HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions |
09-24-2012, 04:15 | #1 (permalink) |
Junior Member Join Date: Jun 2012
Member: 1776142 Status: Offline Thanks Meter: 4 | Htc One x strange backlight problem This is my first post on this forum. I have been reading a lot here and I find the information posted here very useful. I have a repair shop in Sydney, Australia. Hope you guys can help me. A customer came to the shop with a cracked touch screen on a HTC One X and the backlight was working fine. I have worked on htc one x a lot of times. I took the motherboard out and tested a new LCD/touch assembly without replacing the cracked screen to make sure the new LCD/touch was working. When I did test it the backlight was working fine again. Then I went and replaced the touch/LCD and when I closed the phone to test the screen again there was no backlight.. I have tried other LCD/touch screens and backlight is still not working. How could I fix this problems? Please advise Thank you |
The Following User Says Thank You to IT1989 For This Useful Post: |
10-05-2012, 07:19 | #9 (permalink) | |
No Life Poster Join Date: Dec 2004 Age: 50
Member: 98139 Status: Offline Thanks Meter: 126 | Quote:
here is pcd layout u can edit it where to make change and post it thanks | |
10-10-2012, 16:15 | #11 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Brisbane, Australia
Member: 1788854 Status: Offline Sonork: Mobile Fix Simple Thanks Meter: 16 | here is the solution of htc one x back light Please do one by one! Your problem will be solved. P.S. the mother board of One X is different with One XL. This Solution is for HTC ONE X ONLY! |
The Following 2 Users Say Thank You to Mobile Fix Simple For This Useful Post: |
12-03-2012, 17:28 | #15 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1846879 Status: Offline Thanks Meter: 0 | Need halp Have a trouble with replacing the coil. When soldering the coil accidentally have been unsoldered a capacitor. Later, trying to solder the capacitor has finally lost it. Who can help identify capacitor? |
