12-12-2016, 09:58 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. If your phone is detected by PC as "Qualcomm..." device, try to connect it via USB and make Factory repair by the following way: 1. Install the latest Medusa Pro Software version (Medusa Box Downloads - Software, Drivers, Manual). 2. Select "USB" interface, "Core : Qualcomm MSM8916", "Loader : QLoader_v1". 3. Connect your phone to PC via USB cable ("Qualcomm...9008..." device should appear in PC Device Manager). 4. Press "Connect" button in Software and wait while device will be connected. 5. When device will be connected successfully, go to "Factory repair" tab in Software. 6. Press "Repair LG devices..." button. 7. Select original firmware for LS665 (in "*.tot" or "*.kdz" format) and press "Write partitions" button. 8. Post here the result. If the device not connects with "QLoader_v1" loader, try to connect it using "QLoader_v2" and "QLoader_v3" loader. |
04-26-2017, 21:21 | #3 (permalink) | |
Insane Poster Join Date: Jan 2008 Location: Venezuela
Member: 682544 Status: Offline Thanks Meter: 19 | not solved Quote:
Interface : USB Core : Qualcomm MSM8916 Loader : QLoader_v1 Connecting... Sending loader... Failed. Model Settings: Interface : USB Core : Qualcomm MSM8916 Loader : QLoader_v2 Connecting... Sending loader... Failed. Model Settings: Interface : USB Core : Qualcomm MSM8916 Loader : QLoader_v3 Connecting... Sending loader... Failed. Last edited by Octopus box; 04-27-2017 at 06:29. | |
04-27-2017, 06:33 | #4 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. As You can see from your Software log, all USB Qualcomm MSM8916 loaders "QLoader_v1", "QLoader_v2" and "QLoader_v3" are not compatible (not suitable) with your phone, the phone doesn't accept them: Quote:
http://forum.gsmhosting.com/vbb/f664...d-usb-2161902/, http://forum.gsmhosting.com/vbb/f798...table-2162110/. | |
04-28-2017, 18:51 | #5 (permalink) | |
Member: 682544 Status: Offline Thanks Meter: 19 | okey only for eMMC repair ONLY??? Quote:
05-29-2017, 07:37 | #8 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. Quote:
1. You have connected battery or USB cable. Before connecting the device You must disconnect the battery and the USB cable, and then connect the device without power, this is important! 2. Some wires are soldered incorrectly. Carefully check soldering of all wires. 3. In the process of soldering, the resistors were burned (damaged) by using soldering iron or the pin pads on the board to which wires were soldered were damaged. Need replace damaged resistors and restore the pin pads on the board. 4. The ends of wires that were soldered, had not been cleared. Wire, that comes complete with Medusa Pro Box, is covered with an insulator, so before soldering need to clean the ends of each wire. 5. Soldered wires are too long. Make each wire as short as possible (3-5 CM length). 6. For GND connection use more thicker wire. Check all of them and try to connect the device again. Also read these rules: http://forum.gsmhosting.com/vbb/f62/...rules-1591101/, http://forum.gsmhosting.com/vbb/f664...leted-2165828/. | |
05-29-2017, 12:57 | #10 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Post here full Software log with the connect procedure, we will check. Last edited by Octopus box; 05-29-2017 at 13:09. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
05-29-2017, 22:13 | #11 (permalink) |
Junior Member Join Date: Jan 2006
Member: 224793 Status: Offline Thanks Meter: 0 | Welcome to Medusa Pro Software version 1.3.7. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS665 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS665_EMMC_QN1SMB.srf Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Imgur: The most awesome images on the Internet |
06-04-2017, 16:08 | #15 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | The latest version is 1.3.8 and You can download it from Medusa official site: Medusa Box Downloads - Software, Drivers, Manual. |
