EMMC_FLASH_NOT_FOUND(3144):==
Besides problems with iron can be Scatter when the file is not the phone. For example in the title is present emmc, and the phone is actually a MTD flash.
3]S_BROM_CMD_STARTCMD_FAIL(2005):==
On phones with MTD flash if an error occurs:
1] When you select Download to block preloader or dsp_bl not set daw. You should use the appropriate version SPFT, such v2.xxx for phones MT6573, or off DA Download All .
2] When you select Download to block preloader or dsp_bl set daw. It is necessary to uncheck these blocks! If these blocks need to flash, it is necessary to connect the phone to BOOTROM.
3] When selecting Readback , Format , or MemoryTest . It is necessary to connect the phone to BOOTROM.
4] S_FT_READBACK_FAIL(4009):==
In addition to reading errors in the phone the same error for errors in the file system PC. Eg not enough space for a file or file can not be overwritten because it is locked. To clarify the log should look.
5] S_FT_NEED_DOWNLOAD_ALL_FAIL(4050):==
Do not match the size of the blocks in the PMT and scatter. We must look at the log line BROM_DLL
Partition 13 (USRDATA) size changed from 0x0000000000000000 to 0x000000000B620000
This error may occur after the curve editing scatter during treatment error 8038. Treated loading FT through all blocks, or only one block userdata , then the size in the PMT should switch to the right. Instead, the entire block can be sewn userdata_nvram_only.img from its backup file or a pacifier.
6] S_DL_PC_BL_INVALID_GFH_FILE_INFOR(5066):==
Wrong files. For example when the scatter of the chosen folder is not yet prepared for the FT files. It is necessary to choose the scatter in the folder prepared for FT files.
7]SP FLASH TOOL ERROR(8038):==
This error Occure If:=
For phones with the old type scatter (MT6515 / 16/17/73/75/77/89):
Names and location of the blocks in the scatter differ from the table inside the phone (PMT). We must look SP_FLASH_TOOL.log and look at it line NOT MATCH
Example=
NandLayoutParameter :: CompareIsNandLayoutMatched (): NOT MATCH: load item key (CUSTPACK2), value (0x3444000), target item key (CUSTPACK), value (0x3444000)
in this example, it is necessary to replace the name scatter CUSTPACK2 on CUSTPACK. If a few differences, this error will occur until the scatter after amendment does not become identical to the PMT. You can just fix it, if we compare the tables are a little higher in the log line NOT MATCH. The first of scatter, the second of the PMT phone. It is necessary that all blocks in the names scatter were the same as in the second table
Edit scatter must be carefully! Change the names and the number of lines to save the original! Some manage to remove the newline and string imenm unit is on one line with a brace. FT sees this block without PMT and writes it. Then we need to spend efforts to restore this table.
Best Regards
Rahul_Bhutani
The Following 27 Users Say Thank You to Rahul_Bhutani For This Useful Post:
Old 12-08-2014, 05:59   #3 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,979
1ST Step :->: SP_Flash_Tool_v3.XXXX.XX :
  • 1st try to flash your phone with (SP_Flash_Tool_v3.XXXX.XX) Version
  • Try To Flash Using {Firmware-> Upgrade} Option
  • If Any Error Then Try To Flash Your Phone With {Downloa}
  • Check below Both Option OF {SP_Flash_Tool_v3.XXXX.XX}
If You If you unable to flash With (SP_Flash_Tool_v3.XXXX.XX) Then Use SP_Flash_Tool_v5.XXXX.XX Version . Let's See
2ND Step :->: SP_Flash_Tool_v5.XXXX.XX :
  • Try To Flash your Phone Using { Download Only } Option
  • If Fail Then Try To Flash Your Phone With {Firmware Upgrade} Option
  • If Still Fail Then Try to Flash Your Phone With { Format All + Download } Option
  • Check below Both Option OF {SP_Flash_Tool_v5.XXXX.XX}
If You If you unable to flash using both way(SP_Flash_Tool_v3.XXXX.XX And SP_Flash_Tool_v5.XXXX.XX ) Then Try 3RD Way , Let's See
3RD Step :->: SP_MDT_v3.XXX.XX
  • Same the way you fellow , Which already have in 1st and 2nd Step
  • Check below option (SP_MDT_v3.XXX.XX) Select one by one and Try
Note : SP_MDT_v3.XXX.XX Tools working good on Dead Phone /Dead Preloader , Which dead by Flashing
IF you already fellow my way you will be success , In case Still You get Any Error kindly Check HERE
AzimBahar/ParvezAhmed.NET
The Following 4 Users Say Thank You to aZimBahar For This Useful Post:
Old 12-08-2014, 10:26   #4 (permalink)
Member: 805211
Sonork: 1661191
Thanks Meter: 68
How about error 1013 and 4010?
The Following 2 Users Say Thank You to abe05 For This Useful Post:
Old 12-08-2014, 19:34   #5 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
many times we need older version sptools to flash some sets , why is that so ?
is there any sp tool which can be used with all the old and latest mtk based phone ?
The Following 2 Users Say Thank You to gsmsikar For This Useful Post:
Old 12-10-2014, 15:14   #6 (permalink)
tejas243404's Avatar
Member: 725038
Sonork: 100.1675584
Thanks Meter: 288
mtk 6571 sp tools v5.1436 error 3040 plz solsunan
The Following 2 Users Say Thank You to tejas243404 For This Useful Post:
Old 12-11-2014, 13:21   #7 (permalink)
Moderator
gsm mithun roy's Avatar
Member: 1537689
Sonork: 100.1669550
Thanks Meter: 2,219
any way to format nand flash chip ...?
when sp flash tools cant compleat format /unable too format
The Following 2 Users Say Thank You to gsm mithun roy For This Useful Post:
Old 12-11-2014, 17:47   #8 (permalink)
Member: 2082450
Thanks Meter: 1,454
Another error found...
Error : 'PMT changed for the rom'.
Cause : This type of error generally occurs when, upgrading or de grading the factory os.
In this case the mbr value changes to different one.....
Solution : In this case, u have to choose 'Firmware upgrade' rather than 'Download only'.
After that, all the data will be erased even from internal memory...
Note : Backup all the important data before doing this operation, because internal memory will be format in this.
Chandanps18
The Following 6 Users Say Thank You to chandanps18 For This Useful Post:
Old 12-22-2014, 12:29   #9 (permalink)
Member: 2136362
Thanks Meter: 31
Anybody help me, I am new to sp flshtool operation..... Please show me video guide
The Following 2 Users Say Thank You to pintu mangaraj For This Useful Post:
Old 12-22-2014, 13:27   #10 (permalink)
Moderator
Member: 1537689
Sonork: 100.1669550
Thanks Meter: 2,219
google can help you much more
Old 12-30-2014, 13:14   #11 (permalink)
Member: 2082450
Thanks Meter: 1,454
List of errors and Solution
Here are a few more list of errors and solution
1] BROM ERROR : S_FT_ENABLE_DRAM_FAIL (4032) [EMI] Enable DRAM fail
Cause: SP Flash tool is unable to enable DRAM / communicate effectively with the device
Solution: Ensure that the file(s) you're trying to flash are actually for your exact phone model
Format the phone before trying to flash the file(s) again
Ensure the phone is switched off (with battery still inside) before connecting to PC for flashing.
If that doesn't work, keep trying with the boot key
2] BROM ERROR : S_DL_PMT_ERR_NO_SPACE (5069)
Cause: The size of a file is larger than the available / possible partition size.
Solution: Ensure that the file(s) you're trying to flash are actually for your exact phone model. Try another stock ROM
3] S_FT_Download_Fail(4008)
Solution: Fully Charge the battery. Use the latest SP Flash Tool. If still u get this problem, time to format the device. Note: in format Your all data e.g Nv data will be deleted...
The thread will be updated.
Wbr
Chandan
Old 01-07-2015, 16:16   #12 (permalink)
abdulhaq_majroh's Avatar
Member: 1600947
Sonork: 100.1627298
Thanks Meter: 772
hello all please help me
Please any one help me I was flash a lot of clone s7582 s7562 etc with sp flasher but after flash complete phone not detect sim how to solve this?
The Following 2 Users Say Thank You to abdulhaq_majroh For This Useful Post:
Old 01-07-2015, 17:46   #13 (permalink)
Member: 2082450
Thanks Meter: 1,454
May be nv corrupt.
Need to repair nv and check imei.
Post result
The Following 4 Users Say Thank You to chandanps18 For This Useful Post:
Old 01-12-2015, 15:32   #14 (permalink)
Member: 571857
Thanks Meter: 20
all china set master helf me
mtk 6575 former sp-tool set is dead.
what can i do....
The Following User Says Thank You to mithon For This Useful Post:
Old 01-13-2015, 08:22   #15 (permalink)
Member: 2082450
Thanks Meter: 1,454
what can i do....
Start ur own thread and post problem details with screenshot, then only u can get better help from other members.
Hope u can understand me correctly....
Chandan
The Following 3 Users Say Thank You to chandanps18 For This Useful Post:
Page generated in 0.32511 seconds with 9 queries
