06-06-2017, 00:58 | #16 (permalink) |
Junior Member Join Date: Jan 2006
Member: 224793 Status: Offline Thanks Meter: 0 | Welcome to Medusa Pro Software version 1.3.8. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS665 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS665_EMMC_QN1SMB.srf Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. |
06-06-2017, 08:06 | #17 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Check connection again (soldering of each eMMC wire). We have tried to connect our LS665 and there are no any problems with connecting it: Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : 20 Connecting... Device : Samsung eMMC QN1SMB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 150100514E31534D4201554DC4E8523B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN1SMB Product revision : 0.1 Product serial number : (hex) 554DC4E8 Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file D:/Projects/Octoplus_JTag/build/EXT_CSD Backups/QN1SMB_06_06_2017_08_51_30.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.8; FW: 1.18. P00: GPT (00000000, 00000400) P01: sbl1 (00000400, 00000400) P02: tz (00000800, 00000400) P03: hyp (00000C00, 00000400) P04: rpm (00001000, 00000400) P05: aboot (00001400, 00001000) P06: pad (00002400, 00000C00) P07: sbl1bak (00003000, 00000400) P08: tzbak (00003400, 00000400) P09: hypbak (00003800, 00000400) P10: rpmbak (00003C00, 00000400) P11: abootbak (00004000, 00001000) P12: misc (00005000, 00008000) P13: persist (0000D000, 00008000) P14: metadata (00015000, 00000400) P15: modemst1 (00015400, 00000C00) P16: modemst2 (00016000, 00000C00) P17: laf (00016C00, 0000C000) P18: boot (00022C00, 0000C000) P19: recovery (0002EC00, 0000C000) P20: fsg (0003AC00, 00000C00) P21: fsc (0003B800, 00000400) P22: ssd (0003BC00, 00000400) P23: DDR (0003C000, 00000400) P24: sec (0003C400, 00000400) P25: encrypt (0003C800, 00000400) P26: eksst (0003CC00, 00000400) P27: rct (0003D000, 00000400) P28: sns (0003D400, 00004000) P29: factory (00041400, 00010000) P30: fota (00051400, 00010000) P31: drm (00061400, 00004000) P32: mpt (00065400, 00010000) P33: modem (00075400, 00020000) P34: persistent (00095400, 00001000) P35: carrier (00096400, 00014000) P36: system (000AA400, 004ACC00) P37: cache (00557000, 001A9000) P38: userdata (00700000, 00788000) P39: grow (00E88000, 00007FDF) |
