HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions |
12-11-2015, 10:18 | #18 (permalink) |
Junior Member Join Date: Dec 2015 Location: italy
Member: 2499345 Status: Offline Thanks Meter: 0 | Soldering the coil the coil isn't simple. After replacing the screen, I had the same low-backlight problem. After coil replacement everything worked fine for few days. Now the backlight is not working at all (but using a strong light I can see that the LCD is working). Does someone has any suggestion? |
12-16-2015, 18:32 | #19 (permalink) |
Member: 2499345 Status: Offline Thanks Meter: 0 | I found out the problem... it was the bad soldering! Any suggestion how to solder properly the coil? (or any other little piece to a motherboard with other compoents all around) |
