HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions |
11-07-2012, 11:36 | #16 (permalink) |
Junior Member Join Date: Jan 2007 Location: Tirane, Albania Age: 53
Member: 434076 Status: Offline Thanks Meter: 1 | wish you all the best, meanwhile I like to discuss with you a strange problem regarding with a faulty HTC one X. It have problem on the middle of the touch pad. It does not respond on digits 1; 2; 3 during dial pad so it is impossible to dial up phone numbers that include these digits. Can somebody tell me if there is any solution in this case? The phone has good condition touch pad, there is not any scratches or dirties on the LCD. Any kind of help shall be much appreciated. With best regards, FrePa, |
11-08-2012, 23:40 | #18 (permalink) | |
Junior Member Join Date: May 2011
Member: 1578161 Status: Offline Thanks Meter: 2 | Ic Quote:
(ACTIVE) Li+ Battery Charger With WLED Driver and Current Shunt Monitor - Lnk to E_B_A_Y, in adress bar, delite symbol (*) Replacement parts: Coil 1: 220mH Coil 2: 2.2 mH IC1: TPS65200 that all..))) ths list phone models, where you can, finde that IC: HTC/ EVO 3D incradible S sensation XL (only XL) Desire S Wildfre S ths information, i take from ruusian repairs forums! Good Luck!! Last edited by Scorpion23; 11-08-2012 at 23:47. | |
The Following 2 Users Say Thank You to Scorpion23 For This Useful Post: |
11-13-2012, 15:34 | #19 (permalink) |
Member: 1578161 Status: Offline Thanks Meter: 2 | Tps 65200 HTC/ EVO 3D - 100% have IC incradible S sensation XL (only XL) Desire S - 100% have IC Wildfre S - this device, don't have IC-TPS65200 |
11-15-2012, 12:40 | #21 (permalink) | |
Member: 1578161 Status: Offline Thanks Meter: 2 | Inductor Quote:
coil-2 I can't finde discription. But i find this coil in, Desire-S. If you want replace a first time, both coils's DONT POWER ON your device!!! Replace necessarily IC TPS65200. If you replaced first time both coil and phone turn On, the chip burn. I have two chips burned. unknowingly((((( IMPORTANT!!!!! If there is a problem with the backlight, be sure! Change and both coil and chip. Only then switch on the phone! | |
11-24-2012, 18:53 | #24 (permalink) |
Member: 1578161 Status: Offline Thanks Meter: 2 | According to the datasheet, the backlight is a zener diode. As I understand it, it just gives the stabilization of current to the LEDs. There is a suspicion that it takes place. We must look for this sign. 90 percent chance that he interferes, live the light chain. |
12-15-2012, 11:39 | #26 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1853392 Status: Offline Thanks Meter: 0 | Hi, I have a problem with newly replaced screen. Everything looks that works fine(touch, backlight...). But I have problem with colours. It is actually not black but kind of grey and all other colours look the same like the brightness(not backlight) was set to 100%. The screen should work with no problems like that because the guy from the gsm service told me he made many replacements with this screen and nothing happened like that. I attached a sample to let you imagine what I am writing about. Thanks for reply in advance. |
01-01-2013, 15:06 | #28 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1861479 Status: Offline Thanks Meter: 1 | Hello, I hope someone can help me. I Have a HTC ONE X the screen are flickering and I don’t can change the brightness. When I change the brightness to min o to max the brightness are always the same. Someone have just resolved this problem? |
01-15-2013, 21:36 | #30 (permalink) |
Member: 1869032 Status: Offline Thanks Meter: 0 | Hello, I have an HTC One X model PJ83100 US version. The motherboard is different than what is shown in the photos in previous posts. The 220 coil appears to be a '100' and in a different location. The second coil and the IC are also not as shown in the pictures. Does anyone have experience fixing the backlight issue on the US models and can you get the parts from the US versions of the iPhones? |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
