Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Hardware Repair
HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions
Old 06-12-2014, 16:18   #1 (permalink)
Pandemonio100's Avatar
Member: 3381
Thanks Meter: 1,171
Htc desire 500 backlight problem.
HI friend i have a strange problem whit an Htc desire 500 problem is light setting not work, the light inside lcd is low but visible i reset it but nothing changing in setting brightness also if i change the level not change also using automatic brightness not change but if i close sensor with the hand the two function keys light up.
somenone have had this problem.
Tanks
Pandemonio100
Old 06-17-2014, 14:24   #2 (permalink)
Member: 18832
Thanks Meter: 18
Same problem here after JTAG, no shorts after removing the wires, still no light setting is working. Light sensor and proximity sesor work normal.
I try to find another device to see if it is mainboard or LCD.
Await any solution, thank you.
Old 06-24-2014, 19:17   #3 (permalink)
Member: 18832
Thanks Meter: 18
Tanks
Pandemonio100
Did you find solution by any chance? I tested now with another complete LCD assembly, same problem with that, aswell.
Thank you, WBR
e-studio.hu
Old 06-25-2014, 08:52   #4 (permalink)
Member: 3381
Thanks Meter: 1,171
Unfortunately I have not solved and i give back to customer but it's a very very strange problem I've never seen, usually in others phones when light not work not work, this instead has only a problem on the setting of the light.
Old 06-25-2014, 11:57   #5 (permalink)
Member: 18832
Thanks Meter: 18
I also have no idea what happened, but unfortunately it happened after I successfully did JTAG unlock on it. I guess I'll have to buy another one for customer
Thank you for info, anyways.
WBR
e-studio.hu
Old 08-13-2014, 15:43   #6 (permalink)
Member: 91740
Thanks Meter: 31
change lcd light coil 200 erıcsson k300 coil 200 change test ok
Old 08-14-2014, 14:30   #7 (permalink)
Member: 18832
Thanks Meter: 18
Could you share a picture to make identification of faulty part easier?
Thank you.
Old 08-19-2014, 14:20   #8 (permalink)
popzoran's Avatar
Member: 91406
Thanks Meter: 57
Coil 220 near to baterry conector from k800,k750 etc.
The Following User Says Thank You to popzoran For This Useful Post:
Old 09-06-2014, 21:02   #9 (permalink)
Member: 542671
Thanks Meter: 19
can any body post antina ways for these modle
Old 01-20-2015, 10:00   #10 (permalink)
Member: 1214273
Thanks Meter: 136
Thanks for solution. It works for me after Desire 300 water damage and low screen backlight. I have changed coil from HTC Cha Cha.
Old 02-16-2015, 17:49   #11 (permalink)
rico1's Avatar
Member: 5397
Thanks Meter: 38
This first phone unlock procedure, then not light!
this solution helped me a lot! I exchanged the coil! Thanks!!!!
Old 03-19-2015, 14:50   #12 (permalink)
Member: 120029
Thanks Meter: 14
Good solution! I used coil from SE K500. Thank's guys!
The Following User Says Thank You to xela09 For This Useful Post:
Old 04-12-2015, 15:48   #13 (permalink)
Member: 2377883
Tanks guys, i change coil 220 an its work
Old 04-21-2015, 09:19   #14 (permalink)
Member: 2382359
After change coil 220 backlight was work just few second and stop. Any other solution?
Old 06-25-2015, 16:32   #15 (permalink)
Member: 1761814
I changed the 220 coil and LCD is bright again.
Thanks!
Page generated in 0.22576 seconds with 9 queries
